08-14-2023, 04:25 PM | #45 |
707
Rep 2,450
Hey there. Sorry didn’t realize you posted some questions. My motor is stock.
The Pure750 is the final version of the prototype on my car. Should have better spool and make 600whp no problem. Having said that, if you are DCT, don’t expect to get much more than 575whp. I have plenty of boost left but if I approach 600whp my car goes into limp mode with a cylinder 4, 5, or 6 misfire. But there are no actual misfires. I believe it’s something in the tune but I need MHDs help. Unfortunately they don’t have the bandwidth to assist right now so I follow up with them every few months. But my car is fast the way it sits so I am not in a huge rush. Would be nice to figure though.
09-07-2023, 04:23 PM | #46 |
Rep 18
Drives: 2013 135i
Does the stock hpfp handle this power or did you upgrade it along with the lpfp
09-07-2023, 04:45 PM | #47 |
707
Rep 2,450
Fueling mods from OP: PI spacer with 950cc injectors, AIC, Walboro 535 pump in PFS DIY bucket, E57 on dyno day.
I need to add in there the BPM4. I am early E-series N55 so there is no high-pressure fuel pump upgrade. My pump is the same as the N54. Hopefully this helps but feel free to ask any additional questions you may have.
09-08-2023, 08:48 AM | #48 | |
Rep 4,218
Mods: Yes.
09-08-2023, 09:03 AM | #49 |
707
Rep 2,450
I am not. But, I am running xHP stage 3 which supposedly removes or increases all torque limiters.
In addition, I recently paid someone overseas that has been doing custom DCT tunes before xHP even came out hoping there was something missing in xHP in terms of raised torque limiters. Still have the same issue. So this makes me think it’s not transmission related.
09-08-2023, 10:16 AM | #50 | |
Rep 717
houtan707.00 |
09-08-2023, 10:57 AM | #51 |
707
Rep 2,450
thanks wheela. i will look into how i can soften up the crank position detection.
the other thing i forgot to mention is my current tune should have all torque monitors disabled, including throwing a cel, but for whatever reason it still happens. not sure if i entered the wrong value or maybe it is not implemented correctly in the xdf or mhd. screenshot of my current setting for tq monitors.
09-11-2023, 02:09 PM | #52 |
Rep 1,125
Drives: 2015 BMW 435i Xdrive MSport
Does anyone know what the max whp this thing can put out is? Fueling is a major issue on these cars. I know ET3 just released a EKP that can run a dual pump setup. Finding a shop that can wire it in might be the tough part.... that's what I'm finding. You really need the percision raceworks stage 3 LPFP setup to maximize returns. Hobs switch is dicey.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
09-11-2023, 02:23 PM | #53 |
707
Rep 2,450
Thanks for your post. By “this thing”, are you referring to the turbo? If so, my guess is 650whp should not be an issue. By “these cars”, I am assuming you mean n55 powers cars. But are you referring to early e series, late e series, or f series n55 cars? They are slightly different and definitely do not enjoy the same tuning support. I have never heard of ET3. Any links. I have been running a BPM4 for a few years now. Not one issue. And it can control/activate multiple pumps I believe. I know it can control two lpfp for sure. Also, what fuel/ power level are you assuming when you say three pumps would be required?
09-11-2023, 05:35 PM | #54 | |
Rep 1,125
09-18-2023, 01:12 PM | #56 | |
707
Rep 2,450
I softened the knock detection tables in cyldners 4, 5, and 6, increased the misfire per bank from 420 to 800, increased the knock detection threshold for group 2 (table we got from the f series cars). Basically, my current values match or are slightly more conservative than the f series tables. This issue usually shows up in 5th, always at 5900ish rpm, which is hard to test because the speed is high. So i upped my boost to 27ish psi, so it would trigger in 4th if still present. And, it did, grrrrrrrr. codes are below. Log is on SS. https://www.s po o ls t r e et.com/graphs/log-09-17-2023-22-03-17.30147/ Anyone know any F series n55 tuners? I wonder if they make adjustments to these tables on higher hp builds.
11-14-2023, 12:53 AM | #57 |
707
Rep 2,450
Just a minor update to the original post. Been working on figuring out the misfire issue at 600 whp with friends and forum members and we figured out a way to completely disable misfire detection. Tried it out and it worked, allowing me to run 26-27 psi. Car is a lot faster and ran a great 100-200 time which I added to the original post as well as here:
Andrewbens25.50 |
04-25-2024, 08:58 PM | #58 |
707
Rep 2,450
Updated the original post. Been working on the tune and the old girl is still picking up some speed. Still full weight, still on street tires (kumho v730)
100-200kmh 60-130
n55, ps3, pure stage 3, stage 3 |
