Please visit one of the specific Bimmerpost sites above
Go Back   BMW 3-Series (E90 E92) Forum > BIMMERPOST Universal Forums > General BMW News and Cars Discussion
      04-05-2010, 07:30 PM   #1
Jason
Administrator
Jason's Avatar
Drives: E90 M3
Every BMW 3-Series Has 2,500 HP... In Its Brakes
Interesting article out of Jalopnik today:
In response to Toyota's unintended acceleration debacle, BMW engineers decided to calculate the equivalent horsepower of a 3-series' brakes: roughly 2,500 HP. That's right, every 3-Series ships with more than twice the power of a Bugatti Veyron.
The engineers arrived at the 2,500 HP number after measuring the car's 60-0 MPH deceleration time (2.5 seconds), then calculating how much horsepower would be required to achieved equivalent acceleration (0-60 MPH in 2.5 seconds). This is obviously an over-simplified number that exists merely in the calculations on an engineer's note pad - the rear-wheel drive 3-series would need extensive modifications to transfer that accelerative power then send it to the ground - but it does demonstrate exactly how much more powerful the brakes are over the engine, which, in the case of this Bimmer, makes between 200 and 300 HP.
What's this mean for unintended acceleration? Even if you couldn't shift the car into neutral, even if the throttle was stuck wide open, even if you couldn't turn the engine off, you could still stop the car by using the brakes, which can easily overpower the engine.
.... rest of article at JALOPNIK
Jason is offline   United_States
      04-06-2010, 12:13 AM   #2
Saigon
Saigon's Avatar
Drives: BSM E92 335i Coupe
Send a message via AIM to Saigon Send a message via MSN to Saigon
wow very interesting, nice find!
07' Alpine White E93 335i
M-Sport | BMW Performance | Beige l Piano Black l Sport l Premium l Heated l Navi | Steptronic l Comfort Access l Logic7 l iPod & USB |
Saigon is offline   United_States
      04-06-2010, 07:35 AM   #3
kinan_sleiman2006
kinan_sleiman2006's Avatar
Drives: BMW X3
Exclamation
very interesing topic?do you think that theses brakes produce more hp to the engine than 5 series f10?
kinan_sleiman2006 is offline   Syria
      04-06-2010, 07:41 AM   #4
sworks335i
sworks335i's Avatar
Drives: 2007 E90 335i Sport
This is my point exactly!! Toyota is in a bad place with not telling the gov. but then having stupid drivers who can't drive or stop their cars making up stories and lies about how their cars go out of control.
16.4 Million dollar fine is going to help out the government though!!
sworks335i is offline   United_States
      04-06-2010, 07:51 AM   #5
GUNN IT
GUNN IT's Avatar
Drives: 2006 325i Sedan E90
Very interesting... never thought about braking HP.
GUNN IT is offline   United_States
      04-06-2010, 08:35 AM   #6
03BeastCharmer
03BeastCharmer's Avatar
Drives: 03 M5, '13, 88 & 97 M3
I think saying that Toyata drivers should just bake is an over simplified statement, as econo box cars generally don't have great tires, so only a limited amount of brake force can be applied before the tire gives up, and if the engine is still running, you have to overcome all that force just to maintain the same speed, let alone slow the car down. And you would probably very quickly cook the brake pads in a Toyota, making them useless.
That's why the key is to get the car into neutral first.
Current: '13 E92 M3 Euro Delivery 9/4
Wife's: E39 M5, E36 M3, E30 M3
Gone: E86 M Coupe
03BeastCharmer is offline   Reply With Quote
      04-06-2010, 09:07 AM   #7
E90Toad
E90Toad's Avatar
Drives: 2011 328i xDrive
Yeah, lots of help:
$1,560,000,000,000 (deficit) - 16,400,000 (fine) = 95,122 more toyota fines to go and the deficit is gone.
As for the tread, it seems that stomping on the brakes, even in a toyota, should bring the car to a stop fairly quickly. The strength of the brakes as compared to the max horsepower in the Prius, Camry Hybrid, etc. shouldn't be that much different. Each number might be lower but the ratio is probably similar even if not totally equal. The only way it seems it would not work is if the car's computer is not allowing the calipers to activate because it is using the regenerative braking or some other nonsense. It seems that in any car, if you have time to react to the acceleration and react correctly, the car should mechanically be able to stop.
2011 E90 328i xDrive |Vermillion Red
E90Toad is offline   United_States
      04-06-2010, 09:14 AM   #8
jaybird124
jaybird124's Avatar
Drives: '09 335d Sport
I'm curious how much HP they have with no vacuum assist, which is what will happen at WOT.
jaybird124 is offline   Reply With Quote
      04-06-2010, 09:27 AM   #9
jaybird124
jaybird124's Avatar
Originally Posted by E90Toad View Post
Yeah, lots of help:
That's the point that needs to be taken into consideration. The problem has been you don't have vacuum assist at WOT (on any car). Then on top of that the Toyota's were having brake fade (which could happen on a 3, especially given the mighty M3's reputation for fade on the track). It's the comedy of errors that's producing the problems.
      04-06-2010, 09:41 AM   #10
M3_CSL_E92
Drives: none atm
"but it does demonstrate exactly how much more powerful the brakes are over the engine,"
Not really, because when you accelerate, mother nature works against you.
So when braking, she´s actually "helping" you.
M3_CSL_E92 is offline   Reply With Quote
      04-06-2010, 09:46 AM   #11
Ash83
Ash83's Avatar
Drives: 05' 325i/10' 135i/10' Audi A4
Alpine White, Coral RED , Glacier Silver Aluminum trim, M sport, 6MT, NAV, HiFi, USB-iPod, Bluetooth
Ash83 is offline   United_States
      04-06-2010, 09:58 AM   #12
sworks335i
sworks335i's Avatar
Yeah, lots of help:
Agreed! But every little bit helps! Less I have to shell out to them!
If we could get the stupid politicians out of there and put a real businessman in office maybe things would be different. Politicians care too much about making everyone happy and not looking at the bottom line. i know i know, for another thread
Bottom line is that Yota should have admitted something was wrong sooner and came up with a fix instead of trying to hide it. I still think the stories in the news or BS though and don't really add up. Like the one guy who called the cops and then they could never see where he really pressed the brakes all the way down and stuff. People will do anything these days!
      04-06-2010, 10:38 AM   #13
Oulixes
Oulixes's Avatar
Drives: 330xi, 335i
Toyota is in a bad place with ... having stupid drivers.
Every company has drivers they deserve, even BMW.
Oulixes is offline   Reply With Quote
      04-06-2010, 10:39 AM   #14
cotmfk
cotmfk's Avatar
Drives: 2007 335i
Nice find. 2500 hp would be crazy!!!
cotmfk is offline   Reply With Quote
      04-06-2010, 11:21 AM   #15
Solonng
Drives: Monacco Blue 335i coupe
how can you prevent stupid people from themselves? look at the jackasses that elect the sob in office.
Solonng is offline   Reply With Quote
      04-06-2010, 12:03 PM   #16
tgxmike
tgxmike's Avatar
Drives: '09 128i Coupe, 6MT
2009 128i  [0.00]
Picked up one of the car magazines (I forget which one as I did not buy it) this week. The preformed a WOT braking test.... and 1/2 of the cars in there test will release the throttle automatically if both the brake and gas are pressed simultaneously. Meaning even if the pedal (or some internal part) is stuck at WOT the car will automatically cut the throttle when you apply the brakes.
Cars that don’t have this feature typically had ~20-40ft longer stopping distances… so not a big problem unless you panic.
Also the family sedans they tested had 500ish Braking horsepower.... so go BMW!!
tgxmike is offline   United_States
      04-06-2010, 12:16 PM   #17
Oulixes
Oulixes's Avatar
Drives: 330xi, 335i
This is an interesting calculation, quite simple, too. It confirms the results of the tests number of people have done on tracks. Thanks for posting it and more power to Jalopnik.
      04-06-2010, 12:18 PM   #18
CarForHire
CarForHire's Avatar
Drives: Slow in the left lane.
2007 E90 328i  [0.00]
This is a great read.
Race car driving is like sex...all men think they are good at it. - Jay Leno
CarForHire is offline   United_States
      04-06-2010, 01:02 PM   #19
BrokenVert
Extremist Opinion Fighter
BrokenVert's Avatar
Drives: Topless Electric Boogaloo
Fun test...now lets see somebody do this test with the 6pot on the 135
BrokenVert is offline   United_States
      04-06-2010, 01:48 PM   #20
mr_nelson
mr_nelson's Avatar
Drives: e92 328i & Volvo s40 2001
excuse me if my question is dumb, but if your car accelerates out of control, cant you put the stick on neutral or put the automatic gear on N before braking???
just asking.. I dont know about that toyota story
mr_nelson is offline   Canada
      04-06-2010, 02:44 PM   #21
E90 Skye
E90 Skye's Avatar
Drives: 2006 330i Jet Black
thats pretty cool actually...
2006 Jet Black 330i | Premium Package | ZF AT | LUX 4.0 | Jlevi M3 Front Bumper | CF Mtech spoiler | Gloss Black Grill | Msport wheel | Blacklines | Koni FSD + Eibach Pro-kit | BMS PBX
E90 Skye is offline   United_States
      04-06-2010, 02:51 PM   #22
Jack28
HUSTLER
Jack28's Avatar
Drives: E46 M3-E92 M3
Send a message via AIM to Jack28
Interesting Read...
E92 M3 ZCP- AW/FR w/Extended Leather) Packages: ZCP, 6MT, Fully Loaded
E46 M3 - AW/IR 6 Spd, Fully Loaded. 19'' BBS LM DBK, V-CSL C/F Bmpr, Botld, Diff, V-CSL Custum IR-CF Center Counsel, V-GTR Hood, Dixis Ti 76mm, Meisterschaft Ti Sec. 1&2, EvoSport Headers, CAI, D/A Chip, tck d/a, Alcantera Headliner with Imola Red Sttitching....
Jack28 is offline   Reply With Quote
Search this Thread:
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
