02-23-2009, 11:22 PM | #1 |
Supreme Allied Commander
3895
Rep 54,605
Drives: F80 M3
Quaife ATB Limited Slip Differential for Automatic 135i
Quaife, The Ultimate Differential is now available for your 335i at HP Autosport, Inc.
"The Quaife Automatic Torque Biasing Helical LSD Differential enables a car to accelerate more rapidly and corner faster. How? Simply by getting the power to the ground! With an normal open differential, fitted as standard on most cars, much precious power is wasted through wheel spin under acceleration. This happens because the open differential shifts power to the wheel with less grip - along the path of least resistance. The Quaife differential, however, does just the opposite. It senses which wheel has the better grip, and automatically biases the power to that wheel. It does this smoothly and constantly, and without ever completely removing power from the other wheel. In cornering, while accelerating out of a turn, the unit biases greater power to the outside wheel, reducing inside-wheel spin. This allows the driver to begin accelerating earlier, exiting the corner at a higher speed. The Quaife differential also controls loss of traction when the drive wheels are on slippery surfaces such as ice and snow or mud, providing the appropriate biased traction needed to overcome these adverse conditions. Power is transferred automatically without the use of normal friction pads or plates seen in other limited-slip designs. The Quaife ATB Helical LSD differential's unique design offers maximum traction, improves handling and steering, and puts the power where it is needed most. A definite advantage, whether on the track or on the street. The Quaife differential is extremely strong and durable, and since it is gear-operated, it has no plates or clutches that can wear out and need costly and regular replacement. There is no maintenance required to the unit, so you can fit and forget. The Quaife differential is great for street driving or racing. Racers don't have to put up with locking mechanisms or spools that tear the steering wheel out of their hands when cornering. Because it behaves like an open differential during ordinary driving, street drivers will have trouble telling it's there until pushing the cars towards its limits. The Quaife differential is proven in everything from SCCA Rallying to drag racing and Formula 1. It provides autocrossers with such an advantage, it has become "required" equipment for a winning effort. Expand your vehicle's limits with the Quaife ATB Helical LSD Differential!" Here is a video on LSD: Top tuners using our Quaife LSD: Berk Technolgy's Redline Time Attack 135i Burger Motorsport world's quickest 135i Vishnu Tuning Most of the automatic transmission 135i come with a bolted diff, so all you need is the Quaife and a local shop capable of the install. Retails $1493.50 https://hpautosport.com/product/quai...ifferential-2/ For manual 135i's with a welded differential: We can offer a complete Quaife Final Drive Unit for a direct swap. Best tool for DIY diff fluid change: https://amzn.to/39YxRUA Last edited by HP Autosport; 08-15-2023 at 11:54 AM.. |
02-24-2009, 12:47 AM | #2 |
28
Rep 340
Drives: 09 M-Packaged 135i
So.. $1450 is the price for the Auto fitment?
02-24-2009, 12:53 AM | #3 |
3895
Rep 54,605
Drives: F80 M3
02-24-2009, 01:07 AM | #4 |
28
Rep 340
I have the Nismo mechanical LSD on my Z and frankly it affected the daily-drivability. It's too agressive and clunks like hell!
How is the Quaife compared to that? will it feel like OEM LSD?
02-24-2009, 09:19 AM | #5 | |
3895
Rep 54,605
Drives: F80 M3
The Quaife is extremely quiet, no clunks or sounds of any sort during operation. |
02-24-2009, 09:33 AM | #6 |
28
Rep 340
Sorry for all those questions... just wanted to make a couple of things clear..
so, before ordering, we need to make sure we have a bolted diff, right? which cars came with the welded ones? (mine is an 09 Auto M-packaged (non US-spec))
02-24-2009, 01:27 PM | #8 |
Rep 1,859
mine is the same as above- june 08 and 6mt- what is the install cost on these
E82 N54 6MT 6FL 668 KASW turned in
E92 Crimson/Cream N54 6MT, ZSP, ZPP, ZCW, Nav, Sat radio, HD Radio, Logic7, PDC, Active Steering, Active Cruise, 6FL, CA |
02-24-2009, 01:28 PM | #9 |
20
Rep 354
mine is 2009 , automatic transmission, european delivery
2009 AW 135i
CP-E CATLESS DPS, AFE EXHAUST , OIL COOLER KIT,FORGE DVV,,BMW PERFORMANCE SIDE SKIRTS AND BMW P . PEDALS, BMW PERFORMANCE SPOILER , BMW PERFOMANCE KIDNEY GRILLS, CODE 3 IC, DIREZZA Z1 STAR SPEC |
02-24-2009, 02:32 PM | #10 | |
I'm not as dumb as you look.
Rep 132
1 leg. i would say about the cost of the item itself.
Is this thing on?
02-24-2009, 02:47 PM | #11 | |
3895
Rep 54,605
Drives: F80 M3
Harold |
02-24-2009, 02:49 PM | #12 |
3895
Rep 54,605
Drives: F80 M3
02-24-2009, 02:49 PM | #13 |
3895
Rep 54,605
Drives: F80 M3
02-24-2009, 03:47 PM | #14 |
Rep 1,859
so if we have the welded one then we got f**ked by bmw
02-24-2009, 03:58 PM | #15 |
3895
Rep 54,605
Drives: F80 M3
03-11-2009, 04:49 AM | #16 |
175
Rep 1,537
You can always purchase a complete housing with a quaife installed, while your there why not change your ratio to 3.46 for greater acceleration. Ask Harold for details. I have done a few now and it is fantastic with a ratio changes
03-25-2009, 12:26 AM | #17 |
3895
Rep 54,605
Drives: F80 M3
Quaife for your automatic 135i is good in stock.
Complete Quaife FD for your manual 135i is ready to go as well! |
04-17-2009, 04:57 AM | #19 |
13
Rep 194
Any idea if the Quaife will work in a 128i? Since it is a manual, I assume it has the same welded gear problem.
Bill [92 Camaro RS (Autocross ESP / Trackrat) | 09 BMW 128i Sport Package] |
06-19-2009, 10:33 PM | #20 | ||
Rep 1,565
07-17-2009, 12:56 PM | #21 | |
3895
Rep 54,605
Drives: F80 M3
It is a steal compare to other more expensive options out on the market. Last edited by HP Autosport; 09-23-2009 at 11:20 AM.. |
11-01-2009, 10:54 AM | #22 |
135i
Rep 17
I've had a Quaife on my 130i before, good product. Now I have a 135i, and considering upgrading this one also. On thing that I'm wondering about is the stock "LSD-function" on the 135i/335i that works through the brakes, (that functions even when you have the DSC/DTC completely turned off.)
- How does the Quaife unit work together with this function and is there a way to turn it off? |
