07-12-2023, 11:15 PM | #1 |
Rep 5,394
What are you using to register batteries?
Today I bought a new OEM spec battery (AGM 90ah) for 2016 M235 but my damn Foxwell NT301 scanner won't register the thing. After a bunch of research, it turns out the Foxwells can't register batteries in newer 2009+ BMWs. I'm not looking for something computer based but rather something phone/dongle based. I don't need to code anything. Thanks.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
07-13-2023, 07:05 AM | #3 |
118
Rep 304
Bimmerlink should do the trick!
Fliplegend1520.50 |
07-13-2023, 07:12 AM | #4 |
Rep 4,932
I used Bimmerlink (using the ENET cable to the phone). Bit of a catch22 though, Google Pixel doesn't allow you to set a static IP, so I had to snag a Samsung phone from work to do the registration.
07-13-2023, 08:17 AM | #6 |
Rep 16,199
Foxwell NT510. I bought it shortly after buying my car, knowing that I'd need a scanner sooner or later, and that I would need one that would do battery registration. It paid for itself the first time I used it to clear codes caused by an ABS sensor glitch.
07-13-2023, 09:23 AM | #7 |
Rep 1,844
lmao damn that’s annoying
07-13-2023, 10:19 AM | #8 |
204
Rep 383
If you want a similar mechanics tool type item, this OBD dongle from autel is pretty good. More capable than bimmerlink. I haven’t used it for battery, but know it does it. Did use it to read and register fuel injector compensation and worked great.
Autel MaxiAP AP200 OBD2 Scanner Bluetooth Wireless OBDII Auto Diagnostic Tool with Full System Diagnostic, 19 Reset Functions, AutoVIN, Check Engine Light Code Reader for iPhone Android https://a.co/d/gYnyKvj |
07-13-2023, 01:01 PM | #9 |
Rep 5,394
Thanks. Which year BMW did you register the battery? I do have a NT530 for my Porsche Cayman but only currently has Porsche software on it. BMW software would be another $80 but I want to make sure it actually can work on a later year F series, say 2014+.
07-13-2023, 01:08 PM | #10 |
Rep 5,394
07-13-2023, 01:25 PM | #11 |
Rep 1,117
I used it on several including a 2013 F30 and a 2019 M4
07-13-2023, 05:53 PM | #12 |
Rep 4,932
07-13-2023, 08:07 PM | #13 |
Rep 1,531
2016 340i
