BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > BMW M Performance LSD for 335i and 435i. Pricing and Technical FAQ.
GetBMWParts
      05-08-2020, 10:20 AM   #221
Boostedphil698
Boostedphil698's Avatar
Drives: 2015 BMW 435i Xdrive MSport
2015 BMW 435XI  [0.00]
2009 Honda Civic  [0.00]
Originally Posted by mholder View Post
I don't know about the 335i/435i but I just had the M Performance LSD installed in my AT 2017 340i in January 2020 and absolutely love it. It has completley transformed the handling. I also have the MPPSK and M Performance Suspension.
Unfortunately, BMW discontinued the LSD for the automatic transmissions 335i/435i.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily)
      05-08-2020, 11:58 AM   #222
Jvac
Drives: 2015 335i rwd
Here's a recent post of a forum member who did the wavetrac
https://www.bimmerpost.com/forums/sh...php?p=25898738
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
Poochie9107.50
      05-15-2020, 03:36 PM   #223
aps
aps's Avatar
337
Drives: 2018 M3 ZCP
Only put 150 miles on it, but the stability at high speeds has been pretty incredible. Just highway driving so far, but so much easier to take these big sweeping turns at 90+. Can't wait to start pushing it in the canyons.
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5
2013 Glacier Silver F30 335i (sold)
      05-17-2020, 02:48 PM   #224
Polo08816
Drives: 2014 335i M Sport
Your limited slip differential is providing you greater stability at higher speeds on a highway? Maybe if you have 2000 horsepower and can break traction at 80mph.
      05-17-2020, 03:12 PM   #225
aps
aps's Avatar
337
Drives: 2018 M3 ZCP
didn't mean in a straight line. as I said around big curves. maybe it's just more of a confidence in feeling thing.
      06-24-2020, 12:41 PM   #226
itsrichierich
Moto Lover
itsrichierich's Avatar
187
Drives: '19 BMW S1000XR
If anyone has one for sale in Socal for a F30 335i RWD auto transmission, let me know
      06-28-2020, 09:25 PM   #227
Logicoeur
Logicoeur's Avatar
994
Drives: F30 335i xDrive
Originally Posted by itsrichierich View Post
If anyone has one for sale in Socal for a F30 335i RWD auto, let me know
Rwd and xdrive use the same lsd part #. Just matters between auto and manual transmission. Good luck with the search
      06-29-2020, 10:41 AM   #228
itsrichierich
Moto Lover
187
Thanks for the heads up, didn't know that. Got an auto trans here.
      01-24-2021, 05:26 PM   #229
Logicoeur
Logicoeur's Avatar
994
Originally Posted by JT50 View Post
I know you can get it as part of the dynamic handling package, But Does anyone know if you can get the M-Sport Diff or any other LSD for the G20 330i So far I haven't been able to find anything
Wrong forum to ask. We all have the F series
      03-11-2021, 02:56 AM   #230
Paintballover
Drives: BMW 2001
Originally Posted by Gio72 View Post
An 80% locking is harder to manage and not for all drivers.
Anyone knows the price of MP LSD in Europe?
Same issue
      10-16-2021, 11:56 AM   #231
tphss
das Eichhörnchen
tphss's Avatar
46
Drives: e92 M3, F32 435xi
Does anyone know if the new part number of the LSD 33-10-8-659-989 fits the N55 435i with automatic transmission?
The original 33107555607 is discontinued for years now.
The only other option I see for N55 F30/32 seems to be aftermarket diff builders that use a non-oem diff (Wavetrac, Quaife etc) and you need to send them your original core (differential).
      11-12-2021, 05:56 AM   #232
rallas
Drives: 2016 435i
I am wondering the same thing. From what I can tell it looks like this one has 3.08 ratio versus 3.15 of the factory diff or the old 33107555607 diff.
What is the impact of the slight difference in ratio other than the ~2% difference in indicated speed? Will the DME freak out and throw codes?
      11-12-2021, 10:34 AM   #233
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
IIRC vehicle speed is read at the transmission output shaft. Now would the difference in the diff ratio impact stability control? I don't know.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      11-12-2021, 12:17 PM   #234
SuperLomi
204
Drives: 2013 335i M-Sport
According to realOEM, the 33108659989 part number is a 2.81 final drive ratio.
Also, drive shaft for the pre-vs post LCI car's are different - 435i = 1509mm, 440i = 1504mm.
Axle shafts are also different part numbers between pre- and post LCI automatics. It seems like LCI made the axles common between auto/manual and manual pre-LCI, but pre-LCI auto have a unique part number.
So the known issues with putting a manual diff into an automatic are driveshaft length is different, and axle shafts are different length, and some dust seals are different. Based on that known incompatibility, I believe this part number will not work for pre-LCI automatics, without additional parts being changed, or potentially custom work being done.
Logicoeur993.50
      09-15-2023, 07:37 PM   #235
DaReTo
ots mods mst air,wagner ic,stage1 ots tune
Drives: 335I mperformance
I have the 2013 n55 f30 just before launch control[tried it just made a bad smell lol]
uprated air flow for intake and intercooler,dropped plugs to 1step colder iridium,replaced v/c {leaking}and remapped ots with a carbon clean...whats peeps opinion 76k..wanna look after this girl
      02-01-2024, 03:31 PM   #236
rlesko
Drives: F30 335i
2012 335i  [0.00]
Managed to pick up a used M perf LSD, seller said had about 40k miles on it. I'm planning to drain and fill with new fluid, but is there any other maintenance I should be aware of or consider doing? It is off the car so now would be the easiest time.
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo
