06-13-2020, 03:29 PM | #2421 |
Rep 7
Very blessed for this extensive thread right before purchasing but was wondering if anyone installed this carplay module with a backup camera as well? I wasn't able to find an install video with both the carplay module and camera together. I was also wondering if I should go with the camera currently in the cart or if the quality is noticeable with a higher quality camera such as this?:
https://www.amazon.com/Reversing-Cam...tronics&sr=1-1 Thanks! |
06-13-2020, 03:43 PM | #2422 | |
Rep 843
It works and looks fine, but then I don't ever look at it when parking so for me I just added it as it was an option my car was missing. The handle itself (seems to be the same with any that you buy) is not made correctly though, so you have to use alot more force to open the boot than you do with the original bmw handle. |
ap921.50 |
06-13-2020, 05:08 PM | #2423 | |
56
Rep 256
They're probably all manufactured by the same company unless you buy am expensive one, although probably end up being the same too |
cossie1624.50 |
06-13-2020, 05:19 PM | #2424 | |
Rep 7
FransL3.00 |
06-13-2020, 05:26 PM | #2425 |
9
Rep 55
Your cable will be different to mine as mine is CIC so only the 4 pin plug but I just joined the original cable and the new cable together to act as an extension cable, works fine. I assume you could do the same?
06-14-2020, 04:15 AM | #2426 | ||
Matusov
14
Rep 43
nitsuj1756.00 |
06-14-2020, 09:31 AM | #2427 |
Rep 2
The original cable is routed from the screen into the dash behind the steering wheel And comes out from behind the glove box into the HK unit. When I unplug it from the screen there isn’t enough length to route that end down to the Mimi box, and I can’t pull the cable out as it is tied in behind the dash. So my only option was to keep the original cable In the screen and plug it to the Mimi out and use the Andream cable to go from the HK to the Mimi in. But I get the feeling the cables are not interchangeable in this way. If not, I’ll either not install the Mimi or may try to find an oem cable to use in place of the original one which I then would just leave in place unplugged. Not sure if anyone else had there cable routed this way, as all I’ve seen On all makes and models are easily accessible cables, but it came as a surprise.
06-14-2020, 09:42 AM | #2428 | ||
67
Rep 56
Don't worry mate I had same issue.. Mjust unwrap the sticky tape on the cables and it will work. As with all customers I advise them 90% of this is cable management to aid you in install. It's got to a point now where I never remove anything except the headunit to fit it. No glovebox messing about etc |
06-14-2020, 02:20 PM | #2429 | |
86
Rep 144
06-14-2020, 02:51 PM | #2430 |
Rep 1,217
I wasn't aware of that. Good to know for anyone else with the basic iDrive controller.
06-14-2020, 03:02 PM | #2431 |
17
Rep 59
Finally got my unit working, didn't have to use the iDrive controller cable or the aux one
SDK: 25.0.0.5.6.0.0.0 CUST: v2.1.0.3.gpe,c MCU: 20.4.16.19 HW: BMW_CIC Just need to find the right settings to remove the echo during calls. |
06-14-2020, 05:38 PM | #2432 |
Rep 23
What's the newest version for andream mmi? Also where can I download it?
I'm on 20.4.2.14. Also my Siri button doesn't work. Only volume on the steering wheel Nvm all on page 1heh |
06-14-2020, 06:09 PM | #2433 |
56
Rep 256
06-14-2020, 06:19 PM | #2434 |
Rep 23
Yes I did. I forgot it on the phone and the I drive
06-14-2020, 06:19 PM | #2435 |
9
Rep 55
Hold down the iDrive controller for a couple of seconds to activate Siri.
I can’t use the steering wheel voice button because it activates Siri and the iDrive voice. I’d like to know if there’s a way to disable voice in iDrive. |
06-14-2020, 07:47 PM | #2436 |
Rep 23
I fixed all of it. Updated to latest firmware and the 8bit selector was up. Needed to be down. Steering wheel wheel and voice all work now.
06-15-2020, 03:59 AM | #2437 |
94
Rep 289
Latest status from andream regarding DPI issues:
"Friend, the upgrade file is not available. We have urged them to test already. Please wait patiently, thanks a lot" Im pretty sure there multiple andream companies that dont talk to eachother and we are just running around in circles.....soon 6 months since i have told them about dpi issues. This will not get fixed by them. I think we have a bigger chance fixing it ourselves if we hire a programmer to change the settings in the update file. |
06-15-2020, 09:08 AM | #2438 |
65
Rep 350
Anyone had an issue where the brightness keeps fading up and down on the andream unit? Thought it was my eyes at first but it’s definitely fading up and down. Think its idrive behaviour - some kind of auto brightness?
Diirek107.50 |
06-15-2020, 09:33 AM | #2439 | |
Rep 78
06-15-2020, 11:23 AM | #2440 |
9
Rep 55
How frequently? Mine changes when the auto headlights come on / off. It also auto switches maps to dark mode. Works well. No issue with it doing it when it shouldn’t though. You can test it by turning your side lights on and off.
06-15-2020, 03:15 PM | #2441 |
108
Rep 184
Guys - I've provided a link to the newest Bimmertech Beta Software and MCU that includes full screen, high-res AA. I doubt it will work on other units but I know many of you are willing to take a stab at it. Good luck.
https://f30.bimmerpost.com/forums/sh....php?t=1730502 |
06-15-2020, 05:46 PM | #2442 |
Rep 8
Hello guys, and it is possible to go back to the Andream unit to install other bimecteck versions, I have the latest version installed.
andream, android, android auto, apple, carplay, mmi, retrofit |
