PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
E91 11J rear
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
02-07-2023, 06:23 PM | #1 |
Rep 5
E91 11J rear
Hello,
I want new wheels for summer. I have E91 pre-LCI 2006 rwd. I'm looking for theese specs Front 9,5J ET35 with 235/35 R19 Rear 11J ET25 with 265/30R19 I run on standart msport suspension - no lower springs. Will they fit? Any camber settings? No rub or fender roll? Thank you all for your reply Last edited by Maravojtucz; 02-07-2023 at 06:30 PM.. |
02-07-2023, 07:24 PM | #2 |
239
Rep 65
Front, you'll need to be at +22 for the best compromise of tire size and clearance. You'll have some room for less aggressive camber. 235 will be an easy fit. Rubbing will depends on tires sizing but no rolling should be necessary at 9.5 +22 with 235.
Rear, you'll need to be at ~+30 at 265 with some room. No rolling necessary. I'm also on the ground so you may poke out a little at your ride height.
Not a purist. Save the wagons.
02-08-2023, 04:29 PM | #3 |
356
Rep 136
Correct, your rears will need smaller tires at that offset if you want no rolling or adding of negative camber.
Looks like my name on the title, insert your opinions into the trash!
02-08-2023, 09:07 PM | #4 |
Rep 5
Thank you guys! With negative camber will fit correct?
255/30 have +3mm Ride height gain against 265/30 and +3mm arch gap. Not too much difference. I think I put some camber |
CornerGorillaPit238.50 |
02-09-2023, 02:33 PM | #5 |
356
Rep 136
With negative camber fitment will not be an issue
05-23-2023, 03:34 PM | #6 |
Rep 5
Some update photos
I have: Front 235/35 R19 ET35 9,5J and i put 3 mm spacer for more clearance from strut Rear 265/30 R19 ET 25 11J with negative camber -2,3 no rub at all I run on standart M-sport suspension. Wheels are JapanRacing JR11. I hope this helps someone else. |
johnnyorange58.50 |
