07-06-2012, 07:57 AM | #1 |
39
Rep 300
Put DCT in neutral without starting car?
Ok, granted I haven't tried this very much yet but I tried for a few minutes the other day and failed. Does anyone know of a way to put a DCT equipped car in neutral without starting the car?
Sometimes when I leave early - or late - from my garage I feel bad for the people trying to sleep which live directly above my garage. If I could put the car in neutral and roll it back out of the garage it likely wouldn't shake their condo as much. I tried putting the key in the ignition and pushing it in once, but no matter what I hit on the gear selector it stayed in park. |
07-06-2012, 08:01 AM | #2 |
Rep 1,664
Drives: E82 N55 DCT
Engine has to be started.
07-06-2012, 08:18 AM | #3 |
Resident Kerbalnaut
478
Rep 10,703
Lies. At least on my auto it is.
Try this. Hit the starter button without your foot on the brake to wake up the car. Then drop it in neutral. That's how you do it with a step - a DCT should be the same way. Let me know if it works for you! |
07-06-2012, 12:34 PM | #5 |
39
Rep 300
Hmm, I didn't try hitting the start button without my foot on the brake. I figured that pressing in on key would have done the same thing. I'll try it on my way home from work.
07-06-2012, 12:38 PM | #6 |
Rep 655
Stupid question from a life-long manual car driver:
Your battery dies and your car comes to a stop on railroad tracks. You have no power at all and the DCT is in gear or park (don't ask why - this is a hypothetical dramatization ). How do you go to neutral to push the car off the tracks? |
aye_B_090.00 |
07-06-2012, 01:18 PM | #7 |
Rep 1,664
Drives: E82 N55 DCT
Okay, I figured it out... It's amazing what an owner's manual can do for you...
Start the car Shift into neutral Turn off car Leave key in ignition Transmission will still be in neutral Roll away Press park to put in park when car is stopped Or remove key and it goes in park automatically
07-06-2012, 01:24 PM | #8 | |
Rep 563
This is a good case for "automatic car wash mode". From Page 224 of the manual: Before driving into an automatic car wash, perform the following steps to ensure that the vehicle can roll: 1. Insert the remote control into the ignition lock, even with Comfort Access. 2. Engage transmission position N. 3. Release the parking brake. 4. Switch off the engine. 5. Leave the remote control in the ignition lock so that the vehicle can roll. - It switches back to P after 30 minutes or if you remove the key from the slot. But what's not stated in the instructions above is that you still have to turn the car on between steps 1 and 2. Once it's in Neutral you can turn the car back off again and it will remain in Neutral as the instructions above indicate (dropping back to P if you remove the key). I just tried this with my own car and I could not get it to go into Neutral without first igniting the engine. It does seem odd, so maybe there's some other trick that I'm not aware of. (Edit: Looks like bogart found the same.)
2012 135i convertible, DCT, Black/Beige, HK, Prem, M sport, no nav.
07-06-2012, 02:22 PM | #9 |
Rep 1,664
Drives: E82 N55 DCT
What I haven't tried is whether or not you could start the car while it's rolling away in neutral...
I'm guessing you can't, because your foot has to typically be on the brake to start it.
07-06-2012, 03:07 PM | #10 | |
39
Rep 300
07-06-2012, 05:25 PM | #11 |
Rep 1,664
Drives: E82 N55 DCT
Only way to do it haha. If you have a garage you could do the following:
Start car that night Put in neutral Leave key in Shut car off Leave in neutral and key in Close door but don't lock Put something under the tire so it doesn't roll away or pull e-brake if brakes are cool Close and lock garage In the morning it will hopefully still be in neutral Keep extra key outside car just in case
07-07-2012, 01:05 PM | #12 |
Rep 563
I don't think that will work either. I think it would drop into Park after 30 min.
07-07-2012, 06:20 PM | #16 | |
Rep 7,047
With RWD, if you can't get it in neutral, the the tow truck can hook it from behind, make sure the front wheels are straight, lift the rear, and tow it up the flat bed ramp. If front wheels can't be turned straight and car won't go into neutral, then you need a flat bed that has dollies to put under the wheels. Lift the front wheels off the ground, insert dollies under tires, do same for rear, now car can be moved onto flat bed. For AWD that is locked with no neutral capability, it too needs a flat bed. |
sburkeatqmi9.00 |
09-05-2015, 11:12 AM | #17 |
828
Rep 2,232
So I've got a hunch with how to put the dct in neutral, and it involves the mysterious Allen key included in the tool kit. Has anyone been able to do it yet? I haven't had too much time to experiment and figure it out but I think I'm close. Any of the regulars recall seeing this figured out? gregthegr8 Dackelone , anybody else?
Chainlightning3.00 sburkeatqmi9.00 |
09-05-2015, 01:51 PM | #18 | |
63
Rep 157
1. remove DCT shift trim (pry off carefully with flathead screwdriver) 2. locate allen socket near top left of shifter. you will see a red cap looking thing next to it (no need to touch the red cap) 3. insert appropriate allen key into socket 4. rotate counter clockwise. The first quarter turn feels light, but then it gets heavy. Instinct is to stop when it gets heavy, but you have to push past the resistance of the allen socket. once you push through it, you'll hear it click and if done correctly, you'll see the car in neutral on the cluster. From there, it'll stay in neutral as long as you don't remove the key or put it in park. I'm fairly certain you do need to at least have battery power to do this, but no need to start the car. Hope this helps! |
09-05-2015, 01:54 PM | #19 |
63
Rep 157
09-06-2015, 10:57 AM | #21 | |
Rep 653
Yup this is the only way with the car turned off. Ive done it twice now.
2012 DCT 135i
PURE S2 JB4/mhd Fuel-It! direct port meth injection check out my youtube channel here |
Chainlightning3.00 |
09-06-2015, 10:58 AM | #22 |
Rep 653
The red button re engages the trans
2012 DCT 135i
