BMW X3 Forum
BMW X3 Forum
      10-04-2011, 09:38 AM   #1
walendvay
52
Drives: '11 F25 28i; '13 E84 35i
Reboot sequence for iDrive
Hold the volume-mute button for longer than 25sec. You get the BMW splash screen and she reboots!
Just in case anyone feels they need it.
      10-04-2011, 10:16 AM   #2
colson79
Drives: 2012 X3 35i DSB
good to know, just in case.
      10-04-2011, 11:34 AM   #3
sfax
sfax's Avatar
91
Drives: BMW X3 2011 F25
How much longer?
F25 xDrive20d SE __ professional multimedia package | dynamic package | climate package | 309s | xline | xenons | electric seats | folding mirrors | business speakers
      10-04-2011, 05:07 PM   #4
walendvay
52
Originally Posted by sfax View Post
How much longer?
hold it until you see it reboot.
      10-05-2011, 12:43 AM   #5
sfax
sfax's Avatar
91
Thanks. My sense of humour again...
      10-05-2011, 12:56 AM   #6
sard
Drives: 2008 M3
Speaking of the volume button, not to thread jack, but does anyone else think it takes too many twists of the knob to turn the volume up?
E92 M3 - DCT - 20" BBS LM-R - KW Clubsport - Akrapovic Exhaust - Powerchip Tune - Arkym Aero Kit - HID Halo
      10-05-2011, 01:36 AM   #7
sfax
sfax's Avatar
91
Yes. I think it's because the diameter of the knob is too small and if it required less turns it would be too sensitive to make small volume changes. Needs a bigger knob
      10-05-2011, 02:05 AM   #8
JordanWindebank
Drives: X3 xDrive 20d (2011)
Haha yes! This bugged me from the day I got my car, felt like I had to turn the knob 293 times just to slightly adjust the volume. Thank god for the steering wheel controls.
      10-05-2011, 06:48 AM   #9
Babbage
Drives: X3 2011
Yes. The amount of volume increase per knob rotation should be a user adjustable setting in iDrive. This would fix the problem.
      10-05-2011, 07:07 AM   #10
tank531
Deckhand
tank531's Avatar
Drives: F25 2.0D SE xDrive (Sep 11)
Me too - I thought it was one of the marketing tricks from BMW and if you paid top dollar for one of the two higher spec sound systems this bug was fixed?
      10-05-2011, 07:59 AM   #11
Harplayr
Drives: 2011 BMW X3 28i, F25
I usually use the steering wheel button for volume changes.
      10-05-2011, 08:10 AM   #12
walendvay
52
yes, lots of turns of the volume and lots of presses of the steering wheel button. a little annoying.
      10-05-2011, 08:11 AM   #13
Rodion
Finland
27
Drives: X3 (F25)
Actually, according to simple math, bigger knob would make it even worse. At least how much does the outer rim of the knob move in distance compared to how much volume changes.
What it needs is smaller knob or longer "ratio" inside, sort of highway gear after the knob and before the potentiometer.
      10-05-2011, 09:16 AM   #14
Lotus7
Drives: xxxx
The knob actually turns a shaft encoder. Analog potentiometers are so "twentieth century" and are going the way of the dinosaurs. Unfortunately, the encoder to volume change ratio programming is probably embedded in the radio firmware and is not likely something we'll see changed in a system software update.
Clearly, the volume change via the knob is way too slow, although I find the change via the steering wheel buttons just right.
At least shaft encoders don't go noisy and crackly when they get old like “pots”. (and some people)
      10-05-2011, 09:22 AM   #15
sfax
sfax's Avatar
91
Without wishing to labour the point (I'm about to) my point is that the reason the knob requires so much turning is because its small diameter would not promote small granular changes to the volume.
If it were larger diameter, they could allow one full rotation from 0 to max and it would still be granular enough to allow small changes at the same time.
One rotation from 0 to max on a small diameter knob would not be granular enough and that is the problem and I guess why it behaves like it does. If they changed it to one rotation and kept the size the same people would complain they couldn't turn the volume up gently.
Look at any decent amp: big volume knob, 0 to max, about one rotation
      10-05-2011, 11:05 AM   #16
Harplayr
I agree that the volume buttons on the steering wheel are calibrated better. It’s also more convenient to use them rather than reaching over to twist the knob.
I also think we’re getting a little excessively nit-picky if the number of rotations on the volume control knob is becoming a big issue.
      10-05-2011, 11:48 AM   #17
Babbage
Drives: X3 2011
Fair enough. In my car, I've got much bigger things to worry about, like a rattling sound when starting in the morning, and a massive intermittent electronics failure (due to transfer case???).
At least I'm happy that my laggy throttle seems to have been fixed by a software update.
xbimmers
