03-02-2024, 12:09 PM | #2487 | |
40
Rep 224
1. A 'Y' splitter cable... where 2x 3.5mm jacks go IN and 1x 3.5mm jack comes OUT? So, you joined the HU audio out & the DAC audio out and plugged it into the AUX-IN? 2. DAC -> 3.5mm jack -> red/black/white wires -> FAKRA pins 2/7/8 (as shown below)? (This should do the same thing - maybe I will try this tomorrow). Last edited by conandrum; 03-02-2024 at 12:45 PM.. |
03-02-2024, 12:25 PM | #2488 | |||
40
Rep 224
From my experience the HU audio out has some noticeable white-noise in the audio output. However, when I plugged both the DAC output wire and the HU output wire, into a mini mixer (I posted 2 weeks ago) the white noise disappears. (HU on its own = noise) |
03-02-2024, 12:38 PM | #2489 | ||
40
Rep 224
and in parallel HU USB -> Helix USB HEX -> ??? (How do the signals mix?) Also, what about the low output volume from the HU BT phone calls and other audio? How did you overcome that? I know what you mean!!! I am still working on my setup. Even this afternoon! Last edited by conandrum; 03-02-2024 at 01:10 PM.. |
03-02-2024, 03:58 PM | #2490 |
71
Rep 285
Drives: 2017 M3 Comp
03-02-2024, 04:25 PM | #2491 | ||
1050
Rep 2,370
Drives: E63 645Ci
Model number: 123-China Link to retailer: AliExpress Sorry to be so blunt this is exactly what you asked about: Quote:
Ever heard of Chinese whispers or telephone game? Well this is exactly what Chinese are doing with these units. There is no model number, no one knows who actually manufactures the hardware and there are dozens of shops popping up and closing every day on AliExpress. We class them by SoC type and firmware that is running on them - so again, Snapdragon and KSW. Further more some shops mix photos, spec and description form other listings just to make it more difficult for you to know what you're actually buying. You will not find any links to shops in post made by Kri or myself for this and many other reasons. Other forum members might be willing to share where they got their units from but this is at their own discretion. Armed with the knowledge from the first thread you should be able to avoid bad units (or fake as we call them here - a device that pretends to be something that it actually isn't) when shopping for one. |
03-02-2024, 05:04 PM | #2492 |
67
Rep 143
Wondering if anyone has successfully installed A13 v1.5.0 on first post or can at least get the update pop-up. I tried loading it via USB stick but didn’t get the update notification. The only difference this time is I have KSW toolkit installed to test what it can do for me so not sure if that has any effect.
VRSF DP, VRSF 7" Intercooler, BMS OCC, Stg 2 LPFP, Custom MHD E30 Tune, Late Model E-Series N55
03-03-2024, 12:15 AM | #2493 |
71
Rep 285
03-03-2024, 03:53 PM | #2494 | |||
13
Rep 31
03-03-2024, 05:54 PM | #2495 | |
40
Rep 224
Thanks for all the info! Great!
If so, yes, whenever you get a call, you cannot flip over to another app until the call is over, by default! But, you can always go to the app properties and remove the permission to 'display over other apps'. I did test it and it can even do split screen. I did not test to see what happens when you get an incoming call though. Check it out. Last edited by conandrum; 03-03-2024 at 06:29 PM.. |
909912.50 |
03-04-2024, 11:32 PM | #2496 | |
13
Rep 31
03-05-2024, 09:06 AM | #2497 | ||
40
Rep 224
Shamanix
About the Q3 battery... Let's say you go on holiday abroad for a couple of weeks and leave the Q3 in the car without switching it off. When you come back, the Q3 will obviously be discharged. When you start the car, will the Q3 start working normally?... ...or will it need to be charged for a few hours, and switched OFF & ON, before it starts working? Look at this review on Amazon: Quote:
03-05-2024, 12:45 PM | #2498 |
138
Rep 294
No problems with the battery. Turn on constant charging. When the HU is turned on, even with the battery completely drained, the USB-Dac will automatically turn on and work. The instructions have a description of the modes. If this is not done, in a different mode, there may be problems with sound (shutdown) when charging is activated on the USB-Dac.
03-05-2024, 01:48 PM | #2499 | |
13
Rep 31
I'm gonna go back to using car Bluetooth (Combox) to take calls, at least this way I can still have control of the screen. |
03-06-2024, 02:41 AM | #2500 |
Rep 48
Im on A12 KSW with SD662 12.3" (the typical Mekede/Navifly). Usually I use ID7 Launcher but when using regular KSW Launcher I opened up BT by accident, since then I cannot get rid of the autostart of teh BT app. Very annoying.even closing all apps, then opening 20 or 30 other apps and using system for 30 minutes....after restart BT app again opened up...and again and again..I dont get rid of it..
Did I miss how to resolve this? Anything else I can do? I read something to open BT app from KSW launcher and then just go back from there to main screen of ksw launcher....will this resolve the issue? Anything else i can try ton ight when being back home? THANKS! |
03-06-2024, 03:26 AM | #2501 | |
Rep 48
Being "stuck" in the phone call screen was a major downside for me the whole time....only saw this "solution" by accident just now, because of my post about BT App is auto starting after each bootup and so far I could not get rid of that app autostarting..:-( |
909912.50 |
03-06-2024, 05:45 AM | #2502 | |
110
Rep 221
Drives: MINI Cooper, 2020 X1
03-06-2024, 06:21 AM | #2503 |
Rep 48
Thanks a million times. I will try this right away! I am happy for everything that saves me from doing factory reset! :-)
03-06-2024, 01:57 PM | #2504 | |
40
Rep 224
https://f30.bimmerpost.com/forums/sh...postcount=2478 My video & music apps were auto loading just before the HD icon was shown in the upper right tray area. It got resolved by reloading my factory config file. |
03-06-2024, 02:19 PM | #2505 |
40
Rep 224
Guys, when I press the 'voice command' button on the steering wheel, I get both the car's assistant and the google assistant answering at the same time.
Is it possible to get only one of them? I want google assistant only? |
03-07-2024, 01:54 AM | #2506 |
Rep 48
I resolved this by coding the car. I removed Sa620 from vehicle order/Fahrzeugauftrag of my BMW e60. You might also need to code SVS nicht_aktiv in ECU CAPPL (or whatever ECU is relevant for car assisstant)
conandrum40.00 |
03-07-2024, 01:56 AM | #2507 | |
Rep 48
Then when I did some call via BT, it was gone after next bootup and did not come back yet again :-) |
03-07-2024, 03:10 AM | #2508 |
1050
Rep 2,370
Drives: E63 645Ci
conandrum you still didn't answer what you need my permission for. You showed me a video of some animation that I have nothing to do with, so I'm really confused. I do understand what you are asking me for.
