02-16-2015, 06:21 AM | #2245 | |
4-6-8
234
Rep 990
02-16-2015, 07:19 AM | #2246 | |
General
64716
Rep 24,950
Remember what I was saying... The problem starts when the S65 leaves the German factory but possible also not... When clearance is optimal when leaving the factory ... bearings are in condition like in the pics of MilehighM3 , car from 08 with 102K miles on it and easily he was able to run another 100K with those bearings ! And always used the 10W60 TWS/Castrol...?!?! => ( For the M1 guys ) That's why I was saying ... The S65 is actualy a German lottery.... In other words...some are already crap when leaving the factory with only a few miles on it and predestined to blown, and others are outstanding such as MilehighM3 ! And exactly this is going on with the S65 engine !
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
02-16-2015, 07:57 AM | #2247 | |
Rep 3,456
Drives: Harrop E90 M3
02-16-2015, 08:02 AM | #2248 |
Rep 3,456
Correct. He's been contemplating adding a supercharger and wouldn't let him move forward without a little preventative maintenance. Not because I believe there's a problem with the S65, but because it makes sense to do on any engine if adding 50% additional power at 100k. Especially on an engine with elevated lead on the last blackstone. Apparently that lead was mostly all fuel related.
02-16-2015, 08:32 AM | #2250 |
General
64716
Rep 24,950
02-16-2015, 08:36 AM | #2251 | |
Rep 3,456
02-16-2015, 04:20 PM | #2252 | |
274
Rep 2,665
Drives: Goggomobil
Bearing failures are a myth
F86 X6///
02-16-2015, 04:47 PM | #2253 |
General
64716
Rep 24,950
Read above # 2246 . That's the problem .
02-16-2015, 04:57 PM | #2254 |
274
Rep 2,665
Drives: Goggomobil
I know Philippe
F86 X6///
02-17-2015, 07:17 AM | #2255 |
Rep 977
Kawasaki and Regular Guy,
For those of us with the VAC bearing replacement, we are wondering what the photos look like of your tear downs as compared to Maliks. I know you are busy but please let us know when you post those up so we can go back and look. So now we have some tear downs with VAC bearings that look good, and others RG said not so good. Based on what I have read, VAC coated bearings success seem to be a bit of a crap shoot depending on your tolerance stack. If you are on the high end of the stack, you just made your life worse off as the bearings wear you will likely do crank damage and you might still be a grenade waiting to happen. If you are in the middle of stack, you might get away with this for a while until a better solution can be found but you risk some main bearing/crank damage due to hardness or coating coming off and circulating in the motor before it gets picked up by the filter. If you were on the low end of the stack, you could be good for life with this set of bearings and maybe a shift to lighter weight oil. Am I interpreting this correctly?
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... |
02-19-2015, 09:24 PM | #2256 | ||
Rep 10,407
Your prior and ongoing blatant denigration of engineering and science in general, along with prior egregious errors in how bearing loads scale with rpm causes me to strongly question this claim. Perhaps you can elaborate. Tell us which field of engineering and which school. This is not an attack. If you make a claim, be prepared to discuss.
We have recently been discussing statistics, either standard deviations or more simply just min/max deviations. I've asked for such data probably a dozen times here in this thread. Summarize the results and cite a source or post a scan or a link. What is an "acceptable" standard deviation (or even just the maximum spread) in a bearing clearance (and or for rod journal sizes). It's no surprise that industry insiders like you may know how and where to get such data. Me and most of the other folks here don't know where to get this. If you really understand this issue then you can also pretty well immediately tell us all - if the spread or tolerance stack in clearance is the real "issue" or if it is variation in journal sizes or variation in bearing thickness? A standard deviation of 1/10th of a thou in rod journal sizes seems like a pretty well controlled manufacturing tolerance to me... One that is probably produced using standard techniques of statistical process control.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | Last edited by swamp2; 02-21-2015 at 01:14 PM.. |
03-05-2015, 09:35 AM | #2257 |
Rep 1,673
Just going to let everyone know that a test has been completed on Rod Bolt clamp load of the new stock bolts vs 2 different Carrillo, the WMC and the really expensive CARR bolt. Will try and get the data posted later this weekend. Just another tool to help in the problems we see with rod bearings.
Electronics Junkie, Engine Builder.
03-05-2015, 09:42 AM | #2258 | |
Rep 1,678
Drives: 2011 MCB E92 M3
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
03-05-2015, 09:44 AM | #2259 | |
Rep 10,686
03-05-2015, 10:03 AM | #2260 |
Rep 1,673
Yes official sequence was used
03-05-2015, 10:13 AM | #2261 |
Rep 1,673
I did not have any 2000 bolts on hand. The WMC bolt is better than the 2000 though. The rank is CARR>WMC>2000
03-05-2015, 02:18 PM | #2262 |
Rep 3,303
Great update.....more info is needed on rods.
Btw, funniest thing I have heard on the forums is SWAMP insinuating Kawasaki doesn't know what he is doing. PRICELESS. Reminds me of the days I first got banned when Shiv tried to claim he didn't blow up engines when one of his first blow ups WAS AT MY DEALER who I am friends with the SM. Since shiv paid lots of money to Bimmerpost, guess who got banned? Exactly. This is why we lost guys like LeMans Blue.... Cheers, e46e92
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
03-05-2015, 05:16 PM | #2263 | |
Rep 5,508
He's banned on the Evo forums!
Auto Detailing Enthusiast!
03-05-2015, 06:12 PM | #2264 | |
Rep 1,673
03-05-2015, 09:58 PM | #2265 | |
Rep 10,407
All I can say that if you read the entire thread there are some key things Kawasaki got guaranteed, 100% wrong on relatively simple things concerning how engine internal dynamic loads scale with rpm. Things he go so very very wrong that it, along with his ongoing denigration of engineering and science, lead me to believe he is a very good engine builder, working for a very good company, but with no formal engineering education. Notice his claims and unwillingness to answer simple basic questions. I just can't get over the irony of this whole situation... 1. Some problems observed with stock parts. 2. Folks rush in with the coated or peened bearing "solution". 3. Most jump on the band wagon that coated bearings the "the shit" and "the solution". All this despite the fact that they have less clearance. 4. I ask for ANY evidence whatsoever that these "solutions" are better and what happens from both the vendors and fanboys - UTTER SILENCE. 5. Engine(s) with coated bearings have now been disassembled at very low mileage showing no improvement to bearing wear. Surprise, surprise. 6. Now the sheep are lined up ready to purchase another "solution" with ABSOLUTELY ZERO TESTING of the parts and also no testing nor verification rigorously establishing the cause. It sucks but real engineering and real testing are quite expensive and real engineering isn't being done here, not even close. Obviously folks are going to spend their money they way they wish.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
03-05-2015, 10:02 PM | #2266 | ||
Rep 3,303
But $$$ talks around here, I was called a liar since member of car would not step forward, obviously, because the dealer was covering under warranty....so why on earth would he sell the dealer out if he was being helped. But I was called a liar and told to stop causing problems....you know the drill around here. Cheers, e46e92
