03-20-2019, 02:50 PM | #45 | |
93
Rep 291
It's a lot of work keeping carbon black clean. |
03-21-2019, 02:23 PM | #49 | |
113
Rep 300
82-16-0-416-162/163 (I plan for 20" for next summer) I might still get the set for 19" wheels in the meantime.
E70 LCI 35D
Sutphin trans tune///xDelete///What EGR? |
03-21-2019, 02:58 PM | #50 | |
Rep 491
Could not find the mud flaps anywhere on ebay. Cheap chinese knockoffs did not fit. Finally ordered from the BMW dealer and got it installed by them. |
Nyc Dito112.50 |
03-21-2019, 08:45 PM | #52 |
9
Rep 40
Spent some time with my x5 today: replaced coils and spark plugs, turbo coolant lines, cabin air filter ( the one in passenger foot well), finally removed the phone cradle in the glove box and replaced it with oem cover.
03-21-2019, 09:02 PM | #53 |
Rep 1,252
Nice man, you were busy... I always hear of everyone removing their cradle, I added one back with the wireless charger.
03-22-2019, 07:05 AM | #54 |
113
Rep 300
Thanks! I changed the whole assembly. I was unsure about those online button replacements, so I just ended up getting a new OE unit.
E70 LCI 35D
03-22-2019, 07:07 AM | #55 |
113
Rep 300
I wanted to get rid of my cradle, but a wireless charger might actually be something i'd use. Which one did you get?
E70 LCI 35D
03-22-2019, 08:19 AM | #56 | |
Rep 1,252
https://www.xbimmers.com/forums/show....php?t=1455363 |
03-22-2019, 05:09 PM | #57 |
102
Rep 210
Thanks to a member here for the PNs, I purchased and swapped out the front reflectors to clear instead of amber OEM. I'm hoping to get paint matched inserts at some point, but these look good enough for now. I also swapped the iDrive control knob for a //M branded one I got on ebay. I was skeptical because it was cheap and shipped directly from China, but it looks good and honestly makes it easier to use.
I had planned on doing an oil change as well... But I didn't realize I needed an 86mm/16 flute oil filter housing wrench, so that will have to wait until next weekend. The computer doesn't recommend a change for another 10K, but I usually have run my BMWs on 5K intervals despite what the computer says.
2013 X5M
2011 X5 35D Sport Package 2002 M3 2019 i3 |
03-22-2019, 06:46 PM | #58 | |
112
Rep 357
Drives: E70 X5M
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
03-22-2019, 06:49 PM | #59 |
102
Rep 210
It feels as solid as the original. It's really just a sleeve and cover, so the original knob is still under it. I only had to remove the cap to allow the light to be transmitted up to the new cover. The biggest different in feel for me is that the larger circumference of the controller fits in my hand better and is easier to use.
2013 X5M
pdX5M111.50 |
03-23-2019, 10:43 AM | #60 |
113
Rep 300
So since I'm all about preventative maintenance, I decided to swap out the MAP sensor (35d). I have the service records and it had never been changed. Although I dont have any issues or codes, it was cheap enough for me to take care of it today..
..BUT, as sometimes things go..the lower small part of the grommet that stays inside the manifold broke off and fell inside the intake. As i was pulling out the grommet, the rubber broke in half. It might be about 1/4 inch in size over all, its just the tip. I tried to retract it for 20 minutes, and no go. I started the car, no funny noises or sounds, nothing feels weird. Hopefully I'm good until my next oil service where I will be replacing my valve cover and take another look and see if it can be found and removed(My Indy, not me).. Should I be worried?
E70 LCI 35D
03-23-2019, 11:33 AM | #61 | |
Rep 1,564
03-23-2019, 12:17 PM | #62 |
112
Rep 357
Drives: E70 X5M
Installing Active Autowerke downpipes and Velos Stage 2+ tune today. Might do the spark plugs as well if I have time. Fingers crossed for a smooth install! Buddy has a shop at his house with a lift and all so that's a huge plus
9vapors653.50 |
03-23-2019, 01:13 PM | #63 |
Rep 1,252
Downpipes are a mofo, but as you said, with a buddy and lift, that changes everything!
03-23-2019, 01:19 PM | #64 |
102
Rep 210
I found a Vorsteiner carbon valence on craigslist, picked it up and installed it this morning. The valence has a small amount of damage on it from an accident(not noticeable on my black X5M), so the owner had it replaced. He was selling it super cheap, so I decided it was worth picking up. He has a white X5M that was absolutely pristine, one of the cleanest I've seen!
2013 X5M
9vapors653.50 |
03-23-2019, 01:29 PM | #65 | |
113
Rep 300
Good luck with the install!
E70 LCI 35D
9vapors653.50 |
03-23-2019, 01:30 PM | #66 | |
113
Rep 300
E70 LCI 35D
