12-01-2022, 12:48 AM | #2531 | |
Rep 1,566
12-01-2022, 07:41 AM | #2532 |
Rep 3,625
Whether it is a 19 or 20 inch wheel is just a reference point for measuring. Good advice about keeping the rear height. I think the rears are perfect as is.
12-01-2022, 03:20 PM | #2533 |
Rep 3,625
I just picked up the car and I think it looks great. I may adjust it slightly lower but I wasn't looking for a slammed ride. I haven't measured yet but I will this evening once I get it on level ground in my garage.
I am going to give it a week or two to settle before possibly adjusting and taking it in for alignment. My installer, who is primarily a Porsche guy, charged $900 which I thought was very fair. I will probably add some spacers and call it a day. |
01-16-2023, 03:49 AM | #2535 |
Rep 29
Hello, this is my setup. Front all the way down except one twist. Behind 2 turns of the screw, at the bottom as well. The white rubber that goes above the suspension was not changed at the rear, is it necessary to change it? I see him very high from behind. These are the tires that I need to put on the rear, the reference is the correct rear one, right? are the 4 tires the same? thanks Last edited by rapindrive; 01-16-2023 at 04:07 AM.. |
01-16-2023, 04:32 AM | #2536 |
Rep 29
01-29-2023, 06:48 AM | #2538 |
Rep 28
02-02-2023, 11:58 AM | #2539 |
4054
Rep 2,822
Just been sent these from my dealers. Will pick the car up tomorrow morning and can provide measurements if anyone requires them. Looks fantastic!
2020 M4 competition Mexico Blue / Opal white ultimate pack, full M perf carbon kit, MP HAS, Carbon Ceramics, 763M with cup2’s.
Instagram c1_cdg |
MadMax_6.00 |
02-09-2023, 03:35 PM | #2541 |
4054
Rep 2,822
Thank you mate. I didn’t have spacers but I put them in the boot when I dropped it off at BMW and asked if they would mind fitting before they did the alignment. They were happy to. So it’s all set up with the spacers on. 10mm front and rear. Didn’t want any wider than that
Instagram c1_cdg |
06-12-2023, 05:42 PM | #2542 |
Rep 4
Hello, I just installed the MPHAS on my '18 non-ZCP F80 - it feels and rides great - big improvement! After letting it settle a bit for a couple of days, adjusted one of the fronts to bring it within 3-4mm lower than BMW recommended height. The front was easy. I also need to adjust (raise) one of the rears by 6-8mm, and have tried multiple times without success due to the top of the spring seat spinning. This has been a fairly common problem acknowledged throughout this thread (yes, I read all 116 pages of it). So I tried raising both rear wheels at the same time to relieve some spring tension, no luck. I tried holding the top of the spring seat where it is wider and meets the car's body with these channel locks (https://www.amazon.com/dp/B0009WG5SU...roduct_details), but still no luck - very difficult to get a grip there as the spring seat top is thin and the channel locks need to go at an angle due to the strut being in the way. The channel locks scratched the spring seat top (even though I put electrical tape on the channel locks teeth), so I am reluctant to grab the spring seat below on the threaded section where it is a bit thinner, as I don't want to damage the thread. I have not tried gluing the spring seat top to the body with betalink as seems this cannot be reversed? Has anyone tried to pin the spring seat into the body by drilling a hole and putting in a screw? If yes, please share details (e.g. exact location to drill, drill bit and screw size, etc.) and photos, if possible. My only other option seems to be to go to the shop and have them undo the lower control arm bolt to release all spring tension, but I was hoping for an easier DIY method in my garage using only a floor jack. Thanks for your help.
06-13-2023, 11:01 AM | #2543 | |
33
Rep 55
Probably something you still can do when your car is jacked up. |
Rodride113.50 |
07-31-2023, 12:33 AM | #2544 |
Rep 1
At #2533 the height looks great! Can you tell me if possible the measurement of the threads in front and rear? I will install the suspension in the next couple weeks. Thanks!
09-20-2023, 12:52 AM | #2545 |
15
Rep 7
Hi,
what would be the downside of not replacing the oem bumpstops in the rear with the ones provided with the m performance HAS Kit? My car runs 3 years with the oem bump stops in the rear now… the ones in the front were switched out. |
09-20-2023, 09:35 PM | #2546 |
Rep 4
Weytens, can you show me exactly where you drilled the holes - a pic would be greatly appreciated, and what size drill bit did you use? Also, don't you have to put some type of screw into the hole, to keep the spring seat from spinning and the hole in the body mis-aligning from the hole in the spring seat? Let me know if you can PM about this. Thanks!
02-09-2024, 12:01 PM | #2547 |
Rep 16
MP HAS With CS EDC Tuning
Just following up on this well developed thread, hope folks are still keeping an eye on it!
I am a new 2018 Base owner with some ATROCIOUS lowering springs on my new vehicle (previous owner was trippin lol). Looking at all available options for improving my handling and this thread is selling me on the MP HAS. Something about sticking with M developed parts feels good... Wondering though: Is anyone running this hardware with the CS EDC tuning on their Base trim? I have read numerous good things about what the CS EDC tuning can do, and am wondering if the MP HAS and EDC tune is the best combo ever for my use (daily driving, no track days, but spirited back road runs). |
02-09-2024, 10:31 PM | #2548 | |
Rep 3,730
I run the CS EDC on my Bilstein B16 DDC setup and it rides great.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
LXAS6133.00 |
02-10-2024, 08:24 AM | #2549 |
Rep 16
That's great to hear, love another testimonial on the EDC tuning. Definitely going to go that route then. Just curious, did you do it yourself? If not, how much did you pay for a coder to take care of it? There's a DIY post that I looked at, and as an IT professional, doesn't seem too daunting. On the flip side, if someone is out there doing it for cheap, I'd be inclined to go that route.
02-10-2024, 09:22 AM | #2550 | |
Rep 3,730
LXAS6133.00 |
02-14-2024, 02:59 PM | #2551 | |
Rep 16
02-14-2024, 04:53 PM | #2552 | ||
Rep 5,961
Personally, I’d stick with dropping the control arm to remove the load on the spring and then adjust the ride height. Last edited by M3SQRD; 02-14-2024 at 04:58 PM.. |
LXAS6133.00 |
