**First Time Tuners** Start Here** Official Misfire Thread| Updated!
10-11-2013, 03:16 PM | #199 | |
Boooost!
70
Rep 793
Drives: 335i
The old plugs gapped around .030 with 63k on them.
JB4 Stage 2 | Injen CAI | BMW PE | AR Catless DP | Alpina TCU Flash | Eibach Pro Kit | Custom TCKline Koni's | 19" M359 Wheels | DWS Tires |
10-11-2013, 03:46 PM | #200 |
3442
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
I'm assuming my source of .044 gap is just incorrect at this point. I've actualy googled mutliple sources and for the OEM plugs they won't even list the gap. For other aftermarket options like NGK and Denso they come up with .031 and .044.
I found one site that listed the gap for the Bosch ZGR6STE2 and it says .7MM which is .027 which would be spot on. Sigh. I guess nobody knows at this point. Perhaps it's not the gap. |
10-11-2013, 04:30 PM | #201 |
Boooost!
70
Rep 793
Drives: 335i
BMW shows that I have shadow codes for ValvaTronic what is that?
10-11-2013, 04:31 PM | #202 |
3442
Rep 79,211
10-11-2013, 04:34 PM | #203 | |
Boooost!
70
Rep 793
Drives: 335i
I guy on Bimmerfest had said something about one of the lever arms under the valve cover could've popped off What does that mean? Also I noticed that my temperature gauge gets up to about 230 to 240°F, is this normal? The reason I ask is because I'm in a loaner car right now it's a 2013 335i which is the N55 engine just like mine and it stuck at 180? On a side note: I just got the DME update done at the BMW dealership and the exhaust got quieter for sure in fact I have the secondary cats removed at the shop the other day and basically negated most of the sound. I'm really upset about that. The sputter got a little worse also.
10-13-2013, 10:49 PM | #204 |
Boooost!
70
Rep 793
Drives: 335i
I I did a compression check to make sure the cylinders were all equal and here's the results.
Compression results: Cylinder #1 - 139 psi Cylinder #2 - 138 psi Cylinder #3 - 138 psi Cylinder #4 - 141 psi Cylinder # 5 - 139 psi Cylinder # 6 - 140 psi
10-13-2013, 10:50 PM | #205 |
Boooost!
70
Rep 793
Drives: 335i
Cylinder number five misfire came back. I have no idea why but here's a picture of the Vanos system.
10-16-2013, 08:41 PM | #206 |
Boooost!
70
Rep 793
Drives: 335i
My issue finally is resolved. Thanks for the help Jeff!
10-17-2013, 10:50 AM | #207 |
Rep 978
10-18-2013, 06:57 PM | #208 | |
3442
Rep 79,211
I assumed the intake manifold was torqued to spec cause he said it was but it turns out the original spec was off and it required more torque. On a side note this proves again how useless those smoke tests are. Unless they pressurize that system to atleast 20 PSI they are bogus. They only find huge leaks. Last edited by Jeff@TopGearSolutions; 10-18-2013 at 07:02 PM.. |
10-18-2013, 11:54 PM | #209 |
Rep 1,677
I have about 90K on vanos solenoids. No codes or anything. Should they be replaced or simply clean them out?
10-30-2013, 12:21 PM | #210 |
52
Rep 165
Drives: 2011 335is
I just wanted to add my experience to this thread for posterity sake.
I was having consistent misfires after installing Cobb. These misfires eventually began to occur when the cobb was uninstalled as well. It began to be a real pain in the ass because the dealer techs couldn't get the car to misfire on command like I could. After a couple of dealer visits and them not being able to find the problem, they finally found something. Valve spring was the culprit. Hope it helps anyone else with similar issues. I would also like to add that I installed, un-installed, and re-installed my Cobb flash several times over the course of trying to figure this out and the dealer never mentioned anything about having a tune. |
11-07-2013, 04:12 PM | #211 |
Rep 35
Curious if we can switch injectors with a different cylinder to see if misfire follow? Would coding the injector be necessary? I'm tempting to buy a new injector but would like to make sure. Misfire cylinder 4 and just replaced plugs with oem. Thanks
-I also switch Coils with same cylinder code on wot only. |
01-08-2014, 08:16 PM | #212 |
Rep 1,059
I need some help guys, I have a misfire code P0301, cylinder 1, I have new plugs, like 10,000 miles on them, I also tried swapping coil packs between other cylinders and the code is still the same P0301, I cleared the code and it came back like a month later. I also noticed bad gas mileage, like 14-15 mpgs... any ideas???
01-12-2014, 06:35 PM | #213 |
из Кремля
15
Rep 164
Hi all!
I've read all of the thread and others on this forum, however, my issue is a little odd.... I don't have any misfires... I don't have any check engine signs (other than de-cat issue) But everytime i go WOT, car suddenly looses power... I've seen some guys here had same issues, but it was always paired with misfire... What would you think i should do? Since i don't know the cylinder that's causing problem, swapping coils wouldn't work to diagnose... had my HPFP replaced under warranty 10.000 miles ago. Changed all plugs ± 6.000 miles ago. Currently i have only 20.000 miles on my car, but it's '09 - i barely drive it (could it be the reason for those failures?) I'm pretty sure my z4 has all the same components as you guys have....its n54 with jb4, full exhaust, dci, DCT... no meth Would appreciate any valuable input. |
01-15-2014, 04:53 PM | #215 | ||
3442
Rep 79,211
01-18-2014, 02:10 AM | #216 |
9
Rep 38
Had the SES light come this past week. Dealership narrowed it down to cylinder 2 misfire. Was told they need to replace all 6 injectors because they only have the new version of the injector available? PT# 13538616079.
They said I could try to source the old injector if I wanted. Can anyone confirm this? What is the older injector part #, would it be the one in the DIY (# 13537585261)? Planning on following the DIY and changing them out myself. Wondering if I should bother changing all 6 with the new part# or get the older injector and just replace the one misfiring. There was a recall performed on my car back in 2011, my car fell between the build dates of the SIB 10-13-14, but the injectors didn't match the problem injectors so were never changed out by dealership. |
01-18-2014, 02:34 AM | #217 | |
9
Rep 38
Was doing some more digging and looks like Vassillalov answered my question. There is a new Generation of injectors that aren't compatible with gen 1. So my question would be what is recommended, do all 6 with gen 2 or just 1 with gen 1 . Car is has 60000 miles.
01-18-2014, 12:14 PM | #218 | |
3442
Rep 79,211
Pay now or pay later. |
01-19-2014, 06:29 AM | #219 |
Mad Linux Guru On The Loose
1131
Rep 5,404
Drives: 2008 335i Sedan, 2023 M3
Actually,
I've been running gen2 mixed with gen1 injectors in my car just fine. I have replaced injector number 4 in my car with gen2 injector. The part number ends on 261-11 which stands for integration level 11. The coding procedure is exactly the same. The car runs fine. So, you absolutely CAN mix injectors even in the same bank of cylinders.
