BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 2012 BMW 335i F30: Still the Benchmark @ 0-60mph - 4.7 sec (Motor Trend Video)
Studio RSR
      02-27-2012, 08:55 AM   #1
gatoman39
gatoman39's Avatar
Drives: 2011 E92 335 M-Sport
Post 2012 BMW 335i F30: Still the Benchmark @ 0-60mph - 4.7 sec (Motor Trend Video)
BIMMERPOST
     Featured on BIMMERPOST.com
2012 BMW 335i: Still the Benchmark?
0-60mph - 4.7 sec
1/4 mile - 13.3 sec @ 103.9 mph
60-0 - 109 ft
Lateral accel: .90g
Compare this to Insideline's F30 328i performance test results @ http://www.f30post.com/forums/showthread.php?t=651933.
Text of article:
Expectations run high for any new 3 Series -- almost unfairly so. Our expectations were such that when we found out the new 2012 BMW 3 Series would be slightly bigger, and its power steering system would use a fuel-efficient electric motor, we grew skeptical. Cynical, maybe. And then a 2012 BMW 335i equipped with the optional sport eight-speed automatic ($500; the standard eight-speed automatic and six-speed manual are no-cost options) showed up at our test track. What did we learn? That there's no reason for the roundel faithful to fret.
Benchmarks? Forget the last 335i. This new one actually accelerates at the same pace as the 320-horse, 332 lb-ft 335is -- the one with two turbos and a fast-shifting twin-clutch transmission. Our mere automatic 2012 335i, down a turbo and supposedly 20 horsepower and 32 lb-ft, reached 60 mph in 4.7 seconds and the quarter mile in 13.3 sec at 103.9 mph. That's right on pace with a Camaro SS, assuming it's driven well.
Launching the 335i is a simple matter of turning traction control off, holding the brake while waiting for the tach needle to swing past 2000 rpm, and letting go. The rear tires chatter through first, and shifts happen with who-needs-a-twin-clutch-transmission immediacy. Stopping is equally impressive. The Continental ContiSportContact SSR tires grab insistently at the behest of its 13.4-inch front and 13.0-inch rear brake rotors. The best stop we recorded from 60 mph took 109 feet.
A reminder: This is just a luxury sedan with an EPA fuel economy rating of 23/33 mpg city/highway.
Our test car came equipped with adjustable shocks, thanks to Adaptive M Suspension ($900), and the largely aesthetic Sport Line ($1700), which adds sport-tuned suspension and raises the speed limiter. With these additives, the 335i's best figure eight-lap time, at 25.7 sec, and lateral acceleration, at 0.90 average g, match the Chrysler 300 SRT8's results. But beyond a respectable lap time, the 335i provides truly enjoyable handling characteristics. It can be backed into a corner, it can plow, and it can transition between these two extremes at the driver's preference. It's compliant and friendly.
A reminder: This is just a luxury sedan that seats five.
The 335i seems portly -- the scales show 3586 pounds and a front/rear distribution of 51/49 percent -- but that weight actually matches that of the last 335i coupe we tested. Versus the four-cylinder 328i, it carries 100 extra pounds. Where do you think that weight comes from? A hundred points if you guessed the front axle. The added weight is noticeable after back-to-back drives with the 328i, but equally noticeable is the extra forward thrust the 335i so readily supplies. A slightly heavier nose or more power? Decisions, decisions.
The biggest problem we discovered came from the automatic stop/start system. On three occasions, the system deactivated itself while the car was stopped at a light with the engine off, leaving its driver stuck in neutral with a line of honking, angry drivers rapidly forming behind. This phenomenon happened once to yours truly, and that was all the impetus I needed to deactivate it every time I started the car.
Beyond that one glaring issue, I spent much time on the side of a twisty mountain road trying to find other faults, but all I came up with were nitpicky quibbles. The stitching on the hand brake boot doesn't match the stitches on the hand brake lever. The red accent line that stretches across the dash doesn't look that great. (You can get it in black.) The fascia doesn't come across well in photographs, but it is rather attractive in person, blending cues from the i8 concept car with the svelte lines of the Z4.
Instead of finding faults, I found myself thinking about the smart details BMW has added. Tug the hood release under the dash twice and the hood is unlocked; no fumbling around for the latch under the hood required. With Comfort Access (part of the $1900 Premium Package), if you wiggle your foot under the left exhaust pipe, the trunk pops open, which is a wonderful thing for when your arms are full of luggage.
And they will be. Another reminder: This is just a luxury sedan with 17.0 cubic feet of cargo space.
Expectations run high for the 3 Series because it repeatedly delivers such strong performances. Be it on a test track, a two-lane road, or during a daily commute, this new 335i continues that trend. It's capable enough to be compared to sports cars, but compliant and livable enough to be called "just" a luxury sedan.
      02-27-2012, 09:05 AM   #2
Calmwinds
22
Drives: Everywhere
4.7s?! wtf, I thought it was supposed to be 5.4s or something... I think I might just get the 335i now and not wait for a new motor
      02-27-2012, 09:06 AM   #3
justinnum1
Drives: 2018 330i Msport 6mt
damn
F30 330i Alpine white/Coral red Msport 6MT
      02-27-2012, 09:14 AM   #4
stampchez
stampchez's Avatar
125
Drives: 2013 135is
I like that more than C&D's test!
      02-27-2012, 09:16 AM   #5
Calmwinds
22
Drives: Everywhere
wait, so the 5.4s published by bmw is inaccurate?
I really thought it didn't make sense that a car 80 lbs lighter with the same engine would be slower than previous gen.
      02-27-2012, 09:19 AM   #6
Robin_NL
S0THPAW
Robin_NL's Avatar
8784
Drives: HS M2 Competition
Very nice.
Thanx for sharing.
      02-27-2012, 09:25 AM   #7
7or8
Drives: 09' 335i 6MT MSport
Man that engine sounds good! I love the roar at 1:16!
      02-27-2012, 09:27 AM   #8
Vector Pilot
Vector Pilot's Avatar
Drives: 2014 Z4 28i
N55 is for those who have a need for speed. I'm on the list.
      02-27-2012, 09:43 AM   #9
7or8
Originally Posted by Robin Hood View Post
Very nice.
Thanx for sharing.
Congrats Robin.. you bought a beast!
      02-27-2012, 10:09 AM   #10
jzcrna
Drives: 2019 M2 Competition
Wow!! Nice to see a glowing review of the 335i after all of the great 328i reviews. I cannot wait to receive mine.
      02-27-2012, 10:15 AM   #11
emtrey
emtrey's Avatar
92
Drives: 16 M235IX, 06 Carrera S, 335i
I think the Insideline times were off. I drove 2 different 335i demos and they felt very strong so this review seems more in line.
Can't say its quite as fast as my N54 equipped 135i but the new 8 sp trans makes it quite accepatable now that Mrs. Emtrey is pushing me to buy the first 4 door car I have ever owned in my life.
Awaiting pricing for M sport and will be looking to get one of the early 2013s (Mpsort or sportline) to coincide with my lease end on the 135.
      02-27-2012, 10:54 AM   #12
Weaselboy
Weaselboy's Avatar
76
Drives: 2024 M340i
Nice. Just confirms C&D Mag's numbers were off for some reason.
I just never bought the idea that BMW would come out with a new model with lower 0-60 times than the previous version.
      02-27-2012, 11:03 AM   #13
MaX PL
Drives: M3
isnt it odd that two other publications, three if you include BMW themselves, all achieved low 5's, and Motor Trend somehow runs a 4.7?
i'd love it if MT was right but i think we should wait for a larger sample to confirm this.
      02-27-2012, 11:06 AM   #14
Weaselboy
Weaselboy's Avatar
76
Drives: 2024 M340i
Exact same thing happened with the E90. Car mags got about 1/2 second less than the BMW published number.
I noticed in the video he is torque braking the auto trans to about 2k RPM at launch. I wonder if BMW is testing without doing that?
      02-27-2012, 11:19 AM   #15
emtrey
emtrey's Avatar
92
Each buff mag seems to test differently ( and BMW is notriously conservative)..what I am looking at is relative to the same buff mags test of the E90 335 and 135. I think they all ran in the high 4 sec range 0-60.
seems the F30 335 is very close and not dramtically "slower" as earlier characterized.
      02-27-2012, 11:20 AM   #16
bananachipz
Drives: F30 Mineral Gray 335i
check out 3:05 ... it says it all
      02-27-2012, 11:21 AM   #17
DrivenByE30
DrivenByE30's Avatar
France
595
Drives: '12 F30 Lux 335i 6MT
To all the F30 328i proud owners :
Yes we F30 335i owners can also be proud of our 6Cyl. cars too
      02-27-2012, 11:28 AM   #18
cardsdoc
Drives: 2016 340i xDrive Msport
Crap! I'm coming from an N54 335 and had convinced myself that I'll be perfectly happy with the 328 and save some money (which had made my wife even happier). I'm waiting for x-drive. After seeing this, not sure the performance difference is really that small. I'll have to test drive both but this is going to be tough. The smart choice 328 or the 335 for my Y chromosome needs.
2016 340i xDrive, msport, estoril/saddle/anthracite, blk kidney grills, 400m mixed summer, adaptive m, technology, lighting, cold weather, drivers assistance, enhanced usb
      02-27-2012, 11:36 AM   #19
justinnum1
Coming from an n54 myself, i am more than happy with the power in the 328
      02-27-2012, 11:50 AM   #20
bimmerjph
bimmerjph's Avatar
Drives: 2005 Z4 3.0
Yeah, for some reason Car & Driver doesn't like BMW anymore. I guess they got tired of people whining about how the 3 series wins everything.
In their first review of the F30 they kept talking about how it had all of this body. I find that interesting because literally no other site said that.
      02-27-2012, 11:50 AM   #21
cardsdoc
That's good to hear. Any particular driving scenarios where you wish you had the n5x? What's acceleration like while already at highway speeds? Do you need to get the engine revving high to make enough passing power? In the N54 even when going >70 there is still so much punch just downshifting into 5th gear. I worry about that in the n20.
      02-27-2012, 12:07 PM   #22
KR335
Drives: 2020 M340iX
Keep in mind that the car mags generally quote acceleration times with 1-ft rollout (like dragstrip timing equipment), so the car's already moving when the clock starts, which will result in a faster 0-60. Insideline reports 0-60 using this method as well as an actual 0-60, with the difference usually in the range of 0.2-0.4 seconds. I'm guessing that BMW may be quoting an actual 0-60 time. If you look at their test of the new 328i, you'll notice a 0-60 of 5.9sec, which is slightly slower than BMW's number (5.7) and a 0-60 with rollout of 5.5sec, which is what the mags would have reported. If you take the same 0.4 seconds off BMW's number for the 335 of 5.4sec, you would expect a 5.0sec run as reported by the mags. So the 4.7sec by MT is indeed faster than BMW quotes, but by something more like 0.3sec. And C&D's 5.3sec still looks like an anomaly.
2012 3 series review, 2012 3 series reviews, 2012 335i review, 2012 335i reviews, 2012 335i track video, 2012 f30 review, 2012 f30 reviews, 3 series f30, 3 series f30 forum, 3 series f30 review, 3 series f30 reviews, 3 series forum, 3 series reviews, 3-series review, 335i 0-60, 335i 0-60mph, 335i f30, 335i f30 review, 335i f30 video, 335i quarter mile, 335i review, 335i reviews, bmw 3 series first drive, bmw 3 series forum, bmw 3-series f30, bmw 335i review, bmw 335i reviews, bmw f30, bmw f30 3 series forum, bmw f30 3 series review, bmw f30 3-series, bmw f30 forum, bmw f30 review, f30 0-60, f30 0-60mph, f30 3 series review, f30 3 series reviews, f30 3 series track video, f30 3-series, f30 3-series forum, f30 328i, f30 328i quarter mile, f30 335i 0-60, f30 335i 0-60mph, f30 335i review, f30 335i track video, f30 335i video, f30 forum, f30 forums, f30 review
Search this Thread:
