03-18-2009, 10:56 PM | #1 |
Rep 5,483
Removal of Centre Console?
I tried searching for any info on how to remove the center console, but came up with nothing.
I am having my centre console around the shifter area wrapped in carbon leather VERY similar to the OEM trim offered by BMW. Heres a link with pics of the carbon material I have been able to get a hold of. http://www.m3post.com/forums/showthread.php?t=241740 Could anyone help me or provide a link or DIY for removing the centre console in the front and also the centre console in the back (where the air vents are for the rear passengers). Thanks a lot and I will post pics of the finished product.
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
03-18-2009, 11:06 PM | #2 |
Rep 1,035
http://www.e90post.com/forums/showthread.php?t=95731
I'll try to find rear. It's pretty easy as I've done it myself already.
03-19-2009, 05:12 AM | #3 |
Rep 1,171
The best advice I read when I was replacing the ashtray with the sunglasses holder was to wrap a wide flat screw driver in a tea towel and prise up the centre console at each of the mount points - there are 3 or 4 on each side. Once you've popped the first up, you can finish the rest with your hands.
03-19-2009, 09:25 AM | #4 |
Rep 5,483
So is it relatively easy to remove it? I shouldn't be paying for someone to do it?
Current:
03-19-2009, 01:11 PM | #5 |
Rep 1,035
It's actually pretty easy and you just have to be smart. Know that if you are using a metal pry tool against plastic, metal is usually going to leave a ding. There are plastic pry tools and you can improvise. I've removed a lot of panels in my time from doing stereo installs. I prefer to use my hands whenever possible and pry tools only when necessary.
Sometimes you have to improvise and look for areas where you can grab things with your fingers. I pulled the rear vents off with my fingers, that was easy and all you have to do is disconnect some wiring after you pull it off. On the center console, you should be able to grab around the shifter area and pull it up without using pry tools according to this DIY. If you didn't have I-drive, you could pull up on that pocket that replaces the knob. But people have found different ways of doing it if you search on e90post for keywords remove center console.
03-21-2009, 05:14 PM | #6 |
Rep 5,483
Ok, I had the center console remove - (front and back)
I took the 2 pieces plus the 2 ash trays or coin holders or whatever you want to call them to my upholstery guy who will be wrapping it. We have an issue...In order to wrap the door that open and close on the ashtray covers, he has to take the door off. Can anyone confirm whether it will come of or not ? BMW told me there is no way to remove the door because it is basically on a hinge that opens n closes. Anyone?
Current:
03-21-2009, 07:23 PM | #7 | |
Rep 5,124
It seems that you've already removed the ashtray from the console, so just pry the trim from the top ashtray door. Once it is upholstered you can just pop it back on.
03-06-2012, 03:04 AM | #8 | |
Rep 2
many thanks |
