01-13-2015, 08:09 AM | #73 |
20
Rep 126
01-23-2015, 04:33 AM | #76 |
Rep 122
Fitted mine yesterday. heres what I found
1. install is simple. rears take around 30 minutes on a lift. just remove inner lower arm bolts and shock mount bolts, level sensor arm and lower arm down until spring is loose, remove and refit new springs 2. Front is also simple, remove adaptive suspension wires and any covers from topmounts, slacken all 6 topmount bolts (one is under a brace but can remove bolts from 1 side and lift enough to remove) remove pinch bolt from hub, remove track rod arm and front stabiliser arm from hub and then support hub assembly. remove the topmount bolts and you can swing the damper down past the arch and out ready for spring swap, then refit. 3. I noticed on both sides that if you turn the hub from side to side once assembled with the eibachs the topmounts click, did this on both sides despite them being fitted 100% correctly. once sat on the floor this noise does not happen. it seems that the eibach coils sit at a slight angle causing the topmount bearing to not sit flush when damper is extended. will check again in a week. 4. ride height - rear is perfect, front is a huge improvement over stock. will post some pics later. 5. Ride quality - much like stock, steering feels a bit more direct but thing a geometry check will find that its toeing in a bit on the front. nice and compliant/soft over bigger bumps and not crashy or jarring at all but smaller rough road surfaces it does seema little harsher, more testing needed to be sure. |
01-23-2015, 07:27 AM | #78 | |
General
21132
Rep 20,742
Drives: 2021 911 turbo
01-23-2015, 07:47 AM | #80 | |
23
Rep 90
01-23-2015, 09:04 AM | #81 |
Rep 399
PICS!!!!
Delivered 11/28
YMB F80 - Excutive, DCT, and SO int. Current ///AMG 2009 P30 Calcite White C63 - V4 Eurocharged ******* 2012 Mini Countryman S JCW |
01-23-2015, 05:35 PM | #82 |
39
Rep 204
Drives: M3 F80
Excellent! Where can I get a set?
01-25-2015, 09:37 AM | #83 | |
41
Rep 170
01-27-2015, 03:49 PM | #86 |
Rep 7,148
watching this thread closely!
Looking for something in-between the H&R options out there now
2016 F80 M3 Mineral White/Sakhir Orange
2013 BMW S1000RR Flat Silver <stolen> 2007 BMW E92 335i Jet Black/Jade Grey <sold> |
01-27-2015, 08:32 PM | #87 |
_______
171
Rep 1,088
Me too. Pics and more details please. Like how did you get them?
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat |
01-28-2015, 04:37 AM | #88 |
Rep 122
I got them as I work for a dealer for EIBACH here in the UK:
https://www.facebook.com/theperformancecentreuk pics incoming.... |
