03-14-2010, 07:07 PM | #1 |
325
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
2013 F30 BMW 3-Series Major Differences to E90
The 2013 BMW 3-Series will be longer and wider, but will use many components from the current model. The 2009 BMW 3-Series is shown here.
The 2013 BMW 3-Series should reprise most current-model features, starting with standard front-side airbags and, convertibles excepted, head-protecting tubular side airbags covering both seating rows. Convertibles should retain head/torso front airbags, plus rollover bars designed to deploy from the rear headrests if sensors detect an impending tip. They should also continue with a power-fold hardtop instead of a fabric roof. Returning option lists should again include a luxury-focused Premium Package, a driver-oriented Sport Package with upgraded suspension and unique trim, a navigation system with BMW's iDrive infotainment controller (doubtless revised once more for easier use), steering-linked bi-xenon headlamps, keyless entry and starting, music-player plug-in, and the BMW Assist service with wireless cell-phone link. In all, the 2013 BMW 3-Series seems to be another of those tricky redesigns that has to be "the same yet different," much like the E90 versus the prior E46 generation. And you really can't blame BMW for being cautious with a line that accounts for over 40 percent of its yearly sales and which still defines the brand in most people's minds. Besides, why risk losing sales when the market is already so tough? All of which suggests that if you like today's 3-Series, you should like the F30 at least as much. You can bet BMW is counting on it. A Notable Feature of the 2013 BMW 3-Series It was in 2005 that BMW began promoting "Efficient Dynamics," technical features intended to boost fuel economy through improved powertrain and aerodynamic performance. Early examples included direct fuel injection and the Valvetronic variable valve-timing system with "by-wire" electronic control instead of a mechanical throttle. Sources expect European versions of the 2013 BMW 3-Series to add several new Efficient Dynamics technologies, but it's unclear which ones might appear on U.S. models or what they would cost. Perhaps the most likely prospect is an engine stop-and-start system like that on many gasoline/electric hybrid vehicles. Reportedly available only with automatic transmission, it uses an integrated starter/generator powered by a lithium-ion storage cell that charges as needed when the brakes are applied. A smaller, lighter service battery helps compensate for the added weight of these components. There's also talk of an oil pre-heating circuit for the engine, transmission, and differential. The idea is to reduce gas-wasting hydraulic friction in these components through faster fluid warmup after a cold start. Some BMWs already boast a so-called Intelligent Alternator Control that engages the alternator only when coasting and braking, this to eliminate another drain on engine efficiency. The new 3-Series may have "on-demand" oil and water pumps as well. Then there's "Active Aero," a series of inner-body flaps that adjust to smooth airflow through the body as well as around it as a way to trim gas-eating wind resistance. Serving the same end is a possible "active suspension" that slightly lowers the vehicle at highway speeds--not a new idea, but a plus in an age of concern about air quality, global warming, and dwindling oil supplies. Speaking of hybrids, BMW was a development partner in the so-called Two-Mode transmission that General Motors now offers in several large hybrid SUVs and pickups; the same basic system is due as a 2010-model option for the big Dodge Ram pickup. BMW, however, favors clean-diesel power for vehicles like the 3-Series as a faster and cheaper route to better fuel efficiency and reduced emissions. As a result, sources think the company's hybrid offerings will be limited to the X6 premium-midsize SUV and to the 7-Series premium-large sedan. And it's unclear when even those might appear, as BMW is now slashing expenses wherever it can to offset sales and revenue losses from the economic downturn. http://consumerguideauto.howstuffwor...-3-series3.htm
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
03-15-2010, 12:00 AM | #3 |
325
Rep 2,663
03-16-2010, 05:11 PM | #5 |
Sauce
77
Rep 2,023
Looks a lot longer, but good. I would think this is pretty acurate.
2009 E90 M3 | Silverstone II | Black Novillo | HRE P40's | Akrapovic Exhaust | Eibach Pro Kit | Jet Black Kidney Grilles | SSII Side Reflectors | SSII Side Gills | LUX H8 Angel Eyes | Macht Schnell Filter | Tecnocraft Envy Charge Pipe
"M3 drivers have no friends." - Jeremy Clarkson |
03-16-2010, 05:59 PM | #8 |
Rep 488
that being said lets anticipate a new 1 series...it will probably be longer making a lot more people fans?!? maybe?
SOLD: 2013 328i Mineral Gray ZMM/ZLP/Heated Seats
SOLD: 2002 325i Jet Black ZPP |
03-16-2010, 07:46 PM | #9 |
Bimmer Love
16
Rep 362
I would be happier with shorter, and NO back seats...I want another option than the z4 as a 2 seater...kind of like the hardcore porsches...a 1er with just 2 seats and CSL options would be a BUY IT NOW thing...now they are going to add a ton of power to the M3, only to be countered by more weight.
03-16-2010, 08:29 PM | #10 |
Rep 1,938
The report makes sense. The 3-series shall be as conservative as we are used to, but bigger and heavier - it is inevitable, considering the average buyer. The idea of preheating oil in the differential is interesting. Those who favor manual transmission should just pray and keep faith.
03-16-2010, 08:31 PM | #11 |
9
Rep 69
03-16-2010, 11:33 PM | #13 |
Rep 1,691
Drives: 911 992 C2S
03-17-2010, 10:29 AM | #17 |
Rep 585
03-17-2010, 04:22 PM | #18 |
student
226
Rep 911
really don't get it. you keep making a car longer,wider. Then what. 2013 you get 3 series equivelant of a 1995 5 series.
Like is it me or is the worlds population getting fatter. |
03-17-2010, 09:31 PM | #20 |
90
Rep 2,707
That is only normal. It is the best way to keep customers engages over a long period of time. As you get older and wanna roomier car you could still keep getting the same model that you initially fell in love with.
zhpregistry.net - ZHP stats and free classifieds.
03-17-2010, 10:55 PM | #21 |
got em' son
Rep 448
Drives: 08 135i sold / 08 E90 M3 sold
when my gf bought her 1 series, i was able to speak to the sales manager. he had told me that the way BMW is moving is in the direction of the 1 series taking over the "small" market of the 3.. then everything is is bumped up. 3 will kinda be what the current 5 is, the 5 will have the 7 series front and the 7 will be redesigned....
