DIY - Register new battery
07-11-2018, 09:26 PM | #221 | |
2185
Rep 2,807
So you've gotten 2.5 years running it in AZ with the 90Ah profile? For what the battery costs, that wouldn't be too bad. It was actually cheaper than the H7. I guess not many cars can fit such a huge battery. I got it registered right away with the Foxwell tool. I've been trying to decide whether to leave it in as a 90Ah or change it. Was convinced it was somewhere between 81 and 86 then saw you post. Guess I'll toss a coin.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
07-13-2018, 10:34 PM | #222 |
Rep 19
ooh,for BMW battery registeration.I provide this collection website,include:
INPA Register BMW 7 Series New Battery Register a new BMW Battery after replacement by Rheingold ISTA. Rheingold ISTA Register New Battery for BMW F10 Check here: https://www.car-auto-repair.com/tag/...-registration/ hope it helps! |
08-26-2018, 04:10 PM | #223 |
Rep 15
Hi,
i have change my battery for a agm 80ah. My old battery was a 90ah acid one. I used ncs expert, edit klasse_batterie with a 80 ah_agm parameter, Write it in the man file. Register with tool32, but when i use INPA to read the ibs parameter, i can see 91 ah (so a 90 ah_agm battery) but not a 81 ah. I do again all the steps, check all, but i can not read the write parameter in inpa (81 ah). Any idea ? Thanks for your help |
08-27-2018, 11:10 AM | #224 | |
Rep 1,173
12-21-2018, 10:55 AM | #226 |
32
Rep 180
I keep getting an error when trying to register So frustrating as the battery install took under 15 minutes and I've been working for 2 hours to register it. I've tried all of the MEVD17kw.prg, MEVD174k.prg, MEVD176k.pgr and MSD80.prg. I have a 2012 F10 535xi N55. I don't have MEVD172kw.prg as referenced in Appendix A. Any idea what I'm doing wrong?
Rather than STATUS OKAY I get: STATUS = ERROR_ECU_SUBFUNCTION_NOT_SUPPORTED__INVALID_FORMA T I'm trying to use TOOL32 since I already have it and don't have ISTA-D yet. Getting that is more of a hassle than I can figure out right now, too. And it seems I shouldn't really need it. Last edited by Toad335; 12-21-2018 at 11:01 AM.. |
12-21-2018, 01:17 PM | #227 | |
2185
Rep 2,807
Have you tried it in INPA? It's easy to find and I think it works.
12-21-2018, 11:05 PM | #228 |
Rep 13,134
If you have an f30 you need the F30 daten files.
Most of the INpa downloads are set up for e90's only. Is there and F30 coding board? Don't know much about f30's but and esys cable has been mentioned when people use them. https://www.bimmerforums.co.uk/forum...a-fxx-t412793/ Last edited by ctuna; 12-21-2018 at 11:15 PM.. |
05-19-2019, 06:24 PM | #229 |
Rep 664
I got a H8 battery from AAP with 80 AH about the same as OEM. I installed it and hooked it up to INPA but there is no power module so I tried running the job in Tool32.exe and it says status OKAY. Is my battery registered?
05-19-2019, 11:17 PM | #230 | |
Rep 4,109
When you press F5, Status > F5, IBS/PM > F5, Batterietausch Registrieren (translated: "Register Replacement Battery"), ALL that does is enter the mileage shown on the odometer the instant you pressed "F5". You CAN use INPA to clear/Reset the "Histogram" which is the last 5 days of SOC & SOH, but that will be automatically overwritten in the next 5 days anyway, so NOT critical. Histogram Reset is NEXT menu item after Registration (DME > F5 > F5 > F6, Histogram). You CANNOT use INPA to change (1) Battery TYPE, or (2) Ah rating settings in the DME. Both of those are significant for proper charging of the battery by the alternator, and also for battery life, but the vehicle will operate fine without changing to correct settings. Use NCS to change settings ("coding"). If you replaced a 90 Ah FLA battery with an 80 Ah FLA, you probably will get approximately normal battery life & function WITHOUT changing to 80 Ah setting (IF 90 Ah is what is shown as current setting, as viewed using INPA above), BUT you should change the SETTING in the Power Module of the DME using NCS Dummy or something simple to use similar to that. If you changed battery TYPE (FLA to AGM or vice-versa) then even MORE reason to change setting in DME. I'll attach the NCS screen that shows the choices of settings to the next post, so as NOT to mess up margins of this one. The actual screen you will see when connected to your vehicle will have "checkboxes" with the current setting being "checked" and changing is basically like using a Windows dialog box for changing settings. George |
05-19-2019, 11:29 PM | #231 |
Rep 4,109
NCS Dummy Battery Type (Klasse Batterie)
Here is NCS Dummy Screen showing possible battery settings
This if for MSV80 DME as used in 328i/xi Other Models may have CAS Module used for Power Module & Battery Type & Ah rating (Klasse Batterie), so also check CAS Format & Options available are basically same whether DME or CAS (?) I have 328xi with N52K engine & MSV80 DME, so MSD80 on N54 & Modules related to N55 likely are different George |
05-20-2019, 08:42 AM | #232 | |
Rep 664
https://shop.advanceautoparts.com/p/...000%7CL3*15597 It is the same type of battery as oem (non-agm). The oem is 80ah. This battery from the site says Reserve Capacity: 135 min which gives me 81ah. I installed it yesterday and connected INPA and it shows me this So no need to code/change anything in NCS right? So I ran the job in Tool32 and in INPA hit F5, Status > F5, IBS/PM > F5, Batterietausch Registrieren. So i'm done right? Last edited by JunkyardDogg; 05-20-2019 at 08:53 AM.. |
05-20-2019, 10:59 AM | #233 | |
Rep 4,109
You appear to have "mastered" the subject of Battery Replacement. You could run "< F6 > Histogramm Reset" to "initialize" the PM for the new battery. That's found immediately after < F5 > Battery Registration. That should clear the data for the last 5 days in the right column of the screen you attached (MSD80 Power Module Info Field 2). Translation can be necessary when using INPA, as many of the Fault Definitions and other technical terms are in German, and Google Translate is very helpful for that purpose: https://translate.google.com/#view=h...te&sl=de&tl=en Whoever translated the version of INPA you are using got in a hurry. If you look at the "Info Field 2" you attached, note that the Histogram data on the right column shows 6 lines related to "Start Capacity" the first line is "current" or at the moment start capacity, and the next 5 lines are "one day ago" up to "5 days ago." "Aktuell" is the word used in the original German, which can mean both "Current" AND "Actual." Since ALL 6 lines are "actual" readings -- just the last 5 are 1 to 5 days ago -- the best translation of aktuell for this purpose is "current." That's NOT a big deal, but if you look at the NEXT 6 lines related to "Charge Status" or Charge Condition, note that the last 5 lines ALL read "1 day ago." That SHOULD read the same as the corresponding 5 lines above, namely 1 day ago, 2 days ago, ... 5 days ago. The data value is correct, but the "tag" or description translation is INCORRECT. Anyone using INPA should be aware that in many cases the English translation was done by well-meaning volunteers who were trying to get something useful out there for people like me who only know ONE language: "Americanese." However, stuff happens, and someone who speaks both German & English once told me "German is a concise language." I take that to mean than one word in German may have different meanings, depending upon context. Example: AKTUELL = current, latest, actual, relevant, etc. Likewise: DRUCK = pressure, print, press, push, etc. I still use an older (mostly-German except for some menu items) version of INPA which I took the time to translate myself for the simple reason that there ARE "variations" in the translation. INPA is a powerful diagnostic tool, and I would encourage ANYONE who wants to understand HOW his E9x works, or WHY it is NOT working as intended, to learn how to use it to (1) read & clear fault codes and FF Data using F4, Fault Memory; (2) Read Parameters in real time using F5, Status; or (3) Test and monitor functions with Activations, using F6, Activations (Steuern). Hope to see MORE forum members increasing and sharing their INPA skills & knowledge on this forum. George |
05-22-2019, 07:43 AM | #235 |
39
Rep 145
Moving post to this thread:
I used this process: Register Battery: 1. Open Tool32 2. Datei > SGBD, Gruppendatei Laded > Select MSD80.PRG > Click Open 3. Highlight steuern_batterietausch_registri 4. Job > Job Einmal Ausfuhren (run job once) and get: ERROR_ECU_CONDITIONS_NOT_CORRECT_OR_REQUEST_SERVIC E_ERROR Could this be a software version mismatch? I have an MHD stage 1 tune, could this be an issue?
2008 E90 335i • Jet Black • Black Dakota • Brushed Aluminum
Steptronic • Cold • Premium • Sport • Comfort • Nav • Logic 7 How to import a BMW into Canada without getting rear ended Last edited by Modmike; 05-23-2019 at 01:59 PM.. |
05-24-2019, 11:01 PM | #236 | |
Rep 664
07-14-2019, 04:33 PM | #238 |
Rep 782
12-29-2019, 07:22 AM | #239 |
Rep 13
Hello, I replaced an AGM battery a month later, but INPA still shows State of Health (SOH) value 0.00. How and when the car determine the SOH? Thank you. (I replaced the same type battery...AGM 900A 90Ah).
05-26-2020, 10:19 PM | #240 |
#thatsanicemovebro
202
Rep 3,920
Drives: E92 M3 LSB/Black 6MT
Hey all
got a 61 AH mini battery to save weight coding it into DME - coded CAS thru NCSExpert, changed 90 to 60 ah_agm - re-read ECU and it's well labeled/coded - registered new battery via ista - also registered via tool32 - when i check on ista as well as inpa, it says 86 AH (it was previously written 90) even though it's coded in NCSExpert CAS as 60 any ideas? thanks **update Changed VO in CAS and NFRM Was only able to change to A070 (70ah) Tried 55 and 60 didnt work Then i recoded the CAS. Tried 55, 60 and 70 Then registered it after each time When then checking battery info in inpa and ista, when i code CAS to 55 or 60, it reads 86. When I code to 70, it reads 70. Seems to me you can't code a lower AGM value. Anyone have anything to add or suggest that is different so the car sees the proper 60 ah value? Thanks again |
05-27-2020, 02:20 PM | #241 | |
30
Rep 285
https://www.e90post.com/forums/showthread.php?t=1338302 You might be able to get away with 55ah. |
06-01-2020, 01:50 AM | #242 |
24
Rep 48
Drives: 2008 E92 335I Coupe
just replaced 5 year old die hard today with this H8 from pep boys....$167.99 after $18 core return and 4 year free replacement. took all of 5 minutes to register AND code with Bimmergeeks Protool.
