320d (177) Tuning?
02-14-2008, 09:50 AM | #23 |
Rep 409
02-14-2008, 11:19 AM | #24 | |
The Tarmac Terrorist
957
Rep 29,345
Drives: 997.2 GT3
It will work, but its in my opinion not the best way of tuning. It tricks the ECU into thinking the fuel pump is not working as efficiently as it could and turns up the fuel pressure. This will give you more HP and also a potentially ticking time bomb with the Fuel pump. Long term issues i am unsure, maybe borewash due to increase fuel flow from the tuning box. A re-map is programmed thoughout the rev range under different loads makign sure the cars is running its correct amount of fuel for the conditions.
997.2 GT3
02-14-2008, 11:48 AM | #25 |
Rep 686
Drives: E93 320d M Sport, E81 116d SE
Garage List 2006 120d SE [0.00]
2007 335d A M Sport [0.00] 1998 M3 Evo [0.00] 2002 330d Sport [0.00] 2004 330d Sport [0.00] |
Carl
You can't get borewash with diesel fuel, it's got far too much lubrication properties unlike petrol. Remember all the stories about petrol knackering diesel fuel pumps. Regards Chris
Previously: 2007 335D MSport E90 Le Mans Blue, 2004 330D A Sport Silver Grey, 2002 330D A Sport Saphire Black, 2001 320D SE Touring Titanium Silver, 1998 M3 Evo Techno Violet, 1996 328i Sport Montreal Blue, 1994 325i Coupe Red, 1989 325i Sport 2 door Dolphin Grey,1986 325i SE 4 door Lachs
02-14-2008, 11:53 AM | #26 |
957
Rep 29,345
Drives: 997.2 GT3
Oh right, im sorry.. Remember i used to petrol turbo engines, old skool ones at that.
Surely the over-fueling the diesel lump will also lead to premature catalsyst failure etc?
997.2 GT3
02-14-2008, 12:22 PM | #27 |
Rep 686
What you have to remember Carl is diesel engines are limited by the amount of fuel they can consume whereas petrol engines are limited by the amount of air they can consume. Putting more fuel into a diesel (by one means or another) is the only way to make more power.
Youv'e obviously never seen a diesel running on it's sump oil, scarry stuff! The particle filters and catylysts will be rated to operate over a range. If you subject it to conditions outside of it's design parameters then there will be the possibility of premature failure as with all things. Regards Chris
02-14-2008, 01:30 PM | #28 | |
Rep 85
il give a more in depth reviwe when it arrives should have been today but it dint come, should be tomoz or sat. The one i stated is from the company who tuned the Astra 888 and T9
320d, h&r springs,10mm spacers,schnitzer pedals,black grilles,6 pot fronts & 4 pot rears. |
02-14-2008, 02:46 PM | #29 | |
Rep 409
So a remap is a more correct way of tuning an engine right? The only advantages with a box is that you can unplug it before taking the car to service and that you donīt run the risk of the extra power being wiped out if the ECU should be reprogrammed? |
02-14-2008, 03:12 PM | #30 |
Rep 413
Drives: a sexy 325i
all this talk of remapping and tuning is definitely very interesting! But I fear that there may be the same issues with re-mapping a 325i (arriving March) as a 320i, i.e. not significant performance increase for the price!
What are the other physical ways of tuning the car? Like a air intakes (Gruppe M), or exhausts? It seems that this 'physical' tuning is much more popular in the US. What would everyone recommend, besides software modifications?? TSL |
02-14-2008, 03:43 PM | #31 | |
Rep 427
As far as I can make out, a tuning box can only alter the amount of fuel and the timing of the fuel injection. Unlike a remap, it cannot change the fuel pressure. So from your thoughts Carlosmatey, the remap is going to give the ticking time bomb with the fuel pump. Tuning box cannot do this. As for over fueling, both methods increase the fuel at given times to achieve the extra HP. Unless someone knows different...... Sh*t. Late for another appointment. Watch has stopped ticking. OMG. Where IS that ticking sound coming from? |
02-14-2008, 04:37 PM | #32 | |
Rep 95
Pls. keep me updated. We have the same car and I am very interested in a tuning box for an easy installation and uninstallation before service etc.
E92, M-Sport, Sapphire Black |
02-15-2008, 12:27 PM | #33 |
Rep 427
I've tried a Tunit.
It takes a while longer than 10mins to fit though. More like 20-30. Some pesky engine cover retaining screws are in an awkward position. Results are well worth the effort, and completely removeable when you want to. Unlike a remap. |
02-15-2008, 02:54 PM | #34 | |
Rep 56
It can shorten the life of the pump due to the higher pressure and the injectors can fail due to the higher pressure at the back on the injectors. A remap, depending who written the mapping does NOT increase fuel rail pressure, more fuel is injected by opening the injectors longer and more advance on the injection timing. Hope that helps |
02-15-2008, 06:29 PM | #35 |
Rep 427
It's obviously not a simple subject.
Looking at this link, they explicitly state the box does not increase pressure. http://www.tuningbox.com/ANG/p4ang.php There's a lot of processing goes on in a tuning box. Hence the 'high' cost. There's a lot it can't do, as you say, turbo pressure, torque limiters, top speed limiter.... But, I can understand that intercepting the pressure signal can have an effect on the injection time, if the signal feedback is not [just] changed in amplitude, but time displaced. Yes, it's fooling the ecu. However, if it were just effectively reducing the signal, would it cost Ģ300+. Probably not. Details on how it works seem a bit vague but, lets see what else turns up..... |
02-16-2008, 04:21 AM | #36 |
957
Rep 29,345
Drives: 997.2 GT3
Id like to see one on a 335d.
997.2 GT3
02-16-2008, 05:20 PM | #37 | |
Rep 56
The link below is a picture of the fuel rail and components on a 335d, item 3 is where the tunit box connects into, fuel rail pressure sensor. http://www.realoem.com/bmw/showparts...50&hg=13&fg=15 |
02-19-2008, 04:21 PM | #38 | |
Rep 95
Have you recieved your tuningbox and tested it ? I am very curious about how it works ?
02-20-2008, 05:16 AM | #39 |
Rep 62
Yeah tell us when you have tested the box.
Itīs interesting that they claim to get 218 horsepower when tuned. Most of the tuners that have a box for the 177-machine gives around 205-207 hp. I would like to see a dynotest from them. |
05-13-2008, 03:33 AM | #40 |
Rep 191
Hey guys!
I bought a P-tronic tuning box for my 320d. It should arrive in 2 or 3 days. They say that the power will increase from 177 bhp to 226 bhp, while the torque will go up from 350 to about 460 Nm. (to be honest, i wish that the power/torque increase isn't going to be that great because I'm afraid for the clutch, gear box etc. - 215 bhp with 420 is ok by me) I'll give you details, after i install the box. Cheers, Vlad |
05-13-2008, 03:57 PM | #41 |
Rep 56
Thought I would give you an update on the 177bhp 320d.
We did a remap on these last week in Germany, software reads fine via the diagnostic port and writes back into the car fine and the car runs with good power gains Still a long way to go much much more long term testing on the ECU. Next is to protect our work which is going to be much harder, if we cant then I doubt we will release it |
05-14-2008, 07:57 AM | #42 |
Right Responsible
58
Rep 1,646
Keep up the good work, and good luck
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys. |
05-14-2008, 08:25 AM | #43 | |
Rep 5,984
Nice one mate!! Give me a nod if you want a guinea pig whom you can trust and who won't cry if things go wrong. |
05-14-2008, 02:38 PM | #44 |
Rep 56
177bhp, 320d, tuning |
