04-23-2014, 02:21 PM | #46 |
Rep 1,003
Drives: 16 340i, 15 X3d, 91 318i
04-23-2014, 07:09 PM | #47 |
59
Rep 376
Unfortunately I cannot expand quite yet. Another member in France said he was able to do it with ISTA/D, which is also available for download. It is something that can easily be done at a dealer, but you would run the risk of having them questioning things.
In my case, I had taken my car for service and they noticed the error and tried calibrating them, but I had them stop trying to diagnose it. SO I am guessing that when they did that, they finally activated my sensors, but I still had the one that wasn't working. I have no way of actually knowing cause I did not try to diagnose mine until after the dealer calibrated it. |
04-24-2014, 10:12 AM | #48 | |
Rep 1,003
I have a friend who is a dealer tech, maybe I could inquire about the leveler activation next time I get the chance. I anxiously await further info from your experience |
04-24-2014, 10:21 AM | #49 | |
59
Rep 376
However, the person I mentioned in France, has no errors and his autoleveling function is working perfectly, as I expect mine will when I replace the faulty sensor. |
05-07-2014, 01:46 AM | #50 |
Rep 4
I have some of these parts available. I posted it under the classified section. Link:
http://www.f30post.com/forums/showth...0#post15909290 |
06-09-2014, 04:19 PM | #51 |
Rep 24
Warranty
Can anyone chime in on whether or not this will void warranty in any way? (I'm assuming if it does, it's only for the lighting part of the car that was manipulated)
Thanks |
06-11-2014, 11:31 AM | #53 |
59
Rep 376
jj1336: it's commonly accepted that anything you modify that results in damaging something will not be covered under warranty. there is no such thing as voiding the whole car warranty that I have ever heard of, you would have to really do something stupid to do that and the dealership would have to be pretty evil.
SJ00: if you are looking used, you have to realize that you will likely only find these from 335s and you are only dealing with two years of production cars. the lighting package isn't that common on 320s and 328s, plus now a lot of people are going to be looking for them now that there is a retrofit available. another thing to realize is that most totaled cars are damaged in the front so salvage parts will be harder in that aspect. set up alerts on ebay, expand your ebay searches to international, check car-parts.com for used ones (make sure you search 335s and know what you are getting with the headlight), and of course some parts are just going to be have to purchased at the dealership. Good luck with it though. |
07-30-2014, 01:37 AM | #55 |
Rep 443
Has anyone retrofitted a 2014 with nbt with the xenons? It seems that the coding is different from the 2012 and 2013's. Any help with this matter would be much appreciated.
08-10-2014, 05:30 AM | #57 |
Rep 4
can i just confirm that i can install the xenon lights as a stand alone and not install the auto leveling and get no errors?
Im attempting to install xenon's on my f20 and im hoping it will require the same coding and wire placement |
08-10-2014, 09:37 AM | #58 | |
59
Rep 376
08-28-2014, 02:23 AM | #61 |
Rep 18
I have fitted mine but have a couple of issues.
The high beam does not work, and I don't have c_blc_ena in any folder when i search it says its not there. Anybody any ideas? Thanks |
08-31-2014, 07:56 PM | #63 |
Rep 5
I successfully retrofitted Xenon lights to my 2014 328xi yesterday. I added 522 and 524 then VO coded FEM_BODY. I then disabled C_FLC_ENA since I don't plan to retrofit the leveling sensors.
Everything appears to work fine except I'm noticing something odd with the light distribution on the passenger headlight. When I turn the car on, it does it's pre-check of both headlights. The driver's side then goes to the left while the passenger side stays straight. If I turn the wheel all the way to the right, the passenger side does turn as far as it can go so I don't think it's a hardware issue. When I drive above 30 mph, the driver's side then goes straight but of course the passenger's side is already straight. Is this normal behavior or is something wrong? I would expect both lights to go out to the side under 30 mph and both to go straight above 30 mph. |
08-31-2014, 08:29 PM | #64 | |
59
Rep 376
08-31-2014, 08:45 PM | #65 |
Rep 5
adaptive, diy, f30, install, xenon |
