Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Photo/Video/Media Gallery > E93 Convertable roll call
      09-01-2023, 09:30 AM   #1761
E93Seattle (Racerbruce)
E93Seattle (Racerbruce)'s Avatar
800
Drives: 2013 335is E93 & 2021 X3
Originally Posted by Gregrobin View Post
Did you remove them to do this, or do it with them mounted?
still mounted.
hand sanded and using sheet packing paper, uber-draped off all areas and used masking tape for difficult areas, spray-can primer and then spray-can hammertone silver.
hand sanded the triangular metal piece located at the center (just below the middle of the differential) and made it shiny and then masked off and spray-can clear coats applied.
did the same with the front rotor backing plates and hubs:
Name:  Red Rocket LF After Pic 2.jpg
      09-01-2023, 09:43 AM   #1762
800
Name:  Red Rocket LF 1.jpg
      09-03-2023, 08:21 PM   #1763
Mister_R
MisterR247365.com
Mister_R's Avatar
Drives: 335i M-Sport Cabrio (E93)
Dropped the top for a change AND took photos lol...
--R
Appreciate 3
      10-08-2023, 03:41 PM   #1764
CLEAN13BOOSTED
Drives: 2013 BMW E93 3351
New Ride :)
Picked up a Unicorn! Only 22k miles!!!
Appreciate 4
      10-17-2023, 03:51 PM   #1765
lowrydr310
Robot
1698
Drives: 2006 330i, 2007 E93 335i
Appreciate 5
      10-17-2023, 04:51 PM   #1766
800
replacing vacuum lines with high temp silicone hose
Name:  Red Rocket Vacuum Lines Pic 4.jpg
Appreciate 4
Mister_R409.00
lowrydr3101697.50
MSCD3186.00
      10-17-2023, 06:16 PM   #1767
800
multiple days detail of oem mufflers....
Name:  Red Rocket OEM Mufflers Pic 1 Before.jpg
Name:  Red Rocket OEM Mufflers Pic 2 During.jpg
Name:  Red Rocket OEM Mufflers Pic 3 After.jpg
      10-17-2023, 10:51 PM   #1768
335togo
Daily Driver
335togo's Avatar
Drives: 07 N54 Sold, 11 N55
e93
2011 E93 M SPORT N55 All DONE
Appreciate 3
      10-18-2023, 08:54 AM   #1769
800
well done -
such a beautiful daily driver - well done.
how long have you owned? mods? miles? tell us a little about the car.
      11-24-2023, 09:10 PM   #1770
335togo
Daily Driver
335togo's Avatar
Thanks bought as lease return at the end of 2014 with 25K
the list of mods is long... I will give it a try if I can remember it all lol
Underhood: Pure stage 2,Pure inlets, intercooler, downpipe, meth tank (in trunk) with dual injectors stock intake with K&N Fuel-it bucketless pump Resonators mid and HKS exhaust ( I think it sounds the best very deep only slight drone between 1800 and 2100...sounds amazing at 7K)
Suspension: all M3 upgrades that were available front and rear, Sub frame bushings, just changed in this pic to TC Racing coil overs. 400lb front 700lb back
from Bilstein B 14kit which was OK but too soft...Front Dinan swaybar and H&R rear. changed to M3 rear diff....so it gets great traction
Stoptech big brake front and rear ...Apex EC-7 wheels 235-35/19 front and 265-30/19 back PS4s
Trim blacked out and rear diffuser painted black Carbon wrap on all interior pieces Rear camera added Roof open and close on key fob
Probably missing some things is been a good car has 82k on it now and just did water pump and everything connected to it.
Once warmed I beat the piss out if it and it keeps coming back for more.
Running about 22lbs of boost with Wedge Tune.
0-60 best run was with roof down 3.89 tough to get good launch either underboost or over the the tires just light up did a 3.9 and in only 152 ft which is a more impressive run.
need to do a 60-130 run but thats tough without drawing too much attention
I bought a 2005 M3 ZCP and thought about selling car but with the power and drivability I just cant part with it...I takes on all comers thats for sure..
I probably have spent as much on parts and labor as I did the car back in 14 but for 60k (to date all in ) I feel its been money well spent!
      12-08-2023, 01:27 PM   #1771
Renegadenick
Petrol Head
Renegadenick's Avatar
88
Drives: Slow Cars
It’s been awhile e93 gang. Here are a few shots from the past few years. Just hit 14 years of ownership. It’s no longer a daily driver so maybe I can do more with it.
I think the most notable changes since my last update are the interior, power mods, and custom exhaust. Stoptech BBK is going on soon once I get the chance to install. Hopefully I can get some more track time soon.
Just updated the garage profile on the forum to the best of my memory if you’re interested in a mostly complete mod list.
Pre-LCI E93 | 1 of 68 | Mojave Havanna Metallic | N54 |
@Nicholastran213
      12-10-2023, 12:36 PM   #1772
800
recently, removed the front bumper to replace both front brake air ducts that had cosmetic damage, a broken LF fog light bracket, a LF (front half) wheel well fender liner and both front bumper brackets; it appears all of this damage was caused by the "trained professionals" that "serviced" the car in prep for sale....
i have made it new and pristine, reversing the hack's "repairs":
Name:  Red Rocket Air Brake Duct Left Broken Pic.jpg
Name:  Red Rocket Air Brake Duct Right Broken Pic.jpg
Name:  Red Rocket Front End Cleanup Pic 1.jpg
Name:  Red Rocket Front End Cleanup Pic 2.jpg
Name:  Red Rocket Front End Cleanup Pic 3.jpg
Name:  Red Rocket LF Fender Detail Pic 1.jpg
Name:  Red Rocket RF Fender Detail Pic 2.jpg
Name:  Red Rocket Fog Lamp Bracket LF Replacement.jpg
Name:  Red Rocket Front Bumper Reassembly Pic 1.jpg
Name:  Red Rocket Front Bumper Reassembly Pic 2.jpg
Name:  Red Rocket Front Bumper Installed Pic 1.jpg
Name:  Red Rocket Front Bumper Installed Pic 2.jpg
      12-10-2023, 05:08 PM   #1773
800
rear undercarriage massive cleanup and repaint:
Name:  Red Rocket Rear Undercarraige Cleanup Pic 1.jpg
Name:  Red Rocket Rear Undercarraige Cleanup Pic 2.jpg
Name:  Red Rocket Rear Undercarraige Cleanup Pic 3.jpg
Name:  Red Rocket Rear Undercarraige Cleanup Pic 4.jpg
Name:  Red Rocket Rear Undercarraige Cleanup Pic 5.jpg
      12-10-2023, 06:24 PM   #1774
CLEAN13BOOSTED
Soo sweet! Dashwork and steering wheel, do tell? Alcantara ?
      12-11-2023, 01:09 AM   #1775
Renegadenick
Petrol Head
88
Drives: Slow Cars
Thanks! I found an e93 M3 extended leather dash + center console in palladium silver. It has Novillo Leather instead of that spongy material found throughout e9x non-M and M non-extended interiors.
I found a local upholstery shop to mix up some saddle brown dye that matches my shade. Next I restored the leather and then dyed the parts myself. The restoration part took a long time since the leather had a few gashes and rips. Youtube was my best friend for that part. To restore the black plastic parts of the center console, I used colorbond LVP black; it matches OEM plastic pretty closely.
Then I made an alcantara topper and adhered it to the top part of the dash. It is not perfect but I made it...so I'm happy with it.
The steering wheel was made by AZA auto wheel 6 years ago. The leather airbag cover I recently got from some shop that I will have look up to find the name. Essentially they made me a replacement cover that replaces the spongy stock airbag. It was a little scary at first disassembling the airbag fully but it was not bad at all once I got started.
@Nicholastran213
      12-11-2023, 04:00 PM   #1776
800
waiting out the latest atmospheric river falling from the skies in the great pacific northwest....
Name:  Red Rocket Garage Pic 1.jpg
Appreciate 3
      04-06-2024, 07:17 AM   #1777
ezurick
ezurick's Avatar
Drives: 2006 BMW 330Ci
my 2006 E93
Just recently purchased 2006 E93 with only 74k miles...
[Sorry, old thread. but just had to add mine... lol]
**UPDATE**
sorry for my confusion, but I am told this car is a E46. Not a E93.
      04-06-2024, 03:14 PM   #1778
Mister_R
MisterR247365.com
Mister_R's Avatar
Looks super clean and well kept but hate to be the bearer of bad news...that is an E46 not an E93.
--R
      04-07-2024, 02:59 AM   #1779
ezurick
ezurick's Avatar
Not bad news... I just didn't know. I thought at first it was an E46. I am new to BMW's and wasn't sure of the difference. I've owned other euro vehicles and most are pretty clean of model numbers. At first I tried to acquire the specs from BMWusa.com and they don't recognize the VIN for simple owners manual. I don't need the manual, but was trying to learn the specs of this car. Sorry for the confusion and I'll delete the post.
Mister_R409.00
      04-07-2024, 03:03 AM   #1780
Mister_R
MisterR247365.com
Mister_R's Avatar
No worries bro, try using https://www.mdecoder.com/ with your VIN.
--R
Search this Thread:
