N54 Dyno Chart Compilation
12-10-2010, 10:28 PM | #45 |
This is it!!
16
Rep 672
The last time i ran this with the AMS FMIC, its was 370-380. I dont think the IC made up 60 hp. I sold my IC to my buddy.
DFW, TX. Current: 08' Cayenne GTS, 14' Boxster S, 12' CBR 1000', 04' Bayliner 2556
Sold: 2010 A4, 2008 335i, 2007 335i, 2006 M3, 2006 S2000, 1990 NSX, 1991 300zx, 1992 Supra, 1996 Prelude, 1981 CRX, 1980 Mustang. |
12-14-2010, 02:45 PM | #46 |
Rep 291
If HP and TQ are on the same scale they will always cross at 5252 rpm.
If, however, the scaling is different they will cross somewhere else. The dyno on the top of page 2 has HP on a 0-350 scale and TQ on a 0-400 scale and the curves cross at about 4700 rpm. Plot them both 0-400 and you would be back to crossing at 5252rpm.
2009 Spacegrau 335i |
12-14-2010, 03:15 PM | #47 |
Rep 1,311
The only factor that will make hp and tq values to cross at any other rpm than 5250 is when the torque is measured Metric units, i.e. Nm. The rpm crossing point will then be 5250*1.356 = 7120 rpm.
12-15-2010, 03:19 PM | #49 | |
Rep 25
Users with the same tune on another E90 335i Steptronic w/10k RTF tires & full tank of gas has done 12.746@107.77Mph just with this tune.
12-29-2010, 08:41 PM | #51 |
Rep 37
2007 335i e90 6MT. Dyno'd on Mustang Dyno.
Baseline: Fully stock 4th gear pull 72 degrees F 91 octane 253.9 hp 247.7 Ft-Lbs. -------- Mod'd results: Dinan stage 2 Dinan exhaust K&N drop in filter 4th gear pull 62 degrees F 91 octane 291.1 hp 310.9 Ft-Lbs. -------- Gain of: 37.2 hp 63.2 Ft-Lbs. My stock tq seems low. Most other stock numbers I have seen have been much higher than the hp number. Also my hp gains appear to be a bit low. What do you guys think? |
12-29-2010, 10:35 PM | #53 |
Rep 1,046
Sweet gains!
'17 M3 Imola Red/Carbonstructure Cloth, Competition, Lighting, 6MT
Retired: '93 325i |'99 Jeep Wrangler Sport |'06 330i Sport |'08 335i Sport |'08 328i Sport |'09 335d Sport |
01-09-2011, 11:12 PM | #54 |
Rep 1,661
Stage 3 mods, 100 octane. (no meth) at 16psi. Mach V Dynojet(Blue) SAE. Bone stock 335i on 93 pump, same day, same dyno, also SAE. Why does almost everyone on here use STD....makes no sense. Use SAE. CORRECT THOSE NUMBERS....Since everyone else has STD here is a second graph with the same run only in STD. Gotta compare apples to apples.
07' MT, Quaife LSD, BMW Performance LED Steering Wheel, HPF FMIC, AA BOV, HPF Exhaust, DCI, Procede V5, AR Stage 1 oil cooler, AR OCC, AR CL DP's, Vishnu Meth Kit, UUC SSK+DSSR, UUC Shift knob, (19 inch)VMR V715's/Yokohama Advan AD08's, Hartge Pedals and Floor Mats. Awaiting Install: M3 Rear Subframe Bushings, Full M3 suspension bits, AST 4100's, DSS axles. Future plans: Vishnu Single turbo kit
01-09-2011, 11:14 PM | #55 |
13
Rep 318
Injen intake
AR downpipe HKS cat back Vishnu V4 91 octane I mess up with map, i switch around before dyno but the numbers came out kinda low ... any suggestion or commend? run 1 map 1 run 2 map 2 run 2 map 2 |
01-11-2011, 03:00 AM | #56 |
Rep 1,155
Stock Baseline
Procede Baseline (Autotune) V5 12-17 maps Bone Stock. Talk about a power change... It's amazing how the v5 transform the car without doing anything. This car is bone stock and makes amazing power and torque with no other mods. I will post up the rest of the runs with full bolt ons and step by step graphs shortly. Michael Last edited by ETS Michael; 01-11-2011 at 03:10 AM.. |
01-11-2011, 09:58 AM | #57 | |
Rep 1,661
01-13-2011, 03:29 AM | #58 | |
13
Rep 318
What octane was it ?
01-26-2011, 09:33 PM | #61 |
35
Rep 220
Ultimate Racing exhuast
Ultimate Racing downpipes Ultimate Racing intake Ultimate Racing bov Jb4 Cooling mist dual cm7 Pump gas with 70 percent meth 30 percent water. RB turbos Last edited by ultimateracing335; 01-27-2011 at 12:22 AM.. |
01-26-2011, 10:43 PM | #62 |
Rep 2,428
^ Holy cow that's a ton of power! You nearly held 500ft/lb of torque for a 4,000rpm range! And that's with stock turbos, on pump gas? I mean dang, that is extremely high.
Could we see some datalogs? Not questioning or anything, just like to see how it ran |
01-27-2011, 12:25 AM | #63 |
35
Rep 220
Sorry Brian I forgot to add the RB turbos to to the list of mods. Data logs are on n54 tech and the tuning is a work in progress. Im having some fueling issues. NEED MORE FUEL!!!!
02-02-2011, 04:12 PM | #64 |
9
Rep 338
Car:
e90 07 AT Sport Pkg Mods: Dinan Stage 2, CAI, Intercooler Conditions: Temp: 58 deg F Hum: 12% Dyno: Dynojet Gear: 4th Max HP: 299 Max Tq: 340 Max Boost: 14.35 psi Numbers seem to be in line with what others are reporting, although max HP is quite a bit less than RWHP reported by Dinan @ 342. Dinan stock RWHP was 296. Also, their max flywheel Tq reported 421 at, deduct 15% for driveline (can you make that adj for Tq, same as hp?), call it 366. Dinan reports max boost at 13.2, so not sure if readings on this were accurate or not. These Dinan numbers w/o CAI or intercooler, which probably don't make a big diff anyway at the dyno. Generally happy with the car. A bit disappointed in the numbers. |
02-03-2011, 11:51 AM | #65 | ||
37
Rep 386
'07 E92 BMW 335i
02-03-2011, 12:35 PM | #66 | |
9
Rep 338
One thing I'd like to add is info on air/fuel. It shows at about 15 from 2K to 3K and then tapers down to 12 by about 4.5K rpm. Is that normal? I know, in general, there can be variations between dynos and even day to day, but just seems a bit low compared to some others I've seen online....and definitely from what Dinan reports. Unfortunately I don't have a baseline to compare to. Am considering sending the info to my SA to see if it is worth having Dinan take a look. I would expect a canned response, but no downside to asking. |
