01-13-2014, 12:38 PM | #46 |
Rep 1,245
These are OE wheels and tires straight off a 650i, the only thing that requires changing is the TPMS sensors since the F30 ulitizes different sensors in the wheels. I didnt bother changing them since I only had these on the car for a couple weeks.
Here is whats on the the car currently. style 252 from the 7 series, these did require a change of tires to fit as well as the TPMS.
03' 525iT stick, 22' 530i
Previous: 20' X3 M40i, 19' 740i Msport, 17' 430i GC, 15' Msport X3 28i, 15' Sportline X1 28i, 13' Msport 328i, 09' Msport 335i, 07' Msport 335i |
01-14-2014, 07:15 AM | #48 |
Rep 6
Which TPMS sensors you use, because as I understand it, how to change the diameter of the wheel and the tire sensor must be the corresponding change, correct?
01-14-2014, 08:59 AM | #50 |
Rep 1,245
I swapped the original sensors over, you just have to reset them when the vehicle prompts you too.
01-24-2014, 02:40 AM | #51 |
Rep 1,136
Not sure how you aren't rubbing in the front... I just put on dinan springs and have the same tire specs in front as you and I rub over certain dips and bumps..
sent from bimmerpost Android app
01-28-2014, 04:31 PM | #52 | |
Rep 710
What part of houston are you in? |
01-28-2014, 06:42 PM | #53 |
Rep 1,245
hmmm not sure why your rubbing, maybe the Falken sidewall profile? I was running the OE Dunlops which have pretty rounded side walls...weird
I work at the dealer so we have used wheel sets come through all the time...I'm up on the north side
02-09-2014, 12:08 PM | #54 |
Rep 5
02-14-2014, 11:25 PM | #56 | |
Rep 1,805
I have the exact same set-up on my car with the stock X-drive suspension and I'm rubbing in the fronts on large bumps.. I have wear marks on the inside of my plastic fenders (thank god no paint damage).
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
12-29-2015, 12:37 AM | #58 |
Rep 11
I am thinking about swapping my 405M's for these. They also have the 245/35/20 (8.5J) tyres at the front and the 275/30/20 (9J) at the back. The tyres are from Michelin.
I have the DHP as well. Anyone else have an update on whether their setup is rubbing or not? |
07-30-2023, 08:32 PM | #59 |
21
Rep 170
