10-28-2013, 08:34 PM | #221 | |
Rep 1,848
I think I need more front camber though with the Ventus TD's. The outside edge of the front passenger side is nearly corded while there is plenty of tread from the inside to 3/4's of the way across. I am going to flip them on the rims and try to get one more weekend. |
10-29-2013, 07:56 AM | #222 | |
Track Junkie
Rep 38
How have the TDs lasted for you compared to NT-01s? I've only got 5 heat cycles on mine (~25 laps total) so I can't assess yet if there is a noticeable drop off in performance after x number of cycles and how long the tread will ultimately last. All I know is for a treaded tire they are some sticky mofos! |
10-29-2013, 09:20 AM | #223 | ||
37
Rep 381
Feel like I made some good progress but there is more time to be had in T2&3, the sweeper and gut check. Next time! I'm just happy I kept it out of the mud and off the wall. The last turn took a long time to dry out and I had a couple butt clinchers there. Also, I noticed that the car was very sketchy on the drive home Saturday night (I had adjusted the suspension at the track that morning). Turns out I had 7/16" toe out! No wonder I was so unstable under braking at the track. I blame this on my cone killing incident!
10-29-2013, 07:53 PM | #224 | |
Rep 1,848
10-29-2013, 08:19 PM | #225 | ||
Rep 8,077
Drives: 11 E90 M3 Individual
I had a revelation in the sweeper last time I was at MSR Houston CCW. You don't need to turn in from the left entering the bus stop. The middle works great as well. Quote:
I find the grass is much easier on the tread.
2018 F30 320iX Melbourne Red
10-29-2013, 08:55 PM | #226 |
Track Junkie
Rep 38
Cold pressures were 28 +/-1psi, I tweaked a couple tires after taking temps and can't remember which ones. I don't know hot pressures cause I don't check them if I'm taking temps. But sounds like your issue is more down to camber than pressure unless you were running extremely low pressures which I doubt.
10-29-2013, 09:06 PM | #227 | |
Rep 1,848
10-30-2013, 06:55 PM | #228 |
Rep 8,077
Did you rotate tires? I get worse outer edge wear on my rear tires.
11-16-2013, 07:51 PM | #229 |
Rep 5,396
Tws ccw
First day running this direction at tws and first day on track with m3 (performed great!) 2009 m3 dct Mods -ad08r tires on Rac 19s -dinan x pipe -rest is stock, traction off 2:08 |
11-16-2013, 08:17 PM | #230 |
Grown Azz Man
430
Rep 3,021
Great first run.....glad to see you back in the M3 camp .........Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
11-16-2013, 08:31 PM | #231 |
Rep 5,396
11-16-2013, 08:53 PM | #232 |
Grown Azz Man
430
Rep 3,021
We're looking at dates in January or February. We need to let everyone make it through the holidays...........Phil
11-25-2013, 02:29 PM | #233 |
Rep 1,245
MSR CW 11/23/13
1:56.48 (damp)
03' 525iT stick, 22' 530i
Previous: 20' X3 M40i, 19' 740i Msport, 17' 430i GC, 15' Msport X3 28i, 15' Sportline X1 28i, 13' Msport 328i, 09' Msport 335i, 07' Msport 335i |
11-25-2013, 05:38 PM | #235 |
Rep 1,470
11-16-2013
TWS CCW E92 M3 DCT 75F 2:05.24 Heat cycled out RS3s
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
11-25-2013, 09:12 PM | #236 |
37
Rep 381
Txmtrhed, 2.00.06, 11/16/13
track: TWS CCW mods: JRZ RS-1, Hankook RS3, PFC-08 car: 1M Was finally convinced that the Hankooks on the front were heat cycled out after 60+ sessions. Combined with new rear tires I was pushing like crazy. New RS3's for the front are on their way.
11-25-2013, 09:27 PM | #237 | |
Rep 8,077
bigjae1976, 1:55:75, 11/24/13, TWS CW
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue Last edited by bigjae1976; 11-25-2013 at 10:11 PM.. |
11-25-2013, 09:41 PM | #238 | |
Rep 1,470
11-26-2013, 08:46 PM | #239 |
37
Rep 381
Jae, I love the JRZ's, they have been a great street/track shock that are actually more comfortable than the OEM shocks at my street settings and yet I have a lot of adjustability for the track. The RS-1's are a single adjustable unit but if you're thinking about JRZ's for your e46 I would consider the dual adjustable version (RS?). Got mine from Bimmerworld.
The only caveat is that I'm getting some clunking in the right front since my last track event two weeks ago. Don't know what it may be but I need to tear into it this weekend. I'm thinking it's the GC camber plates.
12-21-2013, 12:20 PM | #240 |
Rep 8,077
My GC plates clunk too. I meant to get a ride with you a MSR...forgot. Wanted to check out your suspension.
bigjae1976, 12/15/2013, MSR 3.1, 2:27:43
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue Last edited by bigjae1976; 12-21-2013 at 01:34 PM.. |
12-21-2013, 01:20 PM | #241 |
37
Rep 381
Jae, I've decided that it's not the GC plates but the Powerflex bushing in the right front thrust rod (front lower control arm) making noise in cold temps. Now that it's warmer everything is okay though I'm thinking about going to the BW bearing setup.
