2011 E92 328i 6MT RWD
04-23-2024, 01:18 AM | #1 |
Rep 26
Hello, Testing the waters for my 2011 328i 6MT Location: Seattle WA Milage: 96k VIN: WBAKE5C55BE432004 Spec: Exterior: Space Grey Metallic Interior: Black Sport Package I-Drive Sunroof Heated seats N51 Engine Bought the car in March 2021 at 66k miles in San Diego. Car has been in Southern California since new until Aug ‘22 when I moved to Seattle. Maintenance/Upgrades: Apr 21 66k miles - oil change - spark plugs - cabin filters - transmission fluid - differential fluid - water pump - thermostat - New Valve cover done by dealer under SULEV warranty June 21 67k miles - 3m ceramic tint 35% side and back windows - Genuine M3 steering wheel - Weighted Shift Knob ZCP Aug 21 69k miles - Oil Pan Gasket - Motor Mounts - Brake rotors and pads all around - Clutch, Flywheel, Rear Main Seal done at shop June 22 76k miles - RE Ikon muffler installed - Bilstien B12 pro kit, all shock and spring mounts - Whiteline Poly rear subframe bushings - Oil change - Brake Fluid change Nov 22 81k miles - Oil change - set of 4 new Continental DWS06+ tires Apr 23 86k miles - Oil change - Transmission Mounts - Power Steering Fluid and Reservoir Sep 23 90k miles - Rear shocks replaced under warranty Oct 23 91k miles - Replaced 4 aluminum head bolts, 3 under valve cover & 1 external - Oil change - Oil filter housing gasket - Coolant and heater core flush - Motor mount bracket aluminum bolts replaced Apr 24 96k miles - Used set style 197 wheels - Rear upper wishbones replaced - Rear wheel bearings replaced - Alignment - Oil change - bronze clutch pedal bushings Car is in excellent condition. Super clean. I can post more pictures if there’s interest Last edited by Ayushm; 05-21-2024 at 12:45 AM.. Reason: Added engine code |
