      10-07-2009, 03:44 PM   #1
tkbr0wn
Drives: 2015 Cayman S
Gas Station / Octane / HPFP Questions (First Results Posted)
I know everyone is sick of the HPFP polls, but here is another one. I searched and didnt see anything like it so I figured I would give it a shot. If it has already been done, then I apologize in advance.
Rather than trying to do formal poll with 38 options, I would like to get an idea on the gas stations / octane levels / State that the people with failed HPFP are using. If you can respond with the following, then I will do the data crunching and try to come up with some meaningful data if there is a pattern. If you use multiple gas stations, list them all.
UPDATED....
Here is a link to the data. The format is pretty rough now, Ill try to clean it up as I go...
http://spreadsheets.google.com/pub?k...sQ&output=html
Example:
HPFP FAIL (8000 miles) (11/15/2008) (failure mileage and date)
Model Year 2008
Chevron / 93 / Georgia
Wal-Mart / 93 / Georgia
Refill Level (1/8) (e.g 1/8, 1/4, 1/2, EMPTY)
Or:
HPFP NO FAIL (15000 miles)
Model Year 2009
BP / 93 / Florida
(1/4)
● 2015 Cayman S (Current), 2011 1M BSM #297 (Sold), 2008 135i (Sold) ●
      10-07-2009, 03:54 PM   #2
vitig
Drives: 135i
My car had any long cranks(aprox 5 seg) and i think in a hpfp error.
I go to the service,but my dealer said me that this problem don´t stay in europe because we use 98 octanes fuel and this problem only pass in place that use a low octanes.
Is it real?.
135ijb3, h & r filter, SSK, CDV,clutch stop, klracing fmic,seccond catted ,225-255 michelin ps3, E93F-E92R swaybars.M3 parts front.M3 tension rear.Plates mod(F-2,0º R-1,5º).Bilstein + stock springs.Ps rotors.Subframe bushings.Weichers fstruut.Finally mods sdiff and raceland dp.
      10-07-2009, 03:55 PM   #3
miro2296
miro2296's Avatar
Drives: '08 Montego Blue BMW 135i
NO FAIL HPFP (16K) Shell, Chevron, HEB/93/Texas
but had "A" long crank about 1 week ago though
BMW 135i/6 Speed/Montego Blue/Formula One Ceramic Tint/JB4 G4/AA Sport Intercooler/19 inch Iconz 880Z(19X8.5 & 19X10)/PSS 225/35 & 265/30/E93 M3 front sway bar/TRW front and rear Control Arms/BMS Drop In Filter/Dinan Exhaust/BlackLines/Upgraded \\\M RSFB
      10-07-2009, 03:58 PM   #4
tkbr0wn
Ill let this go for a couple of weeks and throw it all into a database and see if anything magical comes out. I know it will be a relatively minuscule data set, but its a start.
here is my data....
Model Year 2008
QuickTrip / 93 / Georgia
Shell / 93 / Georgia
(EMPTY)
      10-07-2009, 04:01 PM   #5
AW135*Guy
AW135*Guy's Avatar
Drives: AW 135i
I'll respond when we get it back from the shop with the "official" response.
BMW 135i ● AW ● Black Boston ● GS Trim ● M Sport ● Premium ● Cold Weather ● CA ● Nav ● Smart Phone ● Sat Radio
Ordered (6/17) ● Production (6/19) ● Completed (6/26) ● En Route (7/14) ● Prep Center (8/2) ● At BMW Center (8/3) ● PCD (8/14)
      10-07-2009, 04:11 PM   #6
JN2009
Drives: 135i
I have a question.Who in all the people it have this problem wait the low fuel
alert before goes to fill up ? I suspect many people run on empty tank.
      10-07-2009, 04:20 PM   #7
tkbr0wn
Good question, I often drive it down to --- miles to empty
Updated first post to ask for this info as well
      10-07-2009, 04:26 PM   #8
AW135*Guy
AW135*Guy's Avatar
Drives: AW 135i
Well, since they just called and said the two long cranks and SES light were flukes...here is my response:
HPFP NO FAIL (3000 miles)
Model Year 2009
Murphy Oil/ 93 / Georgia
(Empty)
      10-07-2009, 04:26 PM   #9
HPFREAK
Drives: C6 ZO6
I do my best not to let it get down too low before filling up. Just a habit from cars way back that you would burn the fuel pumps up if you ran it too low since they were in tank and not gravity feed types like in every FI mustang from 85 up. they sit in a Hat bolted to the top of the tanks with a pickup and filter at the bottom but it never really reaches all the way to bottom of the tank so sucking air is possible and burning the pump.
My Youtube Channel
      10-07-2009, 04:27 PM   #10
jeremyc74
Drives: '08 135i Montego/Terra
HPFP NO FAIL (35,000 miles)
Model Year: 2008
Tune: JB3 on Map 7 (For the last 25k miles)
Sams Club / 93 / Indiana (Ethonal Capitol of the country)
Whatever is close by / 91-93 / Indiana
I run it bone dry on every single tank, and have since it was new.
      10-07-2009, 06:11 PM   #11
stevenc
Coming Soon
Drives: 2015 BMW M4 Alphine White MT
Is it real?.
98 octane in europe = 93 octane in usa. Europe calculates octane differently, so your gas is the same octane as our gas.
HPFP NO FAIL (14500 miles)
2008 model
Shell / conoco / 93 / texas
1/8th tank
      10-07-2009, 08:13 PM   #12
timhatimay
timhatimay's Avatar
129
Drives: ///M3
2018 BMW M3  [0.00]
2009 135i  [0.00]
HPFP NO FAIL (6000 Miles)
2009 Model
Shell/93/NY
(1/8th tank)
M3 6MT SmTo/CS ZCP
135i MT JB/CR ///MSport - Gone
      10-08-2009, 04:39 AM   #13
vitig
Drives: 135i
[QUOTE = stevenc; 5993212] 98 octanos en Europa = 93 octanos en los EE.UU.. Europa calcula de manera diferente octanaje, para que su gas es el octanaje igual que nuestro gas.
Thanks, then my dealer told me a lie .They told that in europe doesn´t have any bulletin of this.
      10-08-2009, 07:08 AM   #14
NihonX
Drives: 2011 VO 1M
I do the same a lot and still no problems.
I even make my own Xylene 101 Octane mix.
(11600mi [8,000mi+ Jb3 Map 7-8])
      10-08-2009, 08:02 AM   #15
sysfailur
Drives: AW 135i
HPFP NO FAIL (5500 miles)
MY 09
(Shell / Hess / Sunoco) / 93 / PA
(1/4)
Edit: Pretty sure all PA gas uses up to 10% ethanol.
      10-08-2009, 09:44 AM   #16
vitig
Drives: 135i
hpfp changed in garanty ,i like that it is new version but i don´t know.
21800km 98octane(europe)
no codes, many long cranks(about 5sec)
      10-08-2009, 09:53 AM   #17
My135
Drives:
No HPFP problem at 21k miles. Car ran on low fuel (down to less than 10 miles range) several times and always use QT 93 Octane fuel with 10% Ethano and no problem so far, just keep the finger crossed.
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
      10-08-2009, 11:27 AM   #18
1lvr
1lvr's Avatar
Drives: 2008 135i JB+
HPFP NO FAIL (22000 Miles)
2008 Model
Shell/93/AR
Generic 93 no ethanol
(empty)
2008 135I Flavored with a tad of Juice Box - The absolute best way to get to work everyday!
      10-08-2009, 01:12 PM   #19
tkbr0wn
Good start, Keep'em coming.
      10-09-2009, 07:56 AM   #20
Feyd
Feyd's Avatar
346
Drives: a DEEZZULL
HPFP FAIL - 4,820 miles (1.10.2009)
April 2008 Build
Mobile 91 (all that was available in SoCal)
1/4
      10-09-2009, 10:07 AM   #21
adrean8j
adrean8j's Avatar
121
Drives: SGM 135I
2008 135i  [10.00]
HPFP NO FAIL (18000 miles)
Model Year 2008
Tune: ProcedeV3 Rev. II - Since about 4k miles
Shell / 93 / Georgia/SC
BP / 93 / Georgia/SC
(EMPTY)
Originally Posted by ptack View Post
SGM was God's color and has been recalled to heaven.
      10-09-2009, 10:24 AM   #22
jkp1187
Unindicted co-conspirator
Drives: to work, mostly.
MY 09
(1/4)
Aside: Per Pennsylvania law, any gas station that includes ethanol must have a sticker on the pump disclosing that fact. No sticker in Pa. should mean no ethanol, if the law is being obeyed.
As for me:
HPFP NO FAIL
May 2009 build
3800 miles
Used 95 RON in Europe ~ 600 miles
In USA, mostly 93 octane Shell. One tank with 92 octane.
Search this Thread:
