BMW X3 Forum
BMW X3 Forum
      10-16-2011, 03:15 PM   #1
TreeSkier
Drives: 2022 X5 45e
Traction Control in Snow
On a recent trip I went through some slushy/snowy conditions on steep curvy mountain roads in my my X3 35i and it handled great. Snow depth was only 3 to 6 inches average at 11000 ft elevation. I wasn't sure if I should leave the Traction Control (Push DSC button) setting on full timein these conditions as I was in steep windy moutain roads with poor visibility and didn't want to fishtail around corners or loose steering control, so I turned it on and off depending if I needed more traction (slippery or uphill) or wanted more stability (sharper corners or downhill ). I definitely noticed more traction with the Traction Control on and wanted to leave it on full time but didn't want to play around with the contorl limits with Traction either on or off, in dark, blizzard like conditions. Any thoughts or experience?
      10-16-2011, 03:23 PM   #2
mbell
Drives: 2012 BMW X1 2.8
traction control should be left on at all times - especially in winter conditions as you describe. There is no advantage to having it off, unless your on a track.
      10-16-2011, 03:44 PM   #3
xDrive35i
xDrive35i's Avatar
Drives: Porsche Macan S
Activating DTC (pressing button on driving control panel next to the gear shift lever, turning off regular Traction Control) is actually recommended when driving in snow, dirt, or mud. What results is greater traction and more variable power application but less driving stability.
      10-16-2011, 03:45 PM   #4
xDrive35i
xDrive35i's Avatar
Holding the DSC button on the driving control panel turns off everything. That should never be off unless you're on a track.
      10-16-2011, 04:25 PM   #5
Lotus7
Drives: xxxx
Pressing the DSC button once will activate what BMW calls DTC Dynamic Traction Control. Pressing it and holding it for a full 10 seconds will turn off all traction control.
The partial "de-activation" (DTC mode) may be necessary, but as BMW suggests "Use Caution". As Judd says, full de-activation is something for the track or skilled drivers. However, remember, for most of the last 100 years of automobile history, no cars had stability control, and most "sane" drivers who monitored their tire pressures and used reasonable judgment while driving did just fine. The X3 is the only vehicle (of several) I drive that has stability control, and I haven't spun or rolled a vehicle this week.
BMW suggests using that the DTC mode is useful for some severely limited traction situations like deep snow and is necessary when trying to rock the vehicle if several tires are on ice. Under severely limited conditions, as soon as the full stability control senses a little wheel spin, the system will throttle back the engine and apply the brakes. You will not move. Under those conditions, a limited amount of wheel spin MUST be allowed or you won't go anywhere.
See the Owner's manual (pp. 86 in the 2011 issue)
      10-16-2011, 10:23 PM   #6
Toecutter
Drives: rattletrap
I've never been completely clear on the function of the electronic traction devices on snow and ice...
One would want to deactivate traction control when starting from a stop in severely slippery conditions because if left on the wheels won't get power, correct?
Is it also correct that it's safer (although maybe not more fun) to leave it on after already moving on slippery roads in order to maintain forward motion in the event of wheelspin?
Once already moving, how does the function of traction control differ from that of stability control?
      10-16-2011, 10:42 PM   #7
xDrive35i
xDrive35i's Avatar
I think there's some confusion involving "ON" vs. "OFF." Let's not use those terms.
Start the car and press no buttons: all stability and traction control assists are active and in their most restrictive states.
Start the car and press the DSC button once: DSC remains active in its most restrictive state. DTC is activated, which allows for more active and dynamic power application and, in that way, greater traction on loose surfaces in certain low speed conditions (getting stuck in snow, ice, mud, etc.) where moderate wheelspin is needed. Driving stability is somewhat limited at higher speeds.
Start the car and hold the DSC button for up to 10 seconds: DTC is activated and DSC is deactivated. This provides for limited driving stability at all speeds, but greater traction on loose surfaces where momentum and moderate wheelspin are needed. However, with DSC deactivated, some of the traction advantages of DTC are undermined, readying the car for the track more than the low-speed beaten path (I advise you don't go off the beaten path in a BMW).
DTC can be activated in any Dynamic Driving Control setting (Normal and Sport), but is automatically activated when Sport+ is selected; these rules apply in D, DS, and M. Those without Dynamic Driving Control can activate DTC and deactivate DSC at any time as well.
      10-19-2011, 04:52 AM   #8
Ural
Ural's Avatar
Drives: 2011 X3 20d
What kind of tires did you have on on that trip?
      10-19-2011, 03:32 PM   #9
LEDZEP
LEDZEP's Avatar
417
Drives: 2009 E70 & 2011 F25
Ha ha... you just jinxed yourself. You'll be in a ditch with groceries all over the cabin before you know it.
Yep, I was going to point this out also. Not sure why anyone would select Sport+ in inclement weather, but this should be noted. Although, Sport+ also disables cruise control.... so that might be a good thing.
I think it is bad luck to be superstitious
      10-19-2011, 05:34 PM   #10
ctski1
ctski1's Avatar
Drives: e92 328, 2017 X1
Simple to remember - Hit the button once to light up your tires. Press and hold the button for 10 sec to do doughnuts.
      10-19-2011, 05:39 PM   #11
Toecutter
Drives: rattletrap
LOL! Simple and effective.
      10-20-2011, 11:53 PM   #12
TreeSkier
Drives: 2022 X5 45e
I have the Pirelli Cinturato P7 245/50-18. I also went on about 80 mi of dirt roads with a few mud holes. I will try to post some pics of the dirt, couldn't get pics of the snow storm as it was night time and blizzard conditions.
      10-21-2011, 12:06 AM   #13
TreeSkier
Drives: 2022 X5 45e
This is what I was referring to when I say "Traction Control (DTC)". I know you recommended leave it on, but I'm still wondering if it makes sense to leave DTC on when going down steep snowy/dirt/gravel/muddy road where you might need more stability control than traction as it's downhill, unless it helps with braking traction which probably isn' the case. I was turning DTC on only for uphill in the snow and switching back to normal, DSC mode, when going downhill or faster on flatter sections. I really didn't like having to switch modes though and would prefer to leave DTC in snow and/or dirt even at higher speeds.
      10-21-2011, 12:40 AM   #14
xDrive35i
xDrive35i's Avatar
Just as long as you know BMW recommends that you touch nothing if you have any doubts, make any decision you want. Turn on Hill Descent Control if you're worried about steep grades, but if you're going fast that won't do you any good. In terms of downhill understeer, though, it may be worth your while to touch no buttons at all so that if you find yourself coming into a loose surface blind corner too quickly, the car will bite down for you, allowing you to concentrate on driving more. The assists are to be used at your own risk, but that's only because you reserve the right to endanger yourself in the event that a driving profile were to be selected erroneously. Maybe I'm still not answering your question...
      10-21-2011, 05:32 AM   #15
Nahoa
Drives: F25 35i Mineral Silver/Black
I'd just think of it this way, DTC allows some slip. What situations do you want that?
For me, taking off on ice or slick snow where DSC is shutting everything down, but as soon as I'm rolling consistently it's back to DSC. Or, dry clean roads when I'm having a bit of fun and allowing a little slip might increase the speed I can go through some corners (not convinced I'm really going that fast with this higher vehicle, but maybe -- haven't encountered any "light side squeal", so I doubt it) or change the dynamic of a spirited take off. Maybe in sand if DSC also shuts you down, but haven't had the experience.
For me, I don't really want to introduce slip. Slip in normal driving almost always equates to loss of control, the momentum of the vehicle going off in the wrong direction, and an increased possibility that efforts to maintain path and correct that errant momentum will break grip completely and result in a bad situation. Going downhill over unstable terrain would be the last time/place I'd use DTC. I'd rather the car take a conservative approach to the point of shutting me down and bringing me to a stop. Then, in that unstable of a situation, I'd give the hill descent a try. I wouldn't switch to DTC, telling the car to let me slip because that would increase the chance of me slipping out of control.
To the best of my understanding, DTC doesn't "add" anything, it only loosens boundaries on allowable loss of traction. So, switching to this mode would not increase "stability control" -- though I'm not quite certain what stability control means to you. Stability of a vehicle is kind of a broad term that could encompass a whole lot of things.
DSC does help with braking because it works to keep all wheels in traction -- an essential condition for braking.
As indicated above, it's turning off (or down) a very effective safety system. Gotta have a really specific reason and/or be in a very safe circumstance.
I would be interested to hear if anyone has come across information indicating whether or not the vehicle is more, less, or equally effective with regard to DSC with DHP suspension set to Sport or Normal. For example, over uneven surfaces (wet potholes or ruts, or rough snow and ice, say) and not in a performance driving circumstance, is one or the other better and keeping the wheels down on the surface and in traction?
      10-21-2011, 11:55 PM   #16
TreeSkier
Drives: 2022 X5 45e
I guess the consensus is to keep DSC on unless additional traction is needed in the situations where additional traction is needed for snow/icy/muddy spots.
I did use the Hill Decent Control quite a bit but it was not all that practical. Every time you turn it on, it defaults to 5 MPH and it maxed out at 16 MPH. So you had to slow way down to enable it smoothly and then max out the speed to 16 using the speed control button. In many situations I would have like it to go up to 20 or 25 MPH.
Here's some PICs from the trip:
http://flickr.com/gp/9525655@N06/6w3057/
      10-22-2011, 12:02 AM   #17
Toecutter
Drives: rattletrap
FINALLY a pic of an X3 with dirt and mud on it! I was beginning to think they were allergic.
      02-17-2015, 09:39 AM   #18
nyalpine90
nyalpine90's Avatar
7419
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
i was unclear what DTC does or when to press the button
      02-17-2015, 12:15 PM   #19
exon
25
Drives: 2014 X3 35i Jet Black!
DSC on => drive normally, almost no slip. recommended once you get up to speed.
Press once => DTC on => allows some wheel slip for better traction and controlled drift on snow (if you are into that kind of thing).
Long press => DSC off => doughnut time......
      02-17-2015, 01:32 PM   #20
Tjalle
Drives: X4 35i
Law of physics:
-maximium friction (grip) is at about 15 % slip.
-at low speeds one needs a "delta" speed to get grip in snow.
Very good traction control systems =SAAB, has delta speed as a criterium - obviously BMW has not learned that lesson, hence the DTC.
Even with DTC, there is a stability control that is sufficient for most drivers/occasions.
If uncertain - don`t engage DTC.
The most fun you can have with your car is driving on an ice track - preferrably with studded tires
      02-17-2015, 01:39 PM   #21
nyalpine90
nyalpine90's Avatar
7419
2016 BMW X4  [9.33]
tires can also be factor in snow traction winter vs all seasons.
i did notice LS2 tires on 2015 x3 are not as good as Duelers that came in my 2012 x3.
i had no problem with Duelers bridgestones going thru snow. Today with LS2 i fishtail few times smh.
      02-19-2015, 11:06 AM   #22
lawfarm
Drives: 2011 BMW X3 xDrive35i
The comment that DTC should never be used once rolling on the road would apply if you have no vehicle handling ability.
I leave the vehicle in DSC (all TC on) when driving at higher speeds in slippery conditions. But if I'm driving around town, or driving in deep snow, I leave the system in DTC (one press). In those conditions, I'm not exceeding 30mph, and I am responsible for vehicle control. I find the X3 to be a lot more predictable in handling in DTC...there aren't circumstances where the brakes suddenly kick in and pitch the car around. The car slides predictably and progressively, and vehicle control is improved. You can steer with the wheel, the brakes and the gas. If you're a competent driver who understands vehicle control, driving under 30mph, I think you'll find DTC to be more effective (and more comfortable) under those circumstances.
I use TC off for my rally driver moments, on closed roads.
Search this Thread:
xbimmers
