Weight Reduction Data Compilation
01-21-2014, 02:06 PM | #89 |
Rep 790
i had a braile in my camaro...was nice and since it wasnt touched all winter i never used the tender i bought....lol
but for the 1st start of the year i always left it on for 36hrs
2010 335i M sport
2008 328i 2006 325i 1995 Z28 6spd - 377rwhp rip |
01-21-2014, 06:25 PM | #90 |
2040
Rep 2,682
The tender for Li-ion battery is apparently different and I thought it is a good idea to get it in case I need to load tune or if I go on a longer vacation.
01-25-2014, 11:15 PM | #91 |
Boooost!
70
Rep 793
Drives: 335i
I have some specs to add for you guys:
OEM XI Front Springs - 3.4 lbs each OEM BMW Style 284 Wheels - 23 lbs OEM Continental contipro contact SSR Tires - 30 lbs Style 284 wheels + OEM Runflats - 53 lbs Renan CSL style Wheels: 19 x 8.5 - 24 lbs 19 x 9.5 - 25 lbs Continental DWS: 235/35/19 - 23 lbs 265/30/19 - 25 lbs
JB4 Stage 2 | Injen CAI | BMW PE | AR Catless DP | Alpina TCU Flash | Eibach Pro Kit | Custom TCKline Koni's | 19" M359 Wheels | DWS Tires |
09-27-2015, 03:16 AM | #93 |
16
Rep 179
Bump for updates from members, I am debating removing sunroof for carbon fiber roof to cut down on weight. 2009 E90 Would like to TRY to get down to 3400-3500lbs at 650-700whp should be enough .
08-07-2016, 06:32 AM | #94 |
18
Rep 205
When will we see the "next level" of weight reduction become common for the e9x and e8x chassis?
Have many people already started gutting them to e46, e36 levels? How soon before its common to see these (already) track threats rolling through the paddock without AC, door cards, sound deadening, Lexan, etc? It's still a nice, modern luxury car, but when you can pick one up for low $20k add reasonable suspension, breaks, wide tires and easily tune to big numbers, the temptation to get the weight down even further has to be real...I know it is for me. |
08-07-2016, 05:26 PM | #95 | |
Rep 3,778
Drives: '11 328i '19 M6
CF sunroof blankoff panel, gutted rear and trunk, Braille battery, half cage, race radiator, race shells, headers and straight race exhaust, CF trunk and hood, Telematics; TPMS; radio; CA; auto wipers; auto headlight; & remote deleted, etc., etc., etc.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
08-07-2016, 06:03 PM | #96 | ||
18
Rep 205
I involved in a project that will have some exciting new toys for the e36 and e82 guys later this year. I'm toying with the idea of getting out of the 1er into a 3 and doing just that. Not sure what area you're in but would love to see what they feel like on that kind of diet. Good luck with the build! Or at this point, the deconstruction. Jason
[SIZE="1"]JB4 ISO, PURE Turbo Stage 1 v2, Megan DP, 5" stepped VRSF FMIC, AFE CAI, Fuel-it Stage 1 inline LPFP, ER Charge Pipe, KWV3 w/swift spring conversion, M3 Front Control Arms, e90 M3 FSB, Whiteline RSF Inserts, Dinan Camber Plates
08-07-2016, 06:09 PM | #97 | |
Rep 3,778
Here're a couple of threads on the build http://www.e90post.com/forums/showthread.php?t=1010489 http://www.e90post.com/forums/showthread.php?t=1010510 We're expecting to come in under the min weight with the full cage (to be completed this coming winter), gutting the front of the cabin, and removing the passenger race shell, etc. Haven't driven it yet but am expecting it to be just as track-specific as it was before since the roling chassis was modified to its current state, less latest brake incarnation, back in '14. Good luck with your project, too, sounds like fun. Definitely deconstruction, definitely...
09-10-2016, 08:23 AM | #98 | |
Student
24
Rep 190
Drives: GT3, 335i, Charger
Thank god my gf weighs about 88lb, she usually does some runs for me, because I weigh 175lb
~2008 E92 Single Turbo Project~ 719whp/658wtq @29 PSI FFTEC Precision 6466 Bottom mount cppnr1@gmail.com |
09-10-2016, 08:24 AM | #99 |
Student
24
Rep 190
I am thinking about deleting my sunroof as well, please tell me if it's worth it. Loosing that top-heavy weight make any difference in handling??
09-10-2016, 08:32 AM | #100 |
Student
24
Rep 190
OK:
I am currently at 560whp, noticed that on track the weight is heavy on the front brakes, and the top-end weight makes it a little hard to get through the corner at certain speeds. My solution so far came to a cf hood and deleting the sunroof, trying to shed the top-end and nose weight. Any feedback for those who have done this would be great! Also, has anyone installed the challenge cf doors?
04-19-2018, 01:16 PM | #101 | |
36
Rep 137
11-21-2018, 01:58 AM | #102 |
87
Rep 236
Drives: e92 335iA
--edit--- https://www.e90post.com/forums/showthread.php?t=1282179
Anyone had replaced an ordinary steel bumper brace with one from e92 M3 (carbon fiber)? Does it fit with M or standard bumpers? I am about to switch the rear one to M tech, might be a time to change the brace/support member or however you call that thing...
"If everything seems under control, you're not going fast enough.” Mario Andretti
Last edited by streetpro; 11-21-2018 at 02:15 AM.. Reason: I ve found the thread already :-) |
03-11-2019, 01:17 PM | #103 |
57
Rep 156
I have a stripped bare Pre-LCI e90 in the shop right now. If anyone needs any parts weighted, let me know. I have a crane scale with a 660lb capacity, probably not super accurate under 10lbs.
FWIW, my goal is 2500lb dry weight, caged. |
R.G.233.00 |
03-21-2019, 09:50 PM | #104 |
57
Rep 156
Car is a slick-top (no sunroof) 2006 325i with auto transmission.
Rear Subframe + Mounting Hardware (with all bushings) - 51.1 lb Rear Control Arms (one side, with hardware) - 18.7 lb Rear Differential (automatic transmission, with fluid) - 71.4 lb Sound Deadening and Roof Insulation (slicktop chassis) - 21 lb Bare Chassis with front subframe, latches, and rear glass (sound deadening removed) - *839 lb *the car is sitting on four axle stands under the OEM jack points. I lifted one side at a time from a strap attached to the door strikers; driver side was 420 lb, passenger side was 419 lb. Not 100% sure if this method would be entirely accurate, but I can't see why not. Last edited by Justin Daniels; 03-25-2019 at 10:25 PM.. |
tlow982195.50 |
03-25-2019, 10:24 PM | #105 |
57
Rep 156
Front Subframe - 21 lb
Which means the almost bare chassis, in the following state, weighs 818 lb : - Rear glass still installed - All four doors with latches but no glass/track/mirrors. - Other than that, absolutely everything removed that didn't require cutting - Sound deadening removed - No hood - No bumpers - No trunk - No bumper reinforcement - Starting to get the idea? Last edited by Justin Daniels; 03-26-2019 at 07:27 AM.. |
01-10-2020, 10:57 AM | #106 |
Rep 430
Drives: 2008 BMW 335i Coupe
Anyone have any idea how much the hood and sunroof weigh on the e92? Should be around the same I’d think
01-15-2020, 11:13 AM | #107 | |
Rep 5,025
no need to physically weigh or guess for example: https://www.realoem.com/bmw/enUS/par...&q=34516863356 \ weight 2.8kg |
01-31-2020, 09:29 AM | #108 | |
57
Rep 156
2383lb E93 M3 mirror But when they are off they seem to be VERY off so I guess it could be an valid resource for weights! Sometimes it's nice to have a weight of an assembly without having to tally up all of the component weights (seats for instance). Last edited by Justin Daniels; 01-31-2020 at 09:35 AM.. |
02-02-2020, 05:55 PM | #109 | |
Rep 5,025
04-22-2020, 10:23 PM | #110 |
Rep 430
Has anyone gotten the sunroof delete offered by Nelsonracing? Looks amazing and you cut down on 33 pounds up top.
