08-21-2021, 05:53 PM | #221 | |
Rep 3,997
Where as the 6piston calipers (CCB & M2 Comp) have a removable bracket on the calipers that a custom bracket can replace. Look at a picture of the calipers and you'll understand.
DrFerry6734.50 |
08-23-2021, 03:39 PM | #222 | |
Rep 636
Drives: 2012 Space Grey e92 M3 ZCP
08-27-2021, 12:35 AM | #223 |
Rep 546
Just did the c63 caliper + freak parts adapter for 380mm. Install went smooth but the pedal feel isn't as firm as I would like. Time to do stainless lines and reflush the system. But overall looks great and stops good
2011 E92 M3 AW DCT
IG - rod.bearings |
08-27-2021, 04:50 AM | #224 | |
Rep 523
I've done about 600 miles since installing my setup, followed the bedding in procedure EBC recommends and they are performing great. I'm considering switching the textar F80 rear pads on EBC Yellows too. Only down side is the dust from the Yellows |
08-27-2021, 08:13 AM | #226 | |
Rep 546
2011 E92 M3 AW DCT
IG - rod.bearings |
08-27-2021, 10:24 AM | #227 | |
Rep 3,997
Air is still trapped in the system, I've had that happen when opening the system.
09-08-2021, 09:19 AM | #229 |
Rep 636
Does anyone know if the CTS V calipers are an option? Seem to be plentiful and a great price point for a 6/4 caliper set.
https://www.ebay.com/sch/i.html?_fro...pers&_osacat=0
09-08-2021, 11:51 AM | #230 | |
Hey, where have you been all my life?
684
Rep 1,400
Space Fox1042.00 |
09-08-2021, 03:28 PM | #231 |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
I am sure this has already been said but the chance of not messing up your brake bias is basically impossible slapping on random calipers. Extremely unlikely you are going to have the same diameter pistons and the same number. Brake Bias is very important. I never understand why more people aren't concerned about this?
I would just buy a used BBK. They also hold their resale value so when you part out you can probably get back what you paid for them. Street pads work with them just fine. Just as large and shiny as any of the calipers you are going to take off any other vehicle and then slap on. But most importantly designed for your vehicle. edit: A used BBK can be 3-4k vs sourcing 4 calipers from another vehicle, getting the correct mounting brackets etc, SS lines, spending all that money, time, and cash to knowingly throw off your brake bias and not being able to stop any better just for looks? I don't get it. A used BBK makes much more sense for only a little more money and again, great resale value.
09-09-2021, 07:55 AM | #232 |
Rep 636
So it looks like the C63 front calipers are the ticket w/ a better pad sweep on the F8x rotors
SilverSlug684.00 |
09-13-2021, 11:25 AM | #234 |
Rep 3,997
too bad the piston area is so far off and will throw off the brake bias.
09-14-2021, 10:08 AM | #235 |
Slow.
3782
Rep 7,152
Too bad people never worry about it. But hey big flashy calipers, at least they look like they should stop faster.
09-14-2021, 10:19 PM | #236 |
17
Rep 66
Hi! Has someone been able to fit Maserati Ghibli 6 piston calipers on the E92 M3? Can you post some pictures of the adapters? Heard that it is an easy fitment. All the best!
09-15-2021, 08:40 AM | #237 | |
71
Rep 63
There are options like the Alfa/Ghibli calipers with similar piston area that affect the brake bias no more than BBK kits do. It is beyond me why people slap on big calipers that do throw off this bias and make their cars brake worse. But there is valuable information in this thread and cost effective ways to get a decent BBK with calipers from another vehicle. |
09-15-2021, 08:41 AM | #238 | |
64
Rep 72
09-15-2021, 08:42 AM | #239 | |
71
Rep 63
They are nearly identical to the alfa calipers, and can work with the freakyparts bracket, but require some machining. I'll post photos when I'm done |
09-15-2021, 07:28 PM | #240 | |
17
Rep 66
In my case (speaking for myself, not looking for anybody's approval of course, just sharing why I choose to do it), I am looking for stopping consistency. Big brake kits will not make you brake faster. But during track or extensive braking, stock calipers do fade. This is the main reason why I am looking for an upgrade. Your point is valid, which means you wouldnt do it. Nonetheless other points are valid as well. Personally, I dont give a *** for looks, but I do feel that (havin taking care of tires and pad compounds) under repeated braking, I do feel brake fading. all the best! |
Space Fox1042.00 |
09-15-2021, 07:30 PM | #241 | |
17
Rep 66
So, you are fitting the Ghibli ones? Good stuff... leaning towards that route! |
09-20-2021, 07:44 AM | #242 |
Rep 636
How far off are we talking? Would paired w f8x rear calipers help bring the bias back in to an acceptable range?
