03-20-2022, 12:37 PM | #67 |
Rep 3,608
My use of “essentially” was probably not used correctly! Rebrand from the point of view that it’s the same hardware but different spring rates. Wasn’t trying to be too wordy in my post lol
Current: F80
Prior: F82, F32 |
CanAutM321131.50 |
03-20-2022, 06:29 PM | #68 |
Rep 14,144
Drives: G82 M4C X-Drive
I ran with MPHAS for that height adjustability. Don't settle for just springs if you want it just right and corner balanced.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
03-20-2022, 07:22 PM | #71 |
Rep 14,144
Most dealers will price match getbmwparts.com since it's actually some dealership's (edit: Silver Springs BMW) parts website. You just have to ask
slcook541863.00 |
03-20-2022, 08:23 PM | #74 | |
Rep 893
- remove tint - Remove CF front and rear bumper add-ons - Remove Dinan suspension / install stock suspension - install stock front lip - Install iND painted reflectors - Install iND Badge - mount and balance Cup2 - alignment
Instagram: slcook54
03-21-2022, 02:01 AM | #76 | |
Rep 1,224
m34m697.00 |
03-21-2022, 07:37 AM | #77 |
General
21132
Rep 20,742
Drives: 2021 911 turbo
Agreed. And the adjustability goes well beyond aesthetics and corner balqncing. Having the ability to vary the relative front-to-rear roll center heights has direct effect on handling balance.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
jmg18872.00 |
03-21-2022, 07:51 AM | #78 |
56
Rep 65
So that front wheel gap: engineered that way for more suspension travel under braking for increased grip? Or, intentional so owners wouldn’t rip the front lip off leaving the dealership?
For myself, aesthetically that’s the only <very> small negative against this car, but it more than likely serves a purpose, so it isn’t something I’m going to even attempt to fix. Add to that, I’m lucky that I don’t scrape leaving my driveway in stock form, don’t want to push my luck. |
falconey483.00 |
03-21-2022, 09:44 AM | #79 | |
Rep 14,144
Typically we lower the front more than the rear to make the wheel gap even. This actually gives the car a forward rake and affects the way the car handles, and not in a good way IMHO. One thing I have noticed is the lack of rear end stability under hard braking. I tuned this out by raising the front a little bit. You can also do this by adjusting compression in the front, rebound in the rear, or spring rates, but that is beyond the scope of lowering spring and a HAS setup. You would need a true coilover system for that.
slcook541863.00 M3CSinWisc56.00 |
03-21-2022, 09:55 AM | #80 | |
56
Rep 65
03-21-2022, 10:08 AM | #81 | |
Rep 3,608
Edit: added 3 & 4CS pic for reference as well (re-upped for better optimized viewing)
Current: F80
Prior: F82, F32 Last edited by RugbyBro; 03-21-2022 at 03:04 PM.. |
03-21-2022, 06:49 PM | #82 | |
Rep 1,290
Bush league to adjust based on even front to rear, tire to fender gap. They shouldn't be even else dragster rake. There is no BMW M that comes from factory with even gaps all around. If adjustable route, get it as level as possible based on side sill and make incremental adjustments from there by someone who knows wtf they're doing.
Dry sump flat six
03-21-2022, 07:35 PM | #83 | |
Rep 14,144
03-21-2022, 08:56 PM | #84 | ||
Rep 1,290
Dry sump flat six
jmg18872.00 TractionControlDelete4604.00 |
03-22-2022, 02:04 AM | #85 |
205
Rep 319
Is anyone running wider tires in the rear on stock wheels or are 285 the widest you can go? I’m going to need new tires soon and wanted to know if I can go to 295 or even 305 in the rear
03-22-2022, 07:30 AM | #86 | |
56
Rep 65
m34m697.00 TractionControlDelete4604.00 |
03-22-2022, 08:37 AM | #87 | ||
Rep 1,290
Dry sump flat six
03-22-2022, 09:06 AM | #88 |
56
Rep 65
Not sure how that was hard to understand for you.. engineers have a gap on purpose, owners try to lower their car to get rid of it. We're in agreement, but whatever.
