BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > BMW F30 3 Series Coding DIY - Code Auto Start Stop, DVD, Folding Mirrors, Etc.
GetBMWParts
      06-15-2012, 07:42 PM   #199
omarliendo
Drives: 2012 335i Sport Line - Red
Originally Posted by johntchow View Post
after you extract all 24 rar files it will package together a folder with 7 subfolders. you need to move those 7 subfolder into the C:\ESysData\psdzdata\ folder
AHHH! i got it. Thanks, Johntchow! (Now i just need to wait for the car to get here!!)
      06-15-2012, 10:21 PM   #200
svache
svache's Avatar
Drives: 2012 F30 328i
Originally Posted by topgear66 View Post
Svache, i am looking at the "Installation" file for the E-sys and i need clarification on step 5. I did download all of the 24 "2_46.3_psdzdata.partX" files but now i need to copy the 7 folders that are inside every single one of the 24 "2_46.3_psdzdata.partX" folders into C:\ESysData\psdzdata\ folder?
Am i reading this correctly?
Yeah, I think you read it correctly. You basically need to unrar/unzip the whole bunch (all 24 of them, just do the first one and the rest goes automatically) and then copy the contents to that folder.
In the end it should look like this (I also opened the 'SWE' folder as you need to copy as well from that one directory to the other):
edit: lol I didn't realize the thread was on a new page already, guess my answer is a bit double now lol
F30 328i Luxury w/ Mojave metallic, beige interior (timeline)
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread
      06-15-2012, 10:55 PM   #201
omarliendo
haha it's ok, twice for redundancy
This visual was extremely helpful but i do not see your "EST" folder... where did you save that one?
Also... how do we nominate you to be the most helpful user?
      06-15-2012, 11:06 PM   #202
svache
svache's Avatar
lol the EST folder is on a different drive on this computer.. I installed e-sys here first without reading instructions.. so when it needed the token, I was too lazy to move it at the time
It's in the correct location on my 'coding laptop' though (C:\ESysData\e-sys est)
Most helpful? lol, thanks but it's just that I like to spam the forums at times
      06-16-2012, 03:59 AM   #203
svache
svache's Avatar
btw, just added a new version of the cheat sheet.. nothing too much has been added, been too busy with my new home the last few weeks. What I did add was the tail lights on with DLR's, the weatherband radio (dunno why it was not active but it's good to have, especially in risk areas imho), and something else but I forgot what it was again lol
      06-16-2012, 11:19 AM   #204
Silver F30
Silver F30's Avatar
Drives: F30 Sportline
So.....as mentioned before, I work at a BMW dealer in the service department. I thought I had an "in" by being able to use the ICOM unit that is plugged into the OBDII and has an ethernet cable coming out of it. Unless someone knows something I don't the ICOM will not work. It does not generate an IP address so my computer does not read it. Has anyone had any experience with the ICOM? I also tried to use a D-CAN which is what they use on older model BMWs and no luck either. Looks like I am going to have to build one schucks! And I agree with TOPGEAR66, SVACHE should be awarded some kind of an award. Thanks, SVACHE!
      06-16-2012, 04:39 PM   #205
demge01
demge01's Avatar
Drives: F30 320ed
Hi just checking is the correct location as follows:
C:\ESysData\est\Code Away.est as that is the location described in E-Sys Installation PDF.
Or is it C:\ESysData\e-sys est
I think I'm getting there slowly! Cheers.
      06-16-2012, 05:17 PM   #206
svache
svache's Avatar
Hehe it doesn't really matter where you put it, really. Like I said, I have it on a complete different drive on this computer.
The thing is, once you're in e-sys, one of the next steps is to actually point e-sys to that file. As long as you tell e-sys (I believe it's done in the options but it's stated in the instructions) where to find the 'code away.est' file, then it will all be ok
      06-16-2012, 08:09 PM   #207
Poor Knight
Poor Knight's Avatar
Drives: 2016 BMW 340i Luxury line
Really intrigued by the Auto Start Stop default change. - that is something I would definitely do. Is it easy to switch so it is off all the time unless you turn it on?
2008 M3; 2010 X5; 2012 335i; 2016 X3; 2016 340i
      06-16-2012, 08:52 PM   #208
svache
svache's Avatar
Yeah it's pretty simple to do, both coding and the actual switching.
My personal preference is going out to the memory based setting, this way you can set it to whatever you want to have it. The car just turns on with the last used setting (whether that was on or off). The other setting is default off which is basically the same as it does from factory, but then always off, meaning you would have to turn it on if you want to make use of it.
      06-17-2012, 02:36 AM   #209
demge01
demge01's Avatar
Drives: F30 320ed
Great! I've set the E sys options tab to find it in the correct place.
My folder layout and directory matches the one posted above (except mine includes est between CAF and Etc)
Think I've done it right
Just waiting for my cable to arrive now.!
      06-17-2012, 04:06 AM   #210
svache
svache's Avatar
looks like you're all set once the cable comes
      06-17-2012, 06:15 PM   #211
dcshoes23
Drives: 2012 328i
Hey Svache, I have a couple of questions from your video.
1. How do you get the dvd to take up whole screen? I tried going to advanced options and turning zoom on but it still doesn't go across the whole screen
2. How do you display the reverse camera without putting the car in reverse?
Thanks!
      06-17-2012, 07:23 PM   #212
svache
svache's Avatar
Thanks!
Hiyas! Let me answer them
1. I actually did this by going to the advanced options and turning on the zoom function. It works, however, only when the dvd is already in widescreen.. if the original DVD is in 4:3, then it will just zoom to 16:9.
2. This was done through coding. I chanced the necessary functions and then it was just a matter of pressing the PDC button. If it goes to top-view first (if you have this), then you need to change to the rear-view camera by selecting the option in the iDrive (second option from the top for me, you can see me chance this in the video).
I hope this helps
      06-17-2012, 07:39 PM   #213
dawgnut01
Drives: F30 335i Sportline
Got my cable the other night - purchased from ImSW1 - and it works great. Highly recommend buying the cable from him if you don't have the time or skills to do it yourself. Quality work.
Anyway, completed a couple coding sessions and all have worked but one.
Svache or anyone else in the know - for ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN - my understanding is that it should pull the mirrrors in if I use comfort access to lock up. It doesn't. In your notes you refer to _FB for keyfob and _PA for doors...what does this mean? What am I missing?
Much thanks for all of your work on this project.
      06-17-2012, 10:15 PM   #214
svache
svache's Avatar
Glad everything worked out
As for the mirrors. The thing is, ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN doesn't do anything by itself. In order for it to work, it needs either, or both, KOMFORTSCHLIESSUNG_FB and KOMFORTSCHLIESSUNG_PA, to be enabled.
The _FB one refers to closing with the keyfob, the _PA just to the doorhandles. With me, the _PA was already enabled and the first time I tried to do this, the mirrors only folded when I used the doorhandles. Now, after enabling the _FB one, it also worked with the keyfob.
I hope this explained a bit
      06-18-2012, 05:49 AM   #215
Beluci
Drives: F34 330d
Can you give me a cheat list for the f01 ? I just want to unlock dvd by driving.
      06-18-2012, 03:34 PM   #216
svache
svache's Avatar
I'm sorry, I have no F01 available to me to look through those codes. I can only look in the F30 codes myself to see what can be done, the F10 codes were provided by others who coded their F10's.
The code for DVD in Motion should be similar as the code for the F10 and F30 (they were also the same).
      06-18-2012, 04:15 PM   #217
demge01
demge01's Avatar
Drives: F30 320ed
My cable arrived today
Coding tomorrow hopefully!
      06-18-2012, 05:01 PM   #218
Raspartan
42
Drives: F15 X5
Originally Posted by Raspartan View Post
Didn't seem to have any effect but I think I need to test for one more day. Here in Toronto the RDS traffic is only broadcast Monday to Friday 6am - 7pm, so tomorrow is the last day of the week that I can test.
Definitely no effect.
Svache, would you mind sending me a copy of your CAFD_000000F9_007_001_013.ncd file?
      06-18-2012, 05:11 PM   #219
svache
svache's Avatar
lol you should ask them by name, the files are named differently on every car.. but I'm guessing you want the HU_CIC CAFD? (the first part of the file names seem to be the same, my HU_CIC is called CAFD_000000F9_006_009_011.ncd )
      06-18-2012, 05:53 PM   #220
Raspartan
42
Drives: F15 X5
Hm, learn something new every day. Yes please!
3 series coding, 3 series f30, 3 series f30 coding, 3 series f30 forum, 3 series forum, 3-series forum, 5 series f10 coding, ass, ass disable, auto start stop, auto start stop disable, bmw 3 series coding, bmw 3 series f30, bmw 3 series forum, bmw 3-series f30, bmw 3-series forum, bmw 5 series coding, bmw auto start stop disable, bmw auto start stop disabling, bmw coding, bmw coding directions, bmw coding diy, bmw coding instructions, bmw diy, bmw diy forum, bmw f10 coding, bmw f30, bmw f30 3 series, bmw f30 3-series, bmw f30 coding, bmw f30 forum, coding 3 series, coding f30, coding f30 3 series, disable ass, disable auto start stop, disable bmw auto start stop, disabling auto start stop, disabling bmw auto start stop, f10 5 series coding, f10 coding, f30 3 series, f30 3 series coding, f30 3 series forum, f30 3-series, f30 3-series forum, f30 coding, f30 forum, f30 forums
