BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Android 11 / 12 /13 HU discussion
Studio RSR
      02-21-2024, 09:46 AM   #2443
conandrum
40
Drives: BMW X6 E71
Originally Posted by RedErik View Post
Don't know what this file is, but it's not read only... not with the correct privileges. You can pull it, make the necessary modifications, start adb as root and push it to /vendor/etc/audio/
adb: error: failed to copy '..\discover-chat.pdf' to '/vendor/etc/audio/myfile.pdf': remote couldn't create file: Read-only file system
Yes root is required.
After much research, I have come to the conclusion that without rooting the device there is no way of modifying the current audio behaviour. Even then, nothing is guaranteed.
Shamanix is probably the only person in the world whose HFP calls (when phone is paired with Android HU instead of with BMW) audio output is going to his USB DAC. My HFP audio out goes to my 3.5mm audio out socket and to the harness instead.
My DTV audio output also goes to my 3.5mm audio out socket and to the harness.
logcat samples of the relevant tags, show this:
when playing KSW music player (audio via USB DAC):
02-21 16:09:55.925 D/audio_hw_primary( 735): enable_audio_route: apply mixer and update path: compress-offload-playback usb-headphones
02-21 16:09:55.925 D/audio_route( 735): Apply path: compress-offload-playback usb-headphones
when playing KSW BT player (audio via USB DAC):
02-21 16:11:51.152 D/audio_hw_primary( 735): enable_audio_route: apply mixer and update path: deep-buffer-playback usb-headphones
02-21 16:11:51.152 D/audio_route( 735): Apply path: deep-buffer-playback usb-headphones
when making HFP call (audio via 3.5mm audio out socket and to the harness):
02-21 16:12:35.080 D/audio_hw_primary( 735): enable_audio_route: apply mixer and update path: hfp-sco headphones
02-21 16:12:35.080 D/audio_route( 735): Apply path: hfp-sco headphones
when using DTV (audio via 3.5mm audio out socket and to the harness):
02-21 16:10:17.854 I/MediaFocusControl( 1490): abandonAudioFocus() from uid/pid 1000/9289 clientId=android.media.AudioManager@924c670com.wit s.bluetooth.core.GocsdkCallbackImp$$ExternalSynthe ticLambda0@3becde9
(DTV is not even registered as an app. It is some sort of hardware call or something. No events are registered in the log at all. Only event registered at DTV initialization is the abandonAudioFocus from other audio apps)
FYI:
To check your own device,
1. connect using adb to your HU using: adb connect xxx.xxx.xxx.xxx:5555
2. run this command and watch the log on your screen in real time:
logcat -s MediaRouter:* CastMediaRouteProvider:* PSOutputManager:* atoutput.c:* AudioFlinger:* audio_hw_primary:* MediaProvider:* MediaFocusControl:* MediaSessionService:* KswSettings:* audio_hw_primary:* msm8974_platform:* hardware_info:* audio_route:* soundtrigger:* sound_trigger_platform:* sound_trigger_hw:* audio_hw_utils:* MediaResumeListener:* -v time - D -T $(echo $(date +'%s')).000
      02-21-2024, 12:04 PM   #2444
conandrum
40
Drives: BMW X6 E71
My HU Specification:
MCU Ver:6150eALS-C&C-KTL-DC-230107G
APP Ver: Witstek-Ksw-T-M600_OS_v1.4.8
System Ver: Witstek-13-662EA-868927052938789
Snapdragon 662 (SM6115) Android 13
Differences between Cyrus Soundkey and FiiO Q3 MQA
FIIO CONNECT UAC2.0 (normal connection)
(Automatically plays some music)
02-21 19:38:54.448 D/audio_route( 735): Apply path: usb-headphones
02-21 19:38:54.450 D/audio_route( 735): Apply path: deep-buffer-playback usb-headphones
HFP CALL
02-21 19:39:05.127 D/audio_route( 735): Apply path: echo-reference headphones
02-21 19:39:05.129 D/audio_route( 735): Apply path: voice-line
02-21 19:39:05.147 D/audio_route( 735): Apply path: hfp-sco headphones
FIIO UAC1.0 CONNECTION (GAIN button pressed while connecting)
02-21 19:39:43.602 D/audio_route( 735): Apply path: usb-headphones
02-21 19:39:43.605 D/audio_route( 735): Apply path: deep-buffer-playback usb-headphones
HFP CALL
(1st call seems normal but ends with an additional low-latency-playback)
02-21 19:40:26.539 D/audio_route( 735): Apply path: echo-reference headphones
02-21 19:40:26.540 D/audio_route( 735): Apply path: voice-line
02-21 19:40:26.554 D/audio_route( 735): Apply path: hfp-sco headphones
02-21 19:40:36.742 D/audio_route( 735): Apply path: low-latency-playback usb-headphones
(2nd call is different - looking for hfp-sco usb-headphones route but cannot find it)
02-21 19:40:42.167 D/audio_route( 735): Apply path: usb-headphones
02-21 19:40:42.186 D/audio_route( 735): Apply path: handset-mic
02-21 19:40:42.196 D/audio_route( 735): Apply path: audio-record
02-21 19:40:42.235 E/audio_route( 735): unable to find path 'hfp-sco usb-headphones'
02-21 19:40:42.244 E/audio_route( 735): unable to find path 'hfp-sco usb-headphones'
(3rd call onwards are similar to 2nd)
02-21 19:40:57.476 D/audio_route( 735): Apply path: usb-headphones
02-21 19:40:57.480 E/audio_route( 735): unable to find path 'hfp-sco usb-headphones'
02-21 19:40:57.492 E/audio_route( 735): unable to find path 'hfp-sco usb-headphones'
SOUNKEY CONNECT
02-21 19:42:20.942 D/audio_route( 735): Apply path: usb-headphones
02-21 19:42:20.944 D/audio_route( 735): Apply path: deep-buffer-playback usb-headphones
HFP CALL
(1st call same as FiiO UAC2.0)
02-21 19:42:29.257 D/audio_route( 735): Apply path: echo-reference headphones
02-21 19:42:29.261 D/audio_route( 735): Apply path: voice-line
02-21 19:42:29.321 D/audio_route( 735): Apply path: voice-speaker-mic-hfp
02-21 19:42:29.325 D/audio_route( 735): Apply path: audio-record
02-21 19:42:29.366 D/audio_route( 735): Apply path: hfp-sco headphones
02-21 19:42:29.790 D/audio_route( 735): Apply path: voice-speaker-mic-hfp
02-21 19:42:29.798 D/audio_route( 735): Apply path: hfp-sco headphones
02-21 19:42:29.948 D/audio_route( 735): Apply path: audio-record
(2nd call same as FiiO UAC2.0)
02-21 19:42:41.718 D/audio_route( 735): Apply path: echo-reference headphones
02-21 19:42:41.721 D/audio_route( 735): Apply path: voice-line
02-21 19:42:41.736 D/audio_route( 735): Apply path: hfp-sco headphones
CONCLUSION
FiiO Q3 MQA UAC2.0 routes hfp audio to 'hfp-sco headphones' - this results in audio coming from the 3.5mm audio jack on the HU.
Soundkey is identical to FiiO Q3 MQA UAC2.0 in routing.
FiiO Q3 MQA UAC1.0 is different but still no routing path 'hfp-sco usb-headphones' exists. If it did, maybe it would result in audio playback via the DAC.
Both DACs do not output any audio when DTV is activated.
DTV is like a ghost with no way to investigate what it does with the audio. (see here: https://discord.com/channels/7024375...64706299084821)
Ultimately this has to be fixed by the manufacturer who is witstech.cn I believe (business@witstech.cn). I wrote to them on 10th Feb 2024 but no reply has been received.
PS. Blast from the past ))) https://discord.com/channels/7024375...41185205583872
RB — 05/01/2021 04:28
@Snaggle [DE] and @Keto[DE] Any chance you folks know how to switch audio from HU audio out to USB->DAC (I think within MCU, and not between OEM and HU), or prevent it from changing? Its the USB-DAC connected, incoming phone call audio not coming through speakers issue. (mic works but callers sound does not come through) ... SetMusicSource or Set Aux autoswtich or activation perhaps.?
Shamanix138.00
      02-22-2024, 03:59 AM   #2445
Shamanix
Russia
138
Drives: X6M E71, E63 645Ci, F01 750
With this version of the MCU and the firmware, as with all other firmware updates in the future, I also had no problems with BT calls and USB-dac
      02-22-2024, 04:19 AM   #2446
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
2004 E63 645Ci  [0.00]
Code:
adb connect xxx.xxx.x.x:5555
adb root
adb remount
Now you have root access to all system partitions.
      02-22-2024, 07:12 AM   #2447
conandrum
40
Drives: BMW X6 E71
Code:
adb root
adb remount
You are absolutely right.
I did not know that.
>adb root
restarting adbd as root
adb connect 192.168.10.16:5555
already connected to 192.168.10.16:5555
adb remount
remount succeeded
adb push D:\....\discover-chat.pdf /vendor/etc/audio/
D:\....\discover-chat.pdf: 1 file pushed, 0 skipped. 103.8 MB/s (342239 bytes in 0.003s)
      02-22-2024, 09:32 AM   #2448
Basti600
Basti600's Avatar
Drives: A-Class
Hello everyone,
is there actually a way to set the lines (in this case yellow and red) to the vehicle width?
      02-25-2024, 07:38 PM   #2449
conandrum
40
Drives: BMW X6 E71
Shamanix / RedErik
Guys, is the 'middle speaker' connection a good thing to connect or do you advise against it? (this guide does not explain much https://hifimaxnavi.com/pages/about-...ker-connection)
Just to confirm with you:
I have a middle speaker in the car.
I do not use the OEM navigation. I only use OEM radio/music.
So with the HU connected, the purpose of this 'middle speaker connectors' is ONLY to play the HU navigation prompts on the middle speaker at all times? (ie. even when the CCC is switched over to FM/CD/DVD etc?)
Secondly:
Is it useful to enable 'FL Speaker Enable' in Factory settings? Why/Why not?
GPS & 4G Antenna
My GPS SNR is about 24 (yellow). WhatGPS antenna do you recommend for stronger reception?
Are you happy with the 4G antenna?
Carlinkit CCPA
The HU takes 38 seconds after starting the car, to enter the main menu.
If we now launch the autokit app (for carlinkit), how many seconds does it take for everything to be ready and functional?
      02-25-2024, 11:48 PM   #2450
azizsaputra
Drives: BMW X1 E84
iDrive Controller Knob From Mekede brand
Hallo,
do you know where or how to buy iDrive Controller Knob from Mekede brand?
i need this part, because i buy android screen for my E84 without iDrive knob, my seller in here is not responsible, i complain but he gone.
can you help me pls
      02-26-2024, 02:25 AM   #2451
Shamanix
Russia
138
Shamanix / RedErik
Right. The speaker's operation is disrupted if you use the KSW-Toolkit. And it works relatively stably. And not with every navigation program.
Secondly:
This option has a default value for me. I don't use it. When activating this option on some MCUs, there may be problems with navigation program prompts through the speaker. In my opinion, this option is not compatible with every car. It is used when listening to OEM radio.
GPS & 4G Antenna
The GPS and 4G antennas work perfectly. Even in difficult conditions. If this is not enough for you, then you can connect to the OEM fin. Or use USB GNSS antennas with the ability to receive the L1 and L5 signal. And according to my observations, the quality of GPS signal reception depends on the navigation program itself.
I use https://www.topgnss.store/en-fr/coll...leo-receiver-2
When using Carplay, the data is displayed from the phone, therefore the phone antenna is used. The iPhone 14-15 has a GPS module L1 and L5
Carlinkit CCPA
about 1 minute
If it's a lot You can enable the HU download mode in OEM mode and connect the phone from the very beginning to the OEM BT. After downloading the HU, with the necessary settings, everything will be automatically reconnected as your heart desires. And switch the video signal to android
      02-27-2024, 03:30 AM   #2452
Basti600
Basti600's Avatar
Drives: A-Class
Originally Posted by Basti600 View Post
Hello everyone,
... or is it simply not possible?
      02-27-2024, 04:48 AM   #2453
Shamanix
Russia
138
impossible
      02-27-2024, 03:15 PM   #2454
fackamato
Sweden
71
Drives: 2017 M3 Comp
2017 BMW M3  [0.00]
Does this thread cover the hardware anywhere? What display / equipment is this thread referring to?
Thanks
      02-27-2024, 05:04 PM   #2455
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
Thanks
Read the first post.
      02-28-2024, 03:08 AM   #2456
Steljo
Drives: Bmw E61
Exclamation Question for GT6
Hi guys,i buy a new navigation and have a one question in my head
According from 1st post - CPU: Qualcomm Snapdragon 662 - 8 Core (4x 2Ghz & 4x 1.8 Ghz) - short "SD662 or M600" is it true this GT6-EUA=M600 ?
All my info about navigation:
GT6-EUA
MCU Ver
4151A0eLZH-C&C-KTL-DC-230713G
APP Ver
20231205GT_KSW_1920x720_EAU
System Ver
GT6-EAU-T16.00.050-userdebug-20231205.165619
AndroidVer: 13
BT Ver
BLINK 6125_R_2023/12/2-11:31:28
I make a 2 update`s from mega link with mega:..//GT6_KSW/EAU/ no problem.
Can i use Ksw-T-M600_OS_v x.x.x Android 13 for my platform ?
2nd question is for Factory_config.xml for this system, can i use someone, now i have only two UI`s ID7/ID8 ?
      02-28-2024, 03:49 AM   #2457
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
GT6-EUA
MCU Ver
APP Ver
System Ver
AndroidVer: 13
BT Ver
You can only use GT6_KSW update files for your unit.
The factory_config.xml should work for both version - classic KSW and GT6 KSW.
      02-28-2024, 05:57 AM   #2458
Steljo
Drives: Bmw E61
Ok, Which Factory_config to use i found for SD625 -Factory_config_BMW_A10_394.zip
For Android 10 ?
      02-28-2024, 06:07 AM   #2459
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
For Android 10 ?
Use the latest one for A11/A12/A13 versions.
      02-28-2024, 09:08 AM   #2460
Steljo
Drives: Bmw E61
Ok, Factory-config from SD625 and SD662 is the same ?
      02-28-2024, 09:11 AM   #2461
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
Yes and no. Yes factor_config.xml for SD625 will work on SD662. No factory_config.xml for SD662 will have a few more options if I remember correctly.
      02-28-2024, 09:14 AM   #2462
Steljo
Drives: Bmw E61
From where can i get this factory-config for 662 i read this - https://gist.github.com/kamilbrk/6cf...ory-config-xml
      02-28-2024, 09:34 AM   #2463
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
That's the one.
      02-28-2024, 10:35 AM   #2464
Steljo
Drives: Bmw E61
That's the one.
Thank you very much for the information
