12-05-2018, 12:24 PM | #1 |
23
Rep 38
2018 330i / B48 Downpipe Install Experience?
I have found numerous videos of older models with NXX engines but none that are for the B48. Has anyone found a video to support DIY install of a catless downpipe on the B48? If not, but you have experience, how different is it from the Kies Motorsports N55 DIY video:
Thanks in advance! |
12-05-2018, 06:17 PM | #2 |
23
Rep 38
Ok, so I figured out everything... except how to remove the upper brace bolt that holds the brace to the transmission. What is the technique because I can hardly get a hand up there from the bottom, let alone a ratchet. When I can get a ratchet on it, there's no room to ratchet left or right. What is the trick?
DMM26.00 |
12-05-2018, 07:20 PM | #4 |
98
Rep 227
Drives: 2000 BMW E39 M5
Maybe pickup a fine-toothed ratchet? One with less degrees between each tooth.
2017 BMW 330i Sport Wagon - M-sport, EBII, THP, DHP
Supersprint cat-back exhaust (resonated, dual outlet) - H&R rear sway bar - ER charge pipe Waiting for: Bootmod3 - xHP Flashtool - xDelete |
12-05-2018, 09:19 PM | #5 |
23
Rep 38
I may try that but the spacing honestly doesn't even feel like there is enough room for any noticeable movement. And even if I was using air tools, I don't think an air wrench would fit up there. One of my ratchets wouldnt even fit because the head was too wide.
12-06-2018, 05:15 AM | #6 |
98
Rep 227
What about a small torx wrench to break the torque?
http://www.lowes.com/pd_445713-KDT92...uctId=50164687
12-06-2018, 09:51 AM | #7 | |
23
Rep 38
12-10-2018, 10:55 AM | #8 |
23
Rep 38
Just to close this out, I ended up getting it using this combo: Socket > universal joint > 1.5" wobble > 10" wobble extension > 8" standard extension > 120-tooth ratchet.
Thanks ya'll! |
12-10-2018, 02:31 PM | #9 |
98
Rep 227
Wow, that is one hell of a tool arrangement to get that bolt out. Good job!
Any chance you can post a photo looking into the stock downpipe inlet? Curious to see how restrictive the catalyst is. Also, let us know what your thoughts are on the aftermarket downpipe performance. I think you're one of the very first to take this project on. |
12-16-2018, 07:32 PM | #10 |
98
Rep 227
OP, what's your impression of the ER downpipe for your B46? Wondering about sound, smell, power, CEL, etc.
12-21-2018, 03:43 AM | #11 |
99
Rep 130
I got mine changed to a catless downpipe sometime ago but unfortunately the welder didnt do a really good job and apparently the flange cracked and decided to look for another custom downpipe and now it works perfectly...
Instagram : mr_b48
11-07-2019, 04:21 PM | #12 |
Rep 3
Hi. How did you remove the upper brace bolt that holds the brace to the transmission. I saw there has 2 Troy bolts, only can see the button one, can not reach the top bolts. Also, how many parts did you remove? It's really a hard work - -
02-02-2020, 05:10 AM | #13 | |
Rep 1
2018, 330i, b48, catless, diy, downpipe, f30, video |
