06-14-2012, 11:52 AM | #1 |
Rep 444
Wheel compatibility between E90 and F30?
I know there have been threads about this before, but they seem to come to vague conclusions. I realise it's a question of offsets etc but one thread mentioned different offsets between front and rears, which makes no sense to me.
According to this website, the E90 and F30 wheels are the same: PCD - 5x120 Center bore - 72.5 Offset - 34 Mounting - 12 x 1.50 One thread somewhere mentioned that the F30 is using M14 bolts instead of M12, but if the "mounting" figure is referring to the bolt then this doesn't appear to be correct. Can anyone confirm that this website's information is correct and that E90 wheels are compatible with the F30? Or if not, can anyone provide references to sources that say otherwise? *looks hopefully for E90Fleet* |
06-14-2012, 01:10 PM | #2 |
General
1571
Rep 29,203
PCD - Same
CB - Same Offset - Different offsets on different OEM F30 wheels 16x7 ET31 16x7.5 ET35 17x7.5 ET37, 17x8.5 ET47 rear if staggered 18x8 ET34, 18x8,5 ET47 rear if staggered 19x8 ET36, 19x8.5 ET47 rear if staggered 20x8 ET36, 20x8.5 ET47 rear if staggered Mounting - 14x1.25 And F30 has taller tyres.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
06-14-2012, 01:45 PM | #3 | |
Rep 444
I'm a bit puzzled about the offsets being different though - I thought they had to be the same? Or do the offsets differ depending on the wheels that the car comes with? To be honest though I don't really understand what the offset measurement really means. Regarding the mounting specs, it sounds like you're saying that the info on the website is wrong? As for the tyres being taller, do you mean the profile is bigger? IE the /xxR figure? (eg /45R or /50R) |
06-14-2012, 02:49 PM | #4 | |
General
1571
Rep 29,203
The F30 has bigger wheel bolts, 14x1.25 (14mm thread diameter) vs 12x1.50 (12mm thread diameter) on the e90. But I'm pretty sure M14 bolts fits through the holes on e90 wheels. Yes, the profile is bigger, e.g 225/45/18 on f30 vs 225/40/18 on e90, so the profile is "5 more" on the f30 on same width tyres.
06-14-2012, 04:38 PM | #5 | |
I plead the 5th.
527
Rep 1,519
The offset number will differ from car to car. Some cars require a higher offset up front + lower offset in the rear while other cars require similar offsets front and rear. Wheel width is also a number to take into consideration. An 18x8 ET35 & 18x9 ET35 will have differing outer and inner positons - the proper front outer position and rear outer position will differ from car to car. Thus there are no universal requirements such as the offset being the same front and rear. Profile number does not necessarily determine the thickness of a tire. Let's use a 225/45/18 for example. The thickness of a tire is the section width (225mm) multiplied by the profile number as a percentage (.45). Thus the tire thickness of a 225/45/18 would be 101.25mm (about 4") thick. So by stating taller tires he means the thickness would be greater, creating a larger outer diameter. E90 18" tire thickness would be 225*.40 = 90mm while 18" F30 tire thickness would be 225*.45 = 101.25mm. So yes, F30's require larger/taller tires |
06-14-2012, 05:20 PM | #6 |
Rep 1,245
We had a E90 come through the shop with the F30 style 397 (18" sportline wheels).
They seemed to mount up fine with no clearance issues even with the taller F30 tires (looked a bit silly with those tall tires though).
03' 525iT stick, 22' 530i
Previous: 20' X3 M40i, 19' 740i Msport, 17' 430i GC, 15' Msport X3 28i, 15' Sportline X1 28i, 13' Msport 328i, 09' Msport 335i, 07' Msport 335i |
07-08-2012, 01:02 PM | #8 |
Rep 223
The above posts both seem to say it is fine to put F30 wheels on E90 cars, but what about the other way around?
I have a set of Forgestar F14 wheels custom made for my 11' 328i, if they can go on an F30, that will make me more inclined to get an F30 in the future. The F14 wheels do need hubcentric rings, but I don't think this is an issue, I am more concerned about the bolts fitting through the wheels. The F14s require thin wall socket to install the lugs. And of course the offsets. My front is 18X8.5 E32, rear 18X8.5 ET26. What do you guys think? Taller tires should not be an issue. And one more thing, is it true that the F30 with M-Sport will have larger disc brakes even for the 328i? Is this true for the E90 also or it is new for F30? |
07-08-2012, 09:37 PM | #9 |
Güten Täg
Rep 161
The fronts should fit, however thats a pretty low offset on the rears so it will be hard to say until we get more real world data to go on.
My best guess is that it will fit in the rear simply because you can get 9" OEM wheels.
2013 F30 328i Sport 6MT MG
1991 E30 318iC 5MT M20B25 swapped Vert Black - gone |
07-15-2012, 11:17 PM | #10 |
Rep 223
Basically my rear wheel will come out 14mm compared to the OEM 18x8 at the rear.
07-16-2012, 01:32 AM | #11 |
Dinosaur supervisor
3033
Rep 4,214
08-17-2012, 01:10 AM | #12 |
Rep 5,197
any info on whether the M14 F30 bolts will fit through factory spec e9x wheel holes? I am assuming it wont be a problem but would like to confirm.
08-17-2012, 06:11 AM | #13 |
Güten Täg
Rep 161
Both are 5x120.
08-17-2012, 08:33 AM | #14 |
Rep 802
As always ... go this this site ... plug in the OEM size and put in the specs for the new setup ... will tell you whether the rim/tire setup will work ... no point asking on here, as its dependant on MANY variables ... and sometimes people will give you the wrong info as well (as they are misinformed themselves).
http://www.rimsntires.com/specs.jsp
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
Machinebuilder278.50 |
08-17-2012, 08:37 AM | #15 | |
Rep 802
08-17-2012, 09:45 AM | #16 |
Rep 5,197
I know that, my concern is whether the actual holes on the wheels are big enough to accommodate the 14mm wide M14 bolts vs the e9x 12mm M12 bolts. it's just 2mm so I am assumings a no brainer yes. but BMW is so uber precise about some things that you just never know.
08-17-2012, 10:04 PM | #17 | |
Güten Täg
Rep 161
I wouldn't chance it without being 100% sure first, 2mm is a big difference.
08-17-2012, 11:11 PM | #18 |
Rep 5,197
^ that's what I was thinking
08-18-2012, 11:04 AM | #19 | |
Rep 17
M12 Bolt - 12mm (0.472") M14 Bolt - 14mm (0.551") BMW Rims Style 162 Hole size 16.13mm(0.635) Given the above this will give you bolt clerance of 1mm or 0.042" which is planty. The clerance with M12 bolt is 2mm 0r 0.0815". Hope this helps
13 F30 335i M-Sport Estoril Blue II w/ Black Lthr. ZWR,2PF,ZOX,ZKD,ZWP,ZWQ,508,2VF,840,8TH,655 and 2NH
08-18-2012, 11:31 AM | #20 | |
Rep 5,197
hey, thanks! that's great news!
09-27-2012, 03:17 PM | #22 |
Rep 5,197
I wonder about that too.
