10-23-2012, 02:07 AM | #1123 | |
13
Rep 171
Shawnsheridan, would you be so kind as to send me the esys links as well? I'm still not allowed to send or receive pm but I was hoping you could mail it to me? laraake @ gmail.com |
10-23-2012, 03:20 AM | #1124 | |
14
Rep 45
As for: 1. I modified V_SCHWELLE_1 and V_SCHWELLE_2 within REM_01 AND from within PMA, but the rear view camera and the top view camera still can't be activated at high speeds. 2. In the F10 cheat sheet there is FLA_AUTO_AKTIV under FRM module, it sets High Beam Assistant to Automatic On. Is there a way to do this on the F30? The F30 has no FRM module and I have no idea which one is its "counterpart". Anyone? Any ideas, please? |
10-23-2012, 07:42 AM | #1125 |
General
10545
Rep 41,221
You can Receive, just not Send yet. PM Sent.
10-23-2012, 10:21 PM | #1128 |
General
10545
Rep 41,221
PM Sent.
10-23-2012, 10:22 PM | #1129 |
General
10545
Rep 41,221
With only 1 Post, you can't receive PM's, so provide an email, or wait until you have more forum posts.
10-23-2012, 10:26 PM | #1130 | |
Rep 2
10-23-2012, 10:32 PM | #1131 | |
General
10545
Rep 41,221
10-24-2012, 10:33 PM | #1132 | |
Rep 44
REM-7A1 3203 PdcParkMasterVar V_OFF_PF_R UNKNOWN FF REM-7A1 3203 PdcParkMasterVar V_SCHWELLE_1 UNKNOWN FF REM-7A1 3203 PdcParkMasterVar V_SCHWELLE_2 UNKNOWN FF REM-7A1 3203 PdcParkMasterVar D_SCHWELLE_1 UNKNOWN FF REM-7A1 3203 PdcParkMasterVar D_SCHWELLE_2 UNKNOWN FF PMA2-BCE 3003 PdcParkMasterVar V_OFF_PF_R UNKNOWN FF PMA2-BCE 3003 PdcParkMasterVar V_SCHWELLE_1 UNKNOWN FF PMA2-BCE 3003 PdcParkMasterVar V_SCHWELLE_2 UNKNOWN FF PMA2-BCE 3003 PdcParkMasterVar D_SCHWELLE_1 UNKNOWN FF PMA2-BCE 3003 PdcParkMasterVar D_SCHWELLE_2 UNKNOWN FF PS: I'm as well interested in automatic-High-Beam-Assitant. No solution found yet. |
10-25-2012, 06:17 PM | #1133 |
14
Rep 45
I actually tried that, changing the values in BOTH modules and it worked. But only the TopView, the rear view camera still didn't work at high speeds. Oh well, I reverted them back to stock anyway, not interesting enough
Now ... I got another little problem. I was stupid enough to try "Code Default Values" because "Code" gave me an error (no idea why, tried multiple times, some ECUs worked, some not) and I got lots of dumb errors like windows not working, collision detection not working, front camera not working, stuff like this (probably because values were set to "no options on the car"-state). I restored from the latest saved files, now everything is running with no problems. BUT, I read somewhere about these so-called shadow errors ... Will the dealer see I had all those dumb, theoretically without logic, errors? How can I remove them, if so? Thanks. |
10-25-2012, 09:47 PM | #1134 | |
General
10545
Rep 41,221
2) DON'T EVER HIT CODE DEFAULTS! This codes the ECU to a factory floor condition, and does not use your VO at all. If you mistakenly hit CODE Defaults, then the solution is to CODE afterwards to VO Code the ECU based on your specific vehicle order. 3) I have never heard of "shadow error codes", and I wouldn't worry about them. If the car isn't throwing and error code on the Instrument Cluster or an iDrive Control Message, you should be fine.
10-25-2012, 09:59 PM | #1135 |
Rep 3
Hi, can someone email me lawrencetoh@gmail.com the link for E-Sys program & datafiles as well? Thanks in advance. My cable is ready, waiting for the software to proceed.
10-25-2012, 10:05 PM | #1136 | |
General
10545
Rep 41,221
10-25-2012, 10:34 PM | #1137 | |
Rep 59
Drives: 2017 F30 330i M Sport EBII
Garage List 2002 BMW 325i [0.00]
2006 BMW 325i [0.00] 2013 BMW 328i [0.00] 2015 BMW 328i [0.00] 2017 BMW 330i [0.00] |
Could I have the links for the files as well? Thank you. I have a question regarding this ^^ because I am not completely sure if I understand your comment. Are you saying that if I code the car and dealer upgrade my ECU CAFD while service, I might not be able to restore it back to original? Does it mean if I want to go back I just have to do it all over again and"manually" code it back? Can you please explain it to me? Can the car be bricked when dealer does update? THANK YOU. |
10-25-2012, 10:51 PM | #1138 | |
General
10545
Rep 41,221
An ECU can be bricked any time it is flashed if something goes wrong, but that has nothing to do with whether or not the module was coded by you or not. PM Sent.
10-25-2012, 10:57 PM | #1139 | |
Rep 59
10-25-2012, 11:02 PM | #1140 | |
General
10545
Rep 41,221
10-26-2012, 03:57 AM | #1141 | |
14
Rep 45
The FEM_BODY and REM(this doesn't matter anymore, I've done them manually) gave me an error when trying to "Code". I mean it went through the whole process but after clicking "close", in the window that pops at the end where t tells you everything went ok and you can save the report, it told me there was an error, in red fonts. Should have saved it, I guess so I can paste it here As for shadow codes, there are many talking about them even on these and e90post forums. It's an error that showed up then got fixed by itself so to say, but it remains stores somwhere for the dealer to see it (in the good way, so they can see there was a glitch and might need further investigating). Also, about what you just explained, about the dealer updating the ECU, how will I know that? That long number of the saved ncd file going to be different than the ECU's, right? Thanks! |
10-26-2012, 11:38 AM | #1142 |
Internet Crash Test Dummy
334
Rep 1,055
Drives: F97 X3MC / F80 M3 / F90 M5
Link to e-sys files
I'd appreciate a link to the E-Sys files/data as well .
jmh at janixworld.com Thx in advance, Jan
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107 |
10-26-2012, 01:06 PM | #1144 | |
General
10545
Rep 41,221
