KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
07-11-2012, 08:11 AM | #89 |
308
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
275/30 and 305/30 on 19x9.5 +32 and 19x11 +25. 10mm spacer on front. Rears def rub. Fronts, I haven't really noticed anything yet.
07-15-2012, 09:26 AM | #90 | |
182
Rep 388
What did you end up doing with your spacers? I'm in the same position, but I have not opened up the 15mm spacers yet. I put the 12.5 in the rear, but I'm thinking of moving them to the front and exchanging the 15 for 10's. Problem is Turner says 10mm could be a problem, yet I see many people running 10mm. What do you think and is 10mm a problem at all on our cars
07-17-2012, 01:17 AM | #91 |
72
Rep 341
Yokohama AD08's: 275/30 and 295/30 on E92 comp pkg, no spacers and no rubbing so far (street and autox). I was worried it would rub but so far, nothing. Looks great and handling was amazing on the autox course (compared to stock PS2's).
I do have the pins pulled up front. |
07-23-2012, 01:36 PM | #92 | |
64
Rep 198
second of all, i just pulled the trigger on the same springs after seeing your post even though I wasn't going to drop mine due to rubbing concerns. fingers crossed for the same outcome you had! thank you for posting |
07-23-2012, 02:26 PM | #93 |
HALA MADRID!
941
Rep 2,879
Car: '11/75 E90 M3
Wheels : 359M competition Spacers: MS 15mm front, MS 10mm rear Tires / Miles: Michelin PSS - (R) 275/35/19, (F) 255/35/19 Suspension: Stock EDC Setting: All Alignment: Stock Rubbing?: (F) None. (R) Yes, on a loaded car over really BIG bumps; otherwise, no rubbing.
F87 M2 Competition, Sunset Orange, Exc, DCT. **SOLD** F80 M3 Mineral Grey/Sakir Orange, Exc, DCT... ED 6/2015 **SOLD**E90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED. |
07-23-2012, 11:49 PM | #94 | |
Ninja
390
Rep 4,014
good to know...I'd like to get the same tire size once I burn thru the OEMs and was wondering if my 12.5mm spacers (all around) would still work..fron your info sounds like it will...
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i |
07-24-2012, 12:01 AM | #95 |
277
Rep 2,216
Drives: 991 GT3, Sold:'11 e92 M3 SG/FR
Rear ZCP + PSS 275/35 + 12.5mm spacers will definitely rub. 10mm is the max and you will still get an occasional rub over large g loaded bumps.
991 GT3, Sold: '11 e92 M3 SG/FR ZCP|ZCV|ZP2|2MK|494|415|6NR|752
07-24-2012, 02:41 PM | #96 |
Rep 1,303
does MS make a smaller spacer than 10mm, like a 8 or 7mm one? Or is that just useless....I just dropped my car on B&G springs (1" front, .5" rear) and have ZCP wheels and very soon will be upping size to a 275/35 PSS tire. Should I just go with no spacers at all in the back then?
07-24-2012, 02:43 PM | #97 | |
308
Rep 13,093
07-24-2012, 02:47 PM | #98 |
Rep 1,303
07-24-2012, 02:48 PM | #99 |
308
Rep 13,093
Yes, this can cause an issue. Guess you just have to decide what you want most.
07-24-2012, 02:49 PM | #100 |
Rep 1,303
07-24-2012, 02:51 PM | #101 | |
308
Rep 13,093
On the car right now are BBS LM 275/30/19 front with a 10mm spacer and 305/30/19 rear PSS tires. This is all on H&R springs. |
07-24-2012, 02:53 PM | #102 |
Rep 1,303
Are you having any vibration/humming with the 10mm spacer?
07-24-2012, 02:54 PM | #103 |
308
Rep 13,093
07-24-2012, 10:55 PM | #104 |
Rep 1,073
Anybody running a 10mm spacer on the front with19x9.5 +21 offset wheels with Nitto Invo 255/35/19 tires?
Lowered on RD Sport springs. Any rubbing issues? |
07-25-2012, 08:27 AM | #105 | ||
HALA MADRID!
941
Rep 2,879
if you notice, I said mine was a 10mm rear, and I did rub slightly once when I went over my "test" bump that usually brings out the rubs if any.
07-28-2012, 07:04 PM | #106 |
Rep 20
Will these rub?
Given the info in this thread sounds like this is no problem:
Just upsizing tires on an stock '11 Comp Coupe to Michelin PSS 255/35 and 275/35 from 245's and 265's. Tire shop tells me they will rub front or rear, can't remember. I say BS. What say you? TIA |
07-29-2012, 12:38 AM | #107 |
Ninja
390
Rep 4,014
fit fine, no rub..
08-02-2012, 01:12 PM | #109 |
Rep 25
2007 e90 with oem 219m with ps2
Car: 07 E90
Wheels w/ Offsets: M3 OEM 219M - (F) 18x8.5" ET29, (R) 18x9.5" ET23 Spacers: None Tires / Miles: Michelin Pilot Sport - (F) 245/40/18, (R) 265/40/18; About 5k miles. Suspension: OEM EDC Setting: Normal/Sport Alignment: OEM Fender Modifications: (F) None (R) Yes Rubbing?: (F) None at all. (R) Yes, only the passenger side slightly when the suspension is compressed. The fender liner is little sagging. Its a quick fix but I'm just being lazy. Hope it helps some ppl that thinking about this set for Non-M e90. Last edited by TigerJK37; 08-02-2012 at 01:35 PM.. |
08-07-2012, 01:43 PM | #110 |
General
21132
Rep 20,742
Drives: 2021 911 turbo
Car: 08 E92
Wheels: OEM 220M Spacers: None Tires / Miles: Michelin PSS - (F) 255/35/19, (R) 275/35/19; New Suspension: OEM EDC Setting: Comfort/Normal/Sport Alignment: Camber - (F) -2.8 (R) -1.8; Toe - OEM Fender Modifications: None Rubbing?: None at all. I will be trying out 12mm front and 5mm rear spacers shortly. |
