07-20-2012, 11:54 AM | #1 |
16
Rep 69
F25 Coding Wishlist & Findings
Wanted to start this thread for pure coding options since others are dedicated for installing software and finding cables, etc.
Here are some items (wishlist) I would like coded on the X3: Gauge Needle Sweep on startup Ambient Footwell Lighting Auto release of Parking Brake without Seatbelt on Sport Steering setting without Perf Control switch Digital Speed display (no HUD) Foglights stay on with Highbeams Remember last heated seat setting (always) Be able to adjust where air flows without taking fan out of automatic Radio to scroll song/artist info on preset screen instead of having to go to station info screen. I know some of these codes are on various cheat sheets but want to verify if they will work on F25 chassis. Please post and findings and your own wishlists so we can find more exciting options! |
07-27-2012, 07:50 AM | #3 |
16
Rep 69
I was able to verify the F10 Cheat sheet on the link below works for F25 as well.
http://www.f30post.com/forums/showthread.php?t=696777 I successfully coded the following: Seat Belt gong removed Remote/Comfort open & close mirrors, windows, sunroof. Remote close tailgate Remove disclaimer on startup & PDC Fog lights on with high beams Remember last heated seat setting always Sport Display Digital Speed in gauge cluster Tire Pressure and Temp display I know there are tons more coding options and hopefully they will keep being discovered. Please post here successful F25 codes! |
08-01-2012, 07:59 AM | #4 |
16
Rep 69
Did more coding last night and did soft on for welcome lights including fog lights. Like how they soft off also in sequence. Also adjusted when low fuel warning comes on but can't confirm until tank gets empty.
What didn't work on F25 was: Gear Display in Sport mode (still shows DS) Does not remember last heated seat setting (over few hours) |
08-01-2012, 08:35 AM | #5 |
Rep 11,857
Drives: MY24 G01 AW Msport
whats purpose of high beams, fogs stay on?
or when you high beam the fog lights turn on/flash in sequence with high beam? |
08-01-2012, 08:45 AM | #6 |
16
Rep 69
Fogs on with high beams give you a much better view of the road because you have both near and far bright! Like the old cars that had separate bulbs for low & high beams and kept low beams on with high beams.
08-01-2012, 11:04 AM | #9 |
Rep 11,857
your not suppose to drive with high beams on
08-01-2012, 12:29 PM | #10 | |
Rep 449
F25 X3 xDrive 35d M Sport Alpine White, Black Nevada Leather, Speed limit info, TV, Prof. Nav & Speakers, HUD, M Sport steering wheel, Sport gearbox, BMW Apps, Internet, VDC, Comfort with Powered boot, Hi-speed synch, VSS, Top View, Electric tow-bar, Heated steering, Storage, DAB, Heated electric seats, Moonroof, Adaptive High beam assist Xenons, Servotronic, Performance control, etc.
08-02-2012, 05:03 AM | #12 |
Rep 15
Radio coding
OK So I know this one will be very difficult to get a response on, but here goes...
Still new to the coding issue and I am in the process of getting the E-sys and other programs d/l and installed. I too want to "fix" a few things, like the auto start/stop, tailgate closing and DVD motion hack. BUT here is the biggie! I have a new US spec X3 and I live in Germany (work for the Army). I want to change the frequency spacing on the FM radio. My unit is for the US and the spacing is 200khz (I believe), i.e. 101.1 101.3 101.5 etc. In Europe they use 50khz spacing i.e. 101.1 101.15 101.2 101.25 101.3 etc. May radio stations use the "even" frequency numbers (101.2 101.4 101.6 etc) that my radio cannot get (at least very well) I have been told that this can be changed in the coding, but of course, no one in the US has this issue and probably no one even knows where it is coded. So I'll just ask and HOPE that someone might have a clue. (fingers crossed) THANKS for ANY help/support/advice! |
08-02-2012, 09:55 AM | #13 | |
9
Rep 37
HU_CICHB 3002 AUDIO_TUNER_TRAFFIC DAB_LAENDERVARIANTEN this is a country specific adoption of the frequency band and has the following options nicht aktiv australien ece korea kanada singapur there are also three FM band settings, but no description. thaey are as follows with the defaults from my vehicle. FM_BAND_LW nicht aktiv FM_BAND_MW aktiv FM_BAND_KW nicht aktiv
1974 2002 that was fun
1986 325 cinnabar red black leather cool 1994 325 smooth as a gravy sandwich 2011 X3 after a long dry spell, the fun is back. 2012 X5 Diesel -- loving it! |
08-02-2012, 10:21 AM | #14 |
Rep 15
Radio frequencies
Thanks for the assistance
Its certainly worth a look. Kinda odd that "USA" is not listed - but perhaps its the same a Kanada. "ece" COULD be Europe - it kinda fits. Traffic info frequencies are definately different in Europe from the US - that would explain that one. Generally in Europe, the abbreviation LW is for Long Wave bands (below our AM), MW is medium wave (our AM) and KW...?? I have no idea. (SW would be Short Wave - but of course, its not on that list). Many/most aftermarket radios here have the LW band. I have a new Kenwood aftermarket unit in my Passat with that. Will keep looking.... Thanks again!! |
08-02-2012, 11:34 AM | #16 | |
9
Rep 37
HU_CICHB 3002 RADIO_COUNTRY (Radio Country for FM/AM Radio) variants include us ece japan australien Update: I changed this to ece and it gives even numbered frequencies.
1986 325 cinnabar red black leather cool 1994 325 smooth as a gravy sandwich 2011 X3 after a long dry spell, the fun is back. 2012 X5 Diesel -- loving it! Last edited by jdg857; 08-04-2012 at 11:20 AM.. Reason: UPDATE |
08-04-2012, 01:38 PM | #17 |
Rep 15
AWESOME!!!!
Even numbered frequencies are what I need! Thanks - I will try to get that to work for me. Also If you want to have a bit of "fun" you might try going into the AM (MW) wave settings and also set to "ece" and see what you get. IF I am right the spacing between the AM radio stations will be 9khz apart rather than 10. If it works correctly you will get frequencies such as 1107, 873 and so forth - rather than 1100, 1110, 1120, 870, 880 etc. In Germany that is how the MW band frequencies are spaced. Last edited by Randeyman; 08-04-2012 at 01:49 PM.. |
08-04-2012, 02:22 PM | #19 |
Love All
170
Rep 740
08-04-2012, 02:24 PM | #20 |
Love All
170
Rep 740
08-05-2012, 12:03 PM | #21 |
21
Rep 92
Anyone know of any auto shops in Staten Island, NY that can code BMWs? I heard of Mobile-Addictions, gonna call them tomorrow, but was wondering if anyone has any additional suggestions?
