02-21-2024, 11:24 AM | #215 |
Supreme Allied Commander
3893
Rep 54,605
Drives: F80 M3
The basic front only kit consists of a custom upper spring perch, Swift springs, and Swift thrust sheets.
The complete kit will come with rear Swift springs, Swift thrust sheets, and a pair of rear height adjusters. For those who wish not have to mess with machine work on the front lower spring adjusters, we also have a kit with machined adjusters included. The bottom photo is he front kit mounted on KW struts, one with the stock upper mount, and the other with Vorshlag camber plate. ***Slight machine shop work is required for the front lower spring perch, which can easily be done at a local mahine shop. Alternatively, you can purchase new machined KW adjusters from us as well.*** A wide variety of spring rates are available to choose from or we can make a recommendation for you. Camber plates(Vorshlag) is optional but recommended if you are attending HPDE or track days. |
