M3 brakes conversion question
01-24-2012, 01:22 AM | #1 |
the mod bug is crawling in my brain
43
Rep 576
I've searched this topic, but have not come up with a definitive answer.
Does anyone know if M3 brakes (calipers, rotors, pads, the whole assembly) would fit an e90 328i? I know for sure it wouldn't fit with the stock 16", but I have 19" wheels (19x9 et36 +5mm spacer fronts and 19x10 et38 +12mm spacer rears) which should clear a BBK. Thanks for you help! |
01-24-2012, 12:12 PM | #2 | |
Rep 1,052
Also, there may be an issue with the hub and the M3 rotor. Just think I remember hearing that but can't be sure. |
01-24-2012, 06:01 PM | #6 |
Rep 3,277
01-24-2012, 06:32 PM | #7 |
43
Rep 576
01-24-2012, 06:46 PM | #8 |
Rep 3,277
01-24-2012, 07:15 PM | #9 |
Rep 3,277
Jason: We fabricated a bracket for the front, and did a whole slew of welding/machining for the rears. We have a bracket ready to sell for the front, but brake bias will be affected without doing something in the rear. Most garages probably won't do the mods required for the rear.
01-24-2012, 07:39 PM | #10 |
Ex-Diesel Driver
63
Rep 2,000
I can sell you a 335 set up... then I can buy my BBK.
FS: HRE Center Caps http://www.e90post.com/forums/showth...post13972317l] |
01-25-2012, 10:37 PM | #11 | |
Rep 3,561
Too bad it's not a simple bracket adapter for the rear; I'm sure we'd have them on the market by now if it was that simple. OP, If you decide to go 335 (which I recommend, they're more powerful than 135 or performance), you'll need the 335 e-brake assembly for the rear as your current one won't work with the larger rear rotors. |
01-25-2012, 10:38 PM | #12 | |
Rep 3,277
01-31-2012, 04:22 PM | #13 | |
43
Rep 576
01-31-2012, 10:09 PM | #14 | |
Rep 1,650
http://www.e90post.com/forums/showthread.php?t=604481 We are talking about a parking brake after all, so this should be plenty unless you plan on some serious rally type driving or parking lot hooliganism. |
08-22-2020, 03:03 PM | #15 |
Rep 6
m3 breaks on a e90 330
hi I have a similar question I was wondering if i can do m3 breaks on my 330i
I want to do the whole set up. rotors calipers pads everything. |
08-23-2020, 09:22 AM | #16 | |
3768
Rep 2,738
There’s plenty of threads already on the forum about the f30 brakes so I’ll let you take it from there.
e90.330girl4.50 |
08-23-2020, 10:33 AM | #17 |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
Buy my 335i brakes.
caliper, m3 brakes, pads, rotors |
