Audio Table of Contents: Upgrading? Start HERE!
01-19-2016, 09:34 PM | #199 | |
Rep 3,969
IB is more difficult with fold down seats, but definitely doable. I'm sure a shop can install it for about the cost of a custom enclosure. As far as SPL, IB is more efficient than a sealed enclosure, and sounds a heck of a lot better than using a standard fabricated box. Next best thing after IB is a corner loaded enclosure, but you're limited to a single 10 or 12" sub in a very small enclosure.
Many people like the Bavsound speakers running off the L7 amp. I'm sure that would be a big improvement. I would not replace the underseats, instead hook them up to a 2-channel amp with about 75W each, high-pass them at 55Hz, and you will be very happy. Quote:
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
02-13-2016, 07:07 PM | #200 |
43
Rep 133
I've got an e60 with the hifi sound and my factory amp seems to cut out here and there when I have the music cranked (bass cuts out). I'm thinking of upgrading that factory amp but I'm not sure where to start. I believe the amp drives only the two underseat woofers in my car because when I unplugged the amp and played music, there was no bass. The amp i'm talking about is located on my left wheel well.
Would I just have to buy Technic's harness and a mono amp of some sort? Would appreciate some help. Last edited by zoppp; 02-13-2016 at 07:17 PM.. |
02-17-2016, 09:44 AM | #201 |
48
Rep 260
this is an amazing thread! thank you for all the hard work on it. after securing my e92 355i yesterday this thread has given me everything i need to upgrade the sound system! now to get Technic to ship me a harness to the UK
02-27-2016, 06:10 PM | #202 | |
16
Rep 147
Drives: BMW 118D M-Sport Le Mans Blue
http://www.e90post.com/forums/showthread.php?t=660927 If your interested PM me. |
02-28-2016, 09:10 AM | #203 | |
Rep 4,121
03-01-2016, 10:14 AM | #204 |
84
Rep 256
Did things change in 2013 for the E92 coupe? I have 4 mids (2FR, 2RR), two tweeters in front, 2 under seat woofers, and an amp under the trunk tray. Also have navigation if that helps. Is this HiFi or base?
03-01-2016, 08:35 PM | #205 | |
Rep 4,121
03-04-2016, 10:07 AM | #206 | |
48
Rep 260
Amazing install unfortunately its the wrong harness for me as i have the Hi-Fi system that is already amped in the boot. Also my install will be staged and not big bang like yours as i dont have the funds for that I plan to replace the current OEM amp with a JL amp to power the current OEM system. The next phase will involve upgrading the front components and under seat mid-ranges (haven't decided with what yet) Then a matching set of components for the rear and a JL sub and mono amp in the boot. Then if i can secure the funds, the CIC retrofit |
03-16-2016, 06:10 AM | #207 |
Rep 1
Does this same audio table apply to E60? I have a -08 E60 with the Hifi option (676), and it really needs an upgrade, but I couldn't any info about the amp and signal that is used in E60
03-18-2016, 09:09 AM | #209 |
29
Rep 95
I have an E60 and 6spdcoupe and mathematics helped me out with the install. Just reach out to them.
03-18-2016, 08:38 PM | #211 | |
Rep 4,121
04-12-2016, 05:01 PM | #213 | |
Rep 4,121
Connects2 which is A European company probably has harnesses most similar to those provided by technique |
05-11-2016, 11:34 PM | #214 |
Rep 128
Good evening all! read through alot of this am a little confused. The dealership listed my system as Hi-fi but i don't have tweeters so im 99% sure its just the base system and was listed incorrectly. But i got to wondering if maybe the system wasnt coded to hifi and thats why they listed it like that?
Is there a way to see which coding im running? |
05-12-2016, 02:59 AM | #215 | |
466
Rep 2,779
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
05-12-2016, 11:21 PM | #216 |
Rep 13,134
If you look for the amp in the trunk it should be
If you look for the amp in the trunk it should be obvious
if its the base system because there won't be and amp. Also if you are in the US the only year the base systems were issued is 2010 through the first half ob 2011.BMW stereo types http://www.e90post.com/forums/showthread.php?t=352586 http://www.e90post.com/forums/attach...2&d=1266451970 http://www.e90post.com/forums/attach...2&d=1260829447 http://www.e90post.com/forums/showthread.php?t=343673 http://www.e90post.com/forums/showthread.php?t=138949 http://www.e90post.com/forums/attach...1&d=1209780605 http://www.e90post.com/forums/attach...1&d=1209780865 http://www.e90post.com/forums/showthread.php?t=641323 http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/ http://technicpnp.com/menuDiagrams/d...e90_92_93.html http://www.musicarnw.com/page-2/ http://www.e90post.com/forums/attach...4&d=1278871872 |
06-13-2016, 03:01 PM | #217 | |
Rep 7
Not too worried about the remote lead as I have an Audio Control Lc2i which will do signal sensing turn on. Read through alot of the links not completely clear on install. Tried once already and it wasn't kicking on though I rammed the wires into the back of the connector for the BMW amp |
07-26-2016, 02:36 PM | #219 | |
Rep 4,121
07-27-2016, 01:28 AM | #220 |
Rep 6
