05-24-2010, 11:30 PM | #1 |
23
Rep 147
Z4M Track Brake Pad Install
What could it be?
New track pads from Porterfield! Safety first... Loosen the lugs... Here is how I remove the retaining spring clip. Compress with clamp and then pull on it. It pops right out! Compress the brake caliper piston. This makes caliper removal and installation easier. I use a socket as a spacer between the pad and clamp. Removing the caliper bolt cover (upper shown)... Loosen the upper and lower caliper bolts (upper pictured). Notice the green brake wear sensor wire. It just pulls out of the pad with your fingers. I try to grab it as close as I can to where it is clipped into the pad. Pulling out the upper caliper bolt... Pulling off the caliper... Have something to rest the caliper on. Pads removed. Looks a little corroded inside the piston! The new rear pads! They're only like this once... Notice the clip on the back of the pad that inserts in the the caliper piston. Virgin... Not for long! Reinstalling the caliper... The new front pads... Mighty! That is a beefy pad... The front pads install the same as the rears. The brake wear sensors are on the passenger rear and driver front pads only. This may not be new info, but I had fun taking the pictures! Enjoy! ------------ Last edited by mhrir; 05-27-2010 at 09:11 PM.. |
05-25-2010, 07:57 AM | #2 |
Certified Adrenaline Junkie
42
Rep 1,325
Great DIY! I'm sure this will help some people out there. I recall seeing someone asking about how to change pads. It really is a good starter DIY for people to get in touch with their car.
One thing I'd say is after you put everything back together, you might have to press the brake pedal a few times to extend the caliper before you get contact between pads and rotors. |
05-25-2010, 08:14 AM | #3 |
Rep 11,667
Nice write up!
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
05-27-2010, 07:11 PM | #4 |
Rep 1,110
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 * '14 Jeep Grand Cherokee Overland Hemi... No more snow for the M! |
08-12-2010, 09:04 PM | #5 |
Rep 2
I Not Only Would Like To Replace The Brake Pads But Also The Rotors. The Problem Is I Tried The Rear Rotors First And The It Is Stuck On There And Will Not Come Off. I Struck The Rotor (with A Rubber Mallet After I Applied A Generous Amound Of Wd4) All Around And Also The Hub With No Luck.
Is There A Tool For This Process Or Do I Need To Heat It With A Torch? Are The Front Rotors Just As Difficult? Is There A Different Procedure For Those? Help???? |
08-13-2010, 10:32 AM | #6 | |
Rep 666
Drives: 2023 Hyundai IONIQ 6 SEL AWD
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
08-13-2010, 11:30 AM | #7 |
Rep 331
I've never had luck with a rubber mallet. Assuming all is clear (parking break, etc), use a small sledgehammer (about 5lbs) for stuck rotors.
Make sure your car is standing securely on jack stands. |
03-08-2011, 10:39 AM | #8 |
Rep 13
Also, before you replace your rotors spray white lithium grease onto the hub and backside of the new rotor mounting holes. This should keep rust, dirt and other grime from creating an unbreakable seal. I did it on my 350Z, and never had another problem trying to remove rotors.
WTB: E86 M coupe. E-mail me e.goodwin@live.com
10-09-2012, 07:29 PM | #11 |
M = Midlife Crisis
65
Rep 2,006
No.
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM |
10-09-2012, 07:54 PM | #12 | |
Rep 11,667
....otherwise no
10-11-2012, 03:26 AM | #14 |
Rep 49
thanks for the info guys. my pads were worn out but the sensors didnt even fulfill its duty, nothing showed up in the panel lol
07 mcoupe ///M
06-23-2014, 08:48 PM | #16 | |
Rep 413
Drives: Z4 3.0, CLS63 AMG
Normally I'd tie off the sensors too, but I plan to sell the car within the next couple years, so I'll keep everything proper for the next owner On a side note - In terms of resale, how bad is it that I've done ALL of the maintenance on the vehicle myself and the car hasn't been to the dealership in 7+ years? I may have a receipt for oil here and there, otherwise no documents. I figure it's only worth $15k at this point, so I might as well hang onto her
2005 BMW Z4 Roadster 3.0 - Black Sapphire with Red Extended Leather / NAV / Premium & Sport Pkgs / 19" wheels / M steering wheel / Xenon
2013 Mercedes CLS63 AMG |
08-05-2014, 02:46 PM | #17 |
I did this to myself.
Rep 10
Proof is in the pudding. Personally, I've spent a fair bit of money at the dealership on simple things. Once I realized how much, I started to do more maintenance myself, so I can appreciate the choice of DIYing all the work. Plus, occasionally dealerships do a shoddy job or take shortcuts because of time and cost constraints - I've been a victim of this several times, and getting them to fix their mistakes is an inconvenience. If you keep everything in working order and your car drives like it's been well-maintained, then you shouldn't have a problem when you go to sell it.
09-16-2014, 10:57 PM | #18 |
19
Rep 196
nice write up. the raybestos bite and lack of fade is amazing! even compared to full pfc 01 . I wish they did rears for us at a good price.
don't forget your high temp silicone lubricant for the slide pins, or some go for the ceramic extreme high temp lube. just don't use anti-seize.
09-16-2014, 11:31 PM | #19 |
Rep 1,530
Drives: 2008 Z4 3.0si, 2013 E92 M3 ZCP
I just got my jack and jack stands. I heard the brakes start to grind the other day. Definitely going to try changing my brakes this winter. Maybe I'll do the stop tech upgrade kit with the steel cable lines, new pads and slotted rotors.
