ZPOST
  TireRack
      08-24-2007, 01:35 PM   #1
mister_roger
mister_roger's Avatar
13
Drives: 2003 Maldives Blue 2.5i
Front Bumper Removal - DIY by mister_roger
In my recent project of converting my standard Z4 bumper to a Z4M front bumper, I decided it would be good time to also create a new DIY for removing the front bumper. The old DIY (http://www.zpost.com/forums/showthread.php?t=63034), as descriptive as it may be, has dead links to its pictures.
So with intention to provide our community with a new resource, here is my writeup for a standard Z4 front bumper removal:
Overview:
First you need to understand how the front bumper is attached to the body. It is held on by 7 hex screws along the top edge in the engine compartment, 4 expanding tabs along each fenderwell, and 7 8mm screws along the underside of the front bumper edge. The sides of the bumper snap into place where it meets with the fender.
Tools required:
-Screwdriver with hex bits -or- allen wrench crank tool from BMW tool kit.
-Tiny screwdriver (size of a toothpick)
-8mm socket or wrench
-confidence
Step 1:
Start by removing the expanding tabs along each fenderwell. These tabs function by having a small plastic rod become inserted down the middle, causing the tab to expand and lock in place. To remove these tabs, take the tiny screwdrive and PUSH the rods all the way in until you hear them fall. Don't worry, you'll be able to recover them when the bumper is removed.
Now it's loose
Remove the 7 remaining tabs from both fender wells in the same manner.
Step 2:
Remove the 7 8mm screws/bolts along the underside of the front bumper. These are pretty straightforward.
Step 3:
Pull off the sides of the bumper where it meets the fender. You may have to give it some force, but after some firm pulls and it should eventually pop off.
Step 4:
Remove the 7 hex screws along the top edge of the front bumper. This should be done last, because these 7 screws are all that's holding your bumper in place at this point. Using your Screwdriver with hex bit, simply remove the screws. Watch out, they may be a little tight.
OPTION 2: If you do not have a hex screwdriver handy (like i did), I discovered that this allen-wrench crank tool thingy from the supplied emercency tool kit actually fits into the hex screws. It's not intended for this use though, because you run the risk of stripping out the allen head when it turns against the teeth in the hex screw. But as long as you're careful and don't overdo it, this tool should be able to get these screws out. This tool is made from pretty strong metal.
Step 5:
With all the screws and hardware removed, gently pull the bumper forward a bit and disconnect the fog light harnesses (if you have fog lights). The bumper should now pull completely forward and is no longer attached to the body.
Make sure you save this piece as well, which runs along the top edge where the hex screws were.
With the bumper removed, you should see the 4 expanding tab pins that dropped. Save them for use later.
Reinstalling the bumper is the exact same process in reverse order. The expanding tabs are placed in their holes, and the pins inserted afterwards to lock them into place.
And that is how it's done.
Best,
-Roger
2003 Maldives Blue 2.5i -- 18" M6 wheels, 12mm rear spacer, ///MZ4 front bumper conversion, Eibach lowering springs, Koni shocks, Hotchkis F/R anti-roll bars, Helene Performance air filter.
      10-18-2007, 01:00 PM   #2
ElicitZ4
Drives: Z4
Thank you! I was wondering what i needed to do! You're awesome!
      03-31-2008, 06:24 PM   #3
dekaliber
Drives: '07 Z4MC, '11 JCW, '18 Z06
Can anybody confirm if those expanding tabs are PN: 51118174185? (#3 in this diagram: http://www.realoem.com/bmw/showparts...51&hg=51&fg=70)
I don't want to remove the bumper, but I'm interested in getting under there to replace the front reflectors, and I was curious if I could just get a set of replacement tabs instead of taking off the bumper and recovering the pins.
      03-31-2008, 06:57 PM   #4
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
you might be able to reach in through the fog light pass way in the fender lining and grab them since it looks like they fall in the same general area.
From the realoem.com schematics it looks like #3 is what you're looking for. Looks like it comes with the pin and the expanding rivet
      03-31-2008, 07:09 PM   #5
epbrown
epbrown's Avatar
Drives: BMW M Coupe, Porsche Boxster S
At www.bavauto.com, they list PN 51 11 1 944 537 and sell them for 95 cents each. They're listed in the Z4 bumper section as "expanding rivet."
      03-31-2008, 09:03 PM   #6
em2b96p
15
Drives: cbr600rr
how about a picture of the bumper removed and out of the way? i would like to see what it looks like behind there!
      03-31-2008, 09:22 PM   #7
Chuck I
Chuck I's Avatar
Drives: '03 Z4 + '07 ///M Roadster
Here's mine without the bumper
Here you go... I was prepping for my Aero bumper...
      03-31-2008, 10:07 PM   #8
dekaliber
Thanks for the help guys! (Now to actually get a set of these...)
      04-01-2008, 09:28 AM   #9
Reach
gone baby gone
382
Drives: 2016 F80
slightly off topic... anyone have a part # for the circle reflectors in the 04/05 bumpers?
      06-24-2008, 06:43 PM   #10
goldguilexx
goldguilexx's Avatar
38
Drives: mini
great guide to removing the front bumper, did it today to test fit my M front bumper, great fit and so easy to do!!
      06-24-2008, 06:59 PM   #11
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Nice write up. Color and bumper still look great!!!
      12-17-2009, 08:14 PM   #12
Car 5
Drives: 2005 BMW Z4 3.0
These pictures help, after reading your post I was able to remove my bumper in minutes. Thanks Car 5
      05-03-2011, 01:46 PM   #13
Z4Coopster
Drives: 2007 z4 3.0si Coupe
I am in need of "re-aligning the" front bumper , i bought the car used
and i noticed later that the top left side has a larger gap than the right. (where the bumper meets the hood) Im hoping its just not centered correctly and not actually damaged in some way.
is there a certain order to tighten them when you reinstall the top bolts?
I read somewhere (maybe the splitter diy post) theres some "play" on the top bolts where you can actually adjust the alignment , so Im hoping just loosening up the top bolts and trying to re-tighten them in a certain way would be easier than pulling off the entire bumper .
      05-03-2011, 09:17 PM   #14
JFleming
Drives: '10 328i xdrive, '07 Z4 3.0si
Front Bumper
I just installed the bumper on my 07, and yes there was enough clearance in the holes to allow for some adjustment of the gap between the hood and bumper. I just installed the bumper, then SLOWLY and carfully lowered the hood to observe the gap. Mine was good on the left, but I needed to decrease the gap on the right. I just loosened the right side bolts, pushed the bumper in a bit then retightened them. The gap is perfect now.
      02-20-2012, 01:12 AM   #15
OwensMcoupe
14
Drives: Z4 M coupe
Great post thanks a bunch. I will have to do this to adjust the gap around my headlights I think?
      02-26-2012, 11:26 PM   #16
BMW Maniac
Drives: Former Z4M coupe owner
How do the headlight washers come into play? The cap is connected to the pump itself.
1997 /// M3 Coupe Arctic Silver CES STAGE IV (651rwhp/615rwtq)
1999 /// M3 Convertible Techno Violet
      02-26-2012, 11:43 PM   #17
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Clamp the line going to them, and remove them near the nozzles. Its a simple clip
      12-01-2012, 11:06 AM   #18
drbvac
drbvac's Avatar
23
Drives: 2006 BMW M COUPE
Not sure if only in Canada or ?
The "plastic rivets that hold the front bumper on my 06M are not the same as those shown in this write up or in the ESS instructions. They don't push in and are made like zip ties -they go in and then you pull up on the pin and cut it off.
There are lots similar around 0 you can get 35 from CHina on E-bay for 3 bucks - make sure the diameter of the pin and the top are roughly the same as well as the length that the "rivet" goes through what you are attaching.
      12-01-2012, 11:19 AM   #19
inTgr8r
inTgr8r's Avatar
2426
Drives: M2 Comp
^ I have seen a few different types used.
My 06 had the nail type pins but I think there was a production change at some point.
My 07 has the other type.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      12-01-2012, 05:36 PM   #20
Incompatible
Drives: 07 AW Z4C 3.0Si
My 5/07 production had the crush body/break off shaft type rivets. Parts manual shows other reusable type.
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
      03-18-2013, 10:01 AM   #21
Rekla
Hug the road... Carpe Asphalt
Rekla's Avatar
Drives: 2007 ///M Coupe
I'm struggling with step 3... Do you just pull the front bumper top edge out to the side or down or a combination? The attachement bracket between the fender and bumper seems to stay with the fender, not the bumper?
2007 BMW ///M Coupe
      03-18-2013, 10:12 AM   #22
3002 tii
3002 tii's Avatar
2282
Drives: Z4 M, X5, GX460
DO NOT PULL THE BRACKET. The bracket is meant to stay on and if you PULL It, it will BREAK and you can't reuse
Hold UNDERNEATH the bracket and grab BUMPER ONLY. Click on link below, Shipkiller shows where you should be grabbing:
http://www.zpost.com/forums/showpost...&postcount=450
Follow for latest mods
zpost
