03-30-2023, 09:16 AM | #243 |
General
10543
Rep 41,215
PM sent.
04-03-2023, 08:43 AM | #244 |
General
10543
Rep 41,215
PM sent.
04-11-2023, 01:39 AM | #245 |
Rep 2
Can i get info about CHAMP2? Latest iStep firmware, BMW F30 07/2012.
Voice Control - change language from DE to EN/PL. Apps/Live/Online/ConnectedDrive Activation? Use INTERNET from Tehering Phone? Custom system like CIC Portal? Change/Modify internal system SDcard? Anything more can be done? Last edited by BimmerLubuskie; 04-11-2023 at 02:32 AM.. |
04-11-2023, 08:39 AM | #246 |
Rep 21
Drives: 330d M sport Plus
Just came across this thread. I am a little confused, my car came with apps from factory on unlimited subscription but I cannot find any apps on the system. All I want is to access Spotify on my 2014 with Pro nav using my Android. What do I need to do to do this?
04-11-2023, 10:14 AM | #247 | |
General
10543
Rep 41,215
04-11-2023, 10:18 AM | #248 |
General
10543
Rep 41,215
Spotify is not supported on ConnectedDrive anymore. This happened after their Jul 21 update, in 8.5.68.904. Uninstall the updated version from phone then downloaded and install version 8.5.66.1002.
04-11-2023, 01:32 PM | #249 |
Rep 21
Thanks, but the problem I am having is that when I connect my phone and go to connection assistant, it keeps telling me to install the BMW connected App which apparently no longer exists so cannot get past that on the I drive.
04-12-2023, 09:42 AM | #251 | |
Rep 21
04-12-2023, 12:14 PM | #252 |
General
10543
Rep 41,215
PM sent.
07-02-2023, 10:07 AM | #254 |
General
10543
Rep 41,215
PM sent.
08-18-2023, 03:38 AM | #255 | ||
Rep 9
HI Guys! I'm pretty new to BMW coding and wanted to get the BMW Apps option in my 2018 440i GC with NBT EVO ID6. I've been reading up around here and there's just so much info to parse through, I am a little confused. shawnsheridan Would appreciate some help if possible!
I purchased a set of fake fsc codes since I have the EVO and the seller told me he enabled the apps option as well. I installed the fsc codes using featureinstaller and am able to update maps to latest so that worked but didnt see apps. Is there some way to verify that the codes he gave me have the apps option? Also, I understand I will need to update the VO of my car to have the 6NR option. To do this, should I: Quote:
Also, if I am jsut reading the VO, adding 6NR and then pressing code on the HU_NBT2 ECU, will I need a launcher or can I just use plain esys? Last edited by mavericknik; 08-18-2023 at 03:41 AM.. Reason: Added a question |
08-18-2023, 09:40 AM | #256 | |
General
10543
Rep 41,215
BMW Apps requires discontinued ConnectedDrive App though. It wont work with nw MyBMW App. And this is for Android devices only, not Apple.
08-18-2023, 10:11 AM | #257 | |
Rep 9
So is there no way to tell what the contents of my fsc code are and I just have to trust the seller when he said he enabled apps? I'm doing this to try to get AAIdrive to work, which I understand requires the apps option. Trying to see if I can get by without android auto. Thanks for the help! |
08-18-2023, 10:15 AM | #258 | |
General
10543
Rep 41,215
You can check FSC Code Status and see if 9C FSC Code is Status = Accepted.
mavericknik0.00 |
08-18-2023, 04:28 PM | #259 |
Rep 9
I'm a little confused now, I checked the FSC and I do see that the 9C fsc code is enabled:
Code:
AppID 156(0x9C) UpgradeIndex 1(0x01) SWTType SWTclassic light FSCStatus accepted FSCCertStatus not available From what I can see, maybe this is giving me the apps option from my VO? S6AKA - ConnectedDrive services S6NHA Hands-free Bluetooth and USB audio connection Is there some place I can compare 6AK/6NH vs 6NR? I'm wondering if adding 6NR to VO has any benefits. I don't see any mention of 6NR in the 2018 ordering guide here: https://f30.bimmerpost.com/forums/sh....php?t=1393556 |
08-18-2023, 04:31 PM | #260 | |
General
10543
Rep 41,215
6NH has nothing to do with ConnectedDrive / BMW Apps, although you should replace it with 6NS for Enhanced Bluetooth.
mavericknik0.00 |
09-17-2023, 10:23 AM | #261 |
Rep 12
Hello Shawn,
Can you please check if possible activate 6NR Apps to VIN: C764852? Understand need 9C FSC, but u writing BMW Apps discontinued ConnectedDrive App though, can use AAIDrive with Android prone at CIC_HU (609). And add 6NF - smartphone integration needs FSC. Thank you for help |
09-17-2023, 10:31 AM | #262 | |
General
10543
Rep 41,215
09-18-2023, 07:31 AM | #263 |
Rep 12
Thank you Shawn for your quick reply. Can you please send me instructions on how to get 9C FSC and add, load to esys (hope understand all previous instructions steps to add 6NR and code) Thank you
09-18-2023, 09:27 AM | #264 |
General
10543
Rep 41,215
PM sent.
Blekota0.00 |
