04-16-2024, 07:05 PM | #1 |
41
Rep 94
Drives: 2018 BMW 440i GC
I’ve been hearing this clunk or knock sound when going over uneven road surfaces or bumps.
I first noticed this after switching out my shocks and struts to new ones. In this process, I remove the tie rod end from the wheel hub to make things easier. I know it’s not from either the shocks or the struts because I have done this before without removing the tie rods and have not had this issue. Today I jacked up the car and re-torqued the tie rods to the wheel hub without preload and also tightened the steering rack bushing because I figured the noise might’ve been coming from there. Made the noise a lot worse. I am almost certain it’s coming from the tightening of the steering rack bushing. If I loosen it, the sound is much worse. if I tighten it, the sound gets slightly better, but the steering gets so stiff that it doesn’t return to center after completing a turn. What should my next steps be to fix this issue? https://youtube.com/shorts/_fdu4-T88...UGCJoec-iq3mGD |
04-17-2024, 09:54 AM | #2 | |
46
Rep 85
mclovin69x40.50 |
04-17-2024, 10:13 AM | #3 | |
41
Rep 94
There is no noise when turning the wheel only when going over bumps. I’m thinking it might be the inner tie rod ends that are loose or a blown ball joint on them |
04-17-2024, 11:58 AM | #4 | |
32
Rep 83
Drives: 2017 BMW 440i GramCoupe
mclovin69x40.50 |
04-17-2024, 12:00 PM | #5 | |
41
Rep 94
I did suspect that and compared and they were equal on both sides but you can never be too sure |
04-17-2024, 02:21 PM | #6 | |
32
Rep 83
In my case for whatever reason one slid too far in and the other was perfect. So I’m not sure what the variance is that causes that. But it certainly made a knocking sound. You can look at the bottom of the strut and see if there is any sign it was hitting something. |
mclovin69x40.50 |
04-25-2024, 03:28 PM | #7 | |
41
Rep 94
Turns out a sway bar end link was loose. Tightened it up and the noise is gone. |
Burnout27.00 |
