ZPOST
  TireRack
      10-27-2010, 08:57 PM   #1
blender
Custom User Title
blender's Avatar
Drives: black
Stopping coil slap noise
Hello All -
I'm passing along this advice/experience in the hopes that someone else may benefit from our discovery via long period of trial and error.
I had a recurring thunk/clunk coming from the left rear corner. It made a 'gronk' suspension noise that was rather loud and very annoying. Easily replicated in a quiet parking lot at 10-15mph by first loading and then unloading the left rear corner. Even a small bump would do it.
I suspected worn bushings in the Rogue RSMs; bought a new set and replaced them. Noise abated for around 50 miles then returned. Both Rogue and KW were very helpful and responsive on support questions but we could not find the cause. Plug for Rogue and KW support.
We eventually tracked the problem to the lowermost two coils of the KW spring rubbing together when loading/unloading that corner. The friction had worn through plastic factory outer sleeve (below), allowing the painted metal coils to bind/rub against one another, especially when that corner got unloaded, creating the noise. Despite being on the car only four months, the wear on the coils was visually obvious :
Attachment 448399
On a tip from KW we tried wrapping the lowest coil of that spring with a layer of electrical tape, which temporarily eliminated the noise and confirmed the source.
I finalized my fix with spiral-cut 'coil flex' cable minder, 3/8" size. Goes easily around the bottom-most coil or two and eliminates coil binding/noise. About $5.00 for ten feet at radio shack (link) or electronics /home supply store. Very easy to install/replace. The Coils cannot contact each other any more. 500+ miles so far of quiet driving
Attachment 448418
      10-27-2010, 09:02 PM   #2
GP20
95
Drives: Z4M, F80 M3, 991.2 GTS
Thanks for the info! Where did you buy it?
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      10-27-2010, 09:26 PM   #3
lstratos
Drives: Z4 3.0i
I seen those in home depot / lowes, probably electronic / wiring stores.. like for cleaning up wires for home tv & etc..
      10-28-2010, 06:56 AM   #4
inTgr8r
inTgr8r's Avatar
2426
Drives: M2 Comp
Good tip.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      10-28-2010, 08:29 AM   #5
esqu1re
esqu1re's Avatar
41
Drives: M Coupe
Will the springs chew through the coil wrap as it did the paint? How are they holding up so far?
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      10-28-2010, 08:37 AM   #6
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
love the reverse r&D on this forum....
      10-28-2010, 09:31 AM   #7
nickpapa
nickpapa's Avatar
23
Drives: Z4 3.0
believe it or not, this comes stock on a lot of cars. i've especially seen it when changing the suspension on japanese cars. it is very common
      07-22-2015, 10:07 AM   #8
vokramm
Drives: 2007 Z4 3.0i auto
I have exactly the same sound coming from the left rear. Thanks for the tip! Is it specific to KW suspension?
coil, noise, springs
zpost
