05-07-2024, 05:22 PM | #2685 | |
Rep 15
05-08-2024, 10:39 AM | #2686 |
Rep 8
05-08-2024, 12:36 PM | #2687 |
Rep 4
Hello!
Is there any way to fix android head unit with snapdragon 662 which is stuck on boot? https://f30.bimmerpost.com/forums/sh...postcount=4180 I disassembled the device following Kri's instructions in his post and finally saw that it was for the snapdragon 625. PS: You try with SD card it didn't work Thanks in advanced! |
05-09-2024, 02:40 AM | #2688 | |
Rep 23
Zlink (wired) launched faster too |
05-10-2024, 05:53 AM | #2689 |
Rep 22
Hi all, is it possible to stop the music from switching off when I go into the original BMW menu and also activate the arrows on the standard radio unit to skip songs etc?
I have currently connected it to my car via the AUX USB in the car using a Jack to AUX adapter Would be far easier if I could connect the screen via Bluetooth to my Bluetooth audio in my car but the screen for some silly reason doesn't allow you to do a Bluetooth search :rolling_eyes: Screen: M600 RAM: 8GB Memory: 128 Android 13 |
05-10-2024, 09:22 AM | #2690 |
Rep 1
Hello all, I've recently installed a RoadTop 10.25" HU in my F31. 662 M600 model. Since installing, everytime I start driving, I get a chassis stabilization error. When I stop briefly and take off again, it dissappears and stays away for the rest of the ride. Could anyone tell me what is causing this? I presume something CAN related?
05-10-2024, 02:39 PM | #2691 |
Rep 4
Thanks for the information! Seems to only be a tiny upgrade over the snapdragon 662 however. Yes, it has a much smaller manufacturing node (11nm vs 6nm) - so it's more efficient, but since a car isn't a phone, in practice that shouldnt matter much. Heat isn't an issue in a car. So when it comes down to performance, the newer chip clocks quite a bit higher, but it has the same gpu and basically the same specs apart from the higher clock. Disappointing for a "pro" device tbh. They should have gone for at least an 8 gen 1.
Check it out on notebookcheck: https://www.notebookcheck.net/Processor-Comparison-Head-2-Head.247596.0.html I'm still looking for which android box to order.. |
05-10-2024, 08:27 PM | #2692 | |
Rep 12
05-11-2024, 05:17 AM | #2693 |
Rep 13
A couple of days ago I was driving with the blazing sun facing me, and the back of the head unit, the warning like "your phone is getting too hot" popped up. Has anyone had this issue?
My journey finished within 10 of that, so it didn't progress and continued to work after the message during the journey, it is working OK afterwards too. I couldn't locate the message in notifications so couldn't screenshot it. |
05-12-2024, 02:01 PM | #2694 | |
72
Rep 44
05-13-2024, 01:40 PM | #2695 |
Rep 22
Hey
Thanks for this, I have had a play with KSW but got a few issues now hopefully someone can offer some help The buttons programmed to control Spotify don't seem to work, I have tried assigning other buttons but still not working any suggestions on a fix? Since I have installed KSW my screen will no longer automatically switch to the reversing screen, I have stopped the KSW app and then it seems to work again again any suggestions how to fix this? |
05-13-2024, 07:25 PM | #2696 |
Rep 1
Hey guys, very nice and interesting thread. I'm an owner of a Chinese Andream head unit in my BMW. The last pages also discussed sound quality and different approaches, partly by integrating an additional DAC like HU -> DAC -> AUX -> Radio/AMP. We recently found another option to directly stream digital data inside the native BMW amplifier via the MOST25 BUS.
You can read about the implementation on my blog: https://techblogio.com/blog/bmw-digital-audio-streaming. In my opinion, the weakest part of music streaming concerning quality is the conversion from analog to digital on the aux port, even if it can already improve the analog signal via the DAC. I can guarantee from my experience that it will make a significant difference in streaming completely digitally via the MOST-Bus if configured correctly and in the optimal case by also bypassing all default routines/filters inside the BMW amplifier (I also heard a difference if the CD_Changer support is activated inside the amplifier. If not, the sound is much better and seems to be forwarded to the DA converter without much processing inside the device, as the device doesn't expect a digital input on sink 2). You wouldn't expect how good the standard navigation system configuration already sounds without all the internal corrections and the AD conversion. Unfortunately, I'm not so good at staying active in the discussion due to my limited personal time. But check out the page and the related links if you are interested. Last edited by InfinityMod; 05-13-2024 at 07:50 PM.. |
05-14-2024, 11:57 PM | #2698 |
138
Rep 294
05-16-2024, 09:03 AM | #2700 |
Rep 2
Hello, I have installed mine Android 12.3 screen and it works OK in my BMW X2 F39. The problem I have with carplay is that the sound from my original BMW bluetooth was better balanced(right side) and without echo. When the sound comes through the Android there's a great amount of echo. Is there any setting so my carplay uses by default the OEM bluetooth connection for calls?
Yesterday, 08:16 AM | #2701 |
Rep 1
Hello everyone,
I was happy for a long time now with an Android10, with 10.25” in my F20. Now I have an F26 and have bought a 12.3” Android 12 (attached photo of original software and condition). My question is, does anyone else have problems with the screen on the rear view camera trying to adjust the brightness in vain, so that it is usually overexposed and you can hardly see anything? @RedErik From your point of view, can I switch to Android 13, would I have any disadvantages? Because apparently a few people here have switched back, or am I wrong? Many thanks in forward! |
Yesterday, 12:31 PM | #2702 | |
40
Rep 224
https://f30.bimmerpost.com/forums/sh...postcount=2612 |
Yesterday, 03:09 PM | #2703 |
1050
Rep 2,370
Drives: E63 645Ci
From my point of view? My last experience was with Android 10 over 3 years ago. I said this many times before and I guess I'll say it again: I think everyone should ignore these updates, find a nice launcher and forget Chinese shitty firmware.
Today, 02:39 PM | #2704 |
Rep 8
A new Ksw-T-M600_OS_v1.6.1-ota release just arrived today. The audio is better than 1.5.8 and the use is smooth. I thought I had to go back to A12 because I didn't like the audio but now I'm happy with A13.
