BMW M3 Forum (E90 E92)
BPM
      02-21-2009, 05:17 PM   #1
camaross305
camaross305's Avatar
135
Drives: 2008 M3
Camaross305's Plug and play HID angel DIY
Total install on the plug and plays is about 15-20 min. Very easy with simple tools.
Tools
alll you need is
1. 10mm socket
2. 13mm socket
3. zip ties (provided) scissors to cut the excess
4. flat head screw driver
Before you even start as a note. The circuit it self is kinda fragile just be careful not to drop it or break any of the components. Also when handling the HID bulbs themselves DO NOT TOUCH THE GLASS ITSELF unless you have latex gloves on. Because the grease on our finger will ruin the bulb in no time.
First off here is the parts included. 2 ballasts, 2 bulbs, the circuit in the small box, a resistor, and the wiring harness.
Ok your circuit should look something like this. Some of you requested it in tape so that its easier to mount in the headlight area.
If you want to use this circuit enclosure youll have to pop off the headlight lid. And flip it over. Youll see a system of protruding plastic vains from the molding process youll have to cut these off to fit the circuit in the headlight area with the box around it.
1. First off disconnect your battery in the trunk. (if you dont know how to do this there is a few DIY on it)
2. Next remove the plastic cover that is over the positive post shown here
here is where it is located in the engine bay
Here is the cover up close
should look like this after removed
3. Next unscrew the bolt shown in the pic above with a 13mm socket
4. Take the thick red wire that looks like the one shown bellow with the ring terminal on it from the harness and attach it to the threaded shaft and bolt down the connection like shown above. Make sure it is pointing down so the plastic cover goes back on
( Part 4 Cont)
some of you with the newer style harness have a black wire for a better ground like this in harness.
5. As for the passenger side ballast ground. You will see 3 grounds behind the windshield fill neck. 2 painted and one non-painted. Put the ground on the bottom (more toward the ground) of the two painted ones that has nothing on it.
6. Run the wire in the wire behind the winshield washer tank neck and route it as shown. I put some wire loom to make it look cleaner. After running the wire this is how it should look
7. Next open the lid that contains your halo's bulb. Lift the tab as shown.
8. Next located the stock bulb you can see it here in the headlight are after the lid is removed
Twist it counter clockwise and pull it out like so.
Disconnect the factory wiring harness from it
Next put in the new hid bulb in the socket.
This step is kinda difficult but i find it much easier to put the bulb in bottom first like shown here and use a screw driver or skinny object to maneuver the HID bulb into the socket.
Its going to take some twisting and turning around to get it to fit but trust me it fits.
Make sure you leave the plugs from the HID bulb outside of the cannister so the lid can go back on. Run the wires comming from the circuit in the same fashion. I notched my lid in the back as shown to be able to run the wires out. Just make sure you dont cut the actual rubber seal
This is how i placed the wires toward the back of the lid so you dont see the wires
9. Connect the circuit with the plug and play connectors. It should only go one way (so you cant mess it up) but the red or yellow wire should be connected to the yellow wire on the factory plug like this.
10. Then connect the connectors coming out of the circuit. They two should be opposite and impossable to reverse but in this case the red connects to the blue and the black to black with plug and play opposite connectors.
11. Next connect the plug and play plugs from the hid ballast assembly to the bulb. Here is the balast plugs connected and ran underneeth the metal brace out the back of the lid...also run your wires from the harness to the circuit under here to keep all the wires hidden.
Also connect the plug and play plug from the wiring harness to the ballast looks like this. Be sure to use the shorter one of the two in the harness as the long one is to reach to the driver side.
12. After this tuck your ballast, wire harness, and relay away. I put mine here (yellow arrow) and it fits perfect. I placed everything here and its hidden.
13. Then run the other longer of the plug and play plugs shown bellow, in between the top of the fan shroud and under the cover.
14. Repeat the same process for taking off the lid exposing the old bulb, taking out the bulb etc. Put in the new HID bulb on the other side and hook the remainder of the plug and play plugs.
You will also see on the harness a ground for the driver side ballast. Put it on the 10mm bolt on the driver side shock tower (should have two brown wires on it already) and run your wire under the air box. should be here
Lastly Place the resistor i supplied into the stock plug with the plug and play connector
Lastly tuck in your ballast under the air box assembly right here. You may or may not have to remove some bolts holding the air box assembly down. You dont have to do this but i think it gives it a clean stock look.
13. Lastly check all your connections and start up your car. Take a look and make sure your all done. WALLA! your done. Just tidy up your wires and zip tie any hanging wires.
Here is the final look at the engine compartment. Looks stock and you wouldnt even know there is anything new if you didnt know to look for it Enjoy your new super bright halos!!!
Disclaimer: Im not responsible for any miss wiring or faulty connections and any damage that may occur from someone besides me installing this kit. Install at your own risk!
The original Hid angel eyes for sale now on ebay
User name lmims526894rou
Or contact me at chrism9551@aol.com
      02-23-2009, 01:01 AM   #2
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
my 0.02c ... you can unscrew the intake part you see on this picture and use those unused clips to run the harness to the other side ... there are 3 of them and it hold the harness perfect. you can see one of those clips on this picture as well
      02-23-2009, 01:36 AM   #3
gthirtyfizle
gthirtyfizle's Avatar
191
Drives: E92 M3 AW
Let me know if u ever come to nyc, ill pick one of these up and have u install it. Looks way too complicated for me haha. Looks great tho buddy.
      02-23-2009, 08:46 AM   #4
camaross305
135
Drives: 2008 M3
Its really easy... completely plug and play and nearly impossible to mess up. takes about 20 min to install
      02-23-2009, 09:53 AM   #5
J08M3
J08M3's Avatar
Drives: 2011 M3 COUPE
It's easy. Can't mess it up really it only plugs together one way.
      02-23-2009, 10:43 PM   #6
camaross305
135
Drives: 2008 M3
Thanks for the info!!
As he said there is only one way to plug everything in. I make them dummy proof
      02-24-2009, 08:20 AM   #7
bim14
BIMMM3R
bim14's Avatar
77
Drives: '14 M5 6MT AW/SO
I have a Melbourne red e92 and right now I have the 8400k gp thunders, is there any possible way to get red angel eye bulbs so the halos are red?
      02-28-2009, 02:45 PM   #8
doba_s
doba_s's Avatar
i think he can get you bulbs in any color
      02-28-2009, 06:41 PM   #9
camaross305
135
Drives: 2008 M3
Thanks doba...... yes i can get them in pretty much any color.... i could do red but it will probably be illegal lol.
      02-28-2009, 07:27 PM   #10
kmarei
kmarei's Avatar
Egypt
685
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
do you sell just the resistors?
that would solve the problem with the GP thunder that they dim
if i don't want to transition to HID
then that resistor would fool the system into thinking the bulb is there
when the bulb is being powered by a direct positive from the battery and the relay its using is powered by the stock wire
      03-01-2009, 01:23 PM   #11
camaross305
135
Drives: 2008 M3
yep this is true thats what im trying with LED's so they will have full 12v power! but will be way brighter than now but not as bright as hid's
      03-02-2009, 11:10 AM   #12
slimj281
Drives: E92 cp 6-MT
camaro did you receive my pm?
      03-02-2009, 03:54 PM   #13
noxredna
noxredna's Avatar
63
Drives: E92 M3, E30 M3, 1M, F10 M5
have you received the bulbs yet? Can't wait to get it!!
      03-02-2009, 06:05 PM   #14
camaross305
135
Drives: 2008 M3
Yea sorry lol pmed ya back
      03-02-2009, 06:06 PM   #15
camaross305
135
Drives: 2008 M3
lol dont worry any day now!
      03-14-2009, 08:17 PM   #16
m3 Kidd
Drives: e92 m3 sparkling graphite
My Light Kit Order
I have sent you several PM's and haven't heard back. Let me know the status of my order being shipped.
Thanks,
m3 Kidd
      03-15-2009, 03:37 PM   #17
camaross305
135
Drives: 2008 M3
Thanks,
m3 Kidd
sorry pmed ya back..... was on vacation
      03-22-2009, 06:51 PM   #18
noxredna
noxredna's Avatar
63
Photos are down - can't install my kit that I received yesterday! Let's get the photos back up so I can do the installation
      03-22-2009, 09:55 PM   #19
camaross305
135
Drives: 2008 M3
sorry photos are back up
      03-25-2009, 02:23 PM   #20
camaross305
135
Drives: 2008 M3
Ok links fixed
      03-25-2009, 04:15 PM   #21
skoot3r
BMW n00b
skoot3r's Avatar
Drives: 09 e92 M3/ 2013 GMC 2500hd
HTML Code:
i was wondering if you got my pm that I sent you yesterday asking about the status of my order that I placed Saturday.
09 SpaceGray M3 DCT
Power: Dinan 3.62, Gintani Race Mufflers, Dinan Intake, Gintani Xpipe, RPi Scoops
Cosmetic: Vrs Poly-Lip, CSL Trunk, LED Interior Lights, LUX H8, Smoked Tails, Challenge Diffuser
      03-25-2009, 04:57 PM   #22
camaross305
135
Drives: 2008 M3
Originally Posted by skoot3r View Post
HTML Code:
Pm replied
m3post
