07-12-2023, 03:23 AM | #11903 | |
17
Rep 40
Do you have any restarts?
I just testet mine and I've had like 4 in one minute. Quote:
07-12-2023, 03:39 AM | #11904 |
55
Rep 63
Hey, I'm in Veldhoven (The Netherlands) and sell Andream MMI's. Always welcome to have a chat
Did my post help you? Please appreciate post.
07-12-2023, 04:01 AM | #11905 |
55
Rep 63
There is a new update for Andream BMW CIC, NBT and EVO MMI's (1.6.13)
It allows you to use bluetooth in stead of AUX. Saves a lot of install work for CIC mmi's and sound quality is better. Can be downloaded from here: https://102435.sharepoint.com/:f:/s/...960Xw?e=1QRsGy Update at own risk, As far as I know, only works on 1.5.x and 1.6.x version numbers. Only known problem is that Siri's reply volume is very low.
07-12-2023, 10:08 AM | #11906 | |
Rep 36
07-12-2023, 10:37 AM | #11907 |
Rep 9
07-12-2023, 10:43 AM | #11908 | |
Rep 9
Road Top says they can't fix the aspect ratio problem I'm having with HDMI and Autolink. Has anyone tried these modes on the Andream or Bimmertech units?
07-12-2023, 02:01 PM | #11909 | |
Rep 29
And Unfortunately it still doesn‘t solve the issue that siri is not properly working when pushing the steering wheel „voice button“ |
07-12-2023, 02:15 PM | #11910 |
Rep 9
Panning in Google Maps
Does anyone know how to pan the Google Maps in AA with the iDrive controller (or any way for that matter)? I can zoom by turning the wheel but left, right, up, down do not pan.
Car: 2020 X2 8.8 in display NBT EVO ID6 Example video: https://photos.app.goo.gl/5Foc4Y4SWYQzJ2WB7 |
07-12-2023, 04:30 PM | #11911 | |
15
Rep 34
Would I be able to update to 1.6.13? I've read that the update sequence is important. Thanks! |
07-12-2023, 05:10 PM | #11912 | |
Rep 9
07-13-2023, 04:51 AM | #11913 | |
Rep 26
ID5/ID6 please choose EVO. |
seanswn3.00 |
07-13-2023, 05:59 AM | #11914 |
Rep 7,542
Sorry to ask this question again but I'm about to pull the trigger and finally buy an mmi box, but does the nbt Evo version require a micro phone harness? I keep hearing mixed info about this.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
07-13-2023, 01:56 PM | #11916 | |
Rep 7,542
So I'm assuming it gets microphone input from the quad locks? Also did your mmi kit come with a microphone cable?
07-13-2023, 01:59 PM | #11917 |
Rep 11
Is there an update for mine. Every time I get back in my car I have to repair my pixel 7 phone as it has forgotten how to work..I always get a prompt to pair.
07-14-2023, 01:32 AM | #11918 | |
Rep 4
I don't investigate the microphone function yet. Maybe someone else can answer that question. My mmi kit from andream-eu comes without a microphone cable. It contained Power Cable, Wifi Antenna, AV Cable & LVDS Cable. |
F87source7368.50 |
07-14-2023, 03:10 AM | #11919 |
Rep 78
I have the same issue with my Pixel 7, it's definitely a phone issue though as my wife's Samsung works fine. I found that resetting the network settings on the phone and pairing again has helped, now I only see this issue once or twice a month
07-14-2023, 08:40 AM | #11920 |
Rep 9
I also have a Pixel 7 and was having connection issues. I think I figured out that it was my Pixel watch that was causing the problem. Turning off Phone Calls in the watch Bluetooth setting on the phone seems to have fixed it.
07-14-2023, 10:01 AM | #11922 |
Rep 3
Hello Folks,
I bought and installed the Andream MMI Carplay for my 2011 535i. https://www.android-car-dvd.com/coll...ew-bmcp-nbt01a For context, my car came with the the CIC system (Bluetooth only for calls, not music). My problem is that everything works, but when calls come in, I can hear the other party through the MMI System and car speakers, but the other party cannot hear me unless I change to speakerphone on my iPhone and then speak directly into the cellphone. Quite a pain. I've reached out to Andream but they keep telling me about sending a video showing that I have connected the fibre-optic cable and turned of OEM Bluetooth. Not helpful as fibre optic cable feeds audio out of the head unit, not in. Does anyone know how to fix this? |
07-14-2023, 01:49 PM | #11923 | |
Rep 1,607
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
07-14-2023, 07:09 PM | #11924 |
Rep 3
I followed all the steps in the installation video -- including transferring the fiber optic cable. Is there any other way I could test this? I would not want to disassemble my entire dashboard just to check this.
andream, android, android auto, apple, carplay, mmi, retrofit |
