03-26-2015, 03:26 PM | #265 |
European Editor
10635
Rep 22,992
Never too soon to change your fluids(oils). What could it hurt? Its cheaper than a new trans. Change it and report back. Maybe try Redline's MTL that everyone is raving about.
03-26-2015, 06:52 PM | #266 | |
Rep 1,026
04-04-2015, 01:50 PM | #268 |
Rep 1,026
04-20-2015, 04:14 PM | #269 |
Rep 55
So I swapped out the transmission fluid last weekend and replaced it again with Redline D4 ATF because I had extra lying around from last time.
The world seems right again. Shifts are smooth and effortless. I used to have a weird situation where engaging the clutch in first gear was rough and it felt like the clutch wasn't smooth or something. The car would sometimes stutter when I let out the clutch. After changing my oil, transmission, and diff fluid all at the same time last weekend, that jerkiness/clutch uneven sensation has gone away too. |
04-25-2015, 06:35 PM | #270 |
California-bound
385
Rep 1,480
Just did this. This how to was handy, but I had the same thought as a few others, having changed the MTF on other vehicles, why not let gravity work for you. So I ran 3/8" tubing (thanks Joe O. for the size) from the engine bay downwards. Only snag, was when the tubing literally snagged against the chassis at some point and began dribbling out fluid as I was pouring it. Oh well.
Swapped in Redline MTL, having used their products with success in the past. Verdict is out on the difference in feel, maybe a bit more direct, but that's about it. Old fluid had 30k miles on it, was brown in color, still smelled like MTF, which is to say, nasty.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
06-01-2015, 10:40 AM | #271 |
26
Rep 144
Hi guys,
ive been thinking about replacing my diff and transmission fluids, but not sure at the end of the day which fluids to get for each. any of you guys that have done this and can guide me to which to get? thank you! |
06-01-2015, 02:07 PM | #272 | |
Rep 784
http://www.redlineoil.com/application.aspx |
06-11-2015, 08:25 PM | #273 |
Rep 759
Just did this recently and the DIY came in very handy, especially for torque settings and such. Went with Redline MTF and there is a noticeable difference in shifting smoothness. Really nice. Used the "tubing method" to fill from above, just under 2 quarts to fill. Used 1/2 inch tubing, was a perfect fit in the fill hole on the trans and the 2 quarts went in amazingly quick.
06-21-2015, 10:58 AM | #274 |
25
Rep 134
Hey everyone, my rear diff seal or axle seal is leaking, so I'llbe bringing it in to my mechanic for a gasker/seal replacement. Since this involves draining the diff fluid, what weight oil is recommended for it? It's a 2011 135i dct. My mechanic loves to a royal Purple, but has various weights, so not sure which is good for this car.
06-21-2015, 12:29 PM | #275 | |
European Editor
10635
Rep 22,992
BMW uses Castrol SAF-XJ or SAF-OX 75w140 GL5 gear oil. Lots of guys have been using Redline 75w90 GL5 gear oil - with no problems. See what your mechanic recommends. ? Dackel
06-22-2015, 09:27 AM | #276 |
25
Rep 134
Thanks Dackel. I dropped the car off. My mechanic suggestsed the 140weight as it'll provide more protection for me since I will be tracking the car 4-5 times per season.
07-03-2015, 12:35 PM | #277 |
Слава Украине!
2336
Rep 2,443
My transmission fluid at 17,450 miles next to fresh MTL. Meant to do it much earlier... Oh, and added a Dimple plug though swishing through the old fluid with a magnet yielded no particles.
Last edited by Suprgnat; 05-27-2022 at 10:59 AM.. Reason: Fixed broken pic link. |
07-03-2015, 12:56 PM | #278 | |
Rep 1,026
Have you thought about sending a sample for testing? Color doesn't necessarily indicate oil life, unless it has a burnt smell to it. |
07-03-2015, 01:04 PM | #279 |
Слава Украине!
2336
Rep 2,443
I might. I wasn't having any issues; I had really meant to do this as a break-in change at 1200-2000 miles and kept saying "tomorrow, tomorrow."
07-03-2015, 01:08 PM | #280 |
Rep 1,026
Gotcha. I believe I have read some research though that on transmissions, most metal wear occurs in the first 5-15,000 miles, so you're probably still good with regard to break-in.
02-09-2016, 01:45 AM | #281 |
Rep 528
LOL brohesive you just answered my question subconsciously hahaha
6MT/CDV Delete/Injen Intake/berk race exhaust/ Cyba Scoops/ECS cryo rotors/Axxis ultimate pads/H&R coils/BBS LM-esque lol/BMW PE front/whiteline sway/and did i mention 2200 at 1 ohm ...eyeing the auto diff currently
04-11-2016, 07:13 PM | #282 |
36
Rep 127
Does anyone know what the size of the gaskets for the manual transmission plugs and differential plugs are? Also, does material matter? Aluminum, copper, etc?
04-11-2016, 07:15 PM | #283 |
36
Rep 127
After further research, its recommended that the entire plug (including o-ring) needs to be replaced after each service? Seems overkill...what do you guys think?
https://www.fcpeuro.com/products/bmw...ug-23117531356 |
04-12-2016, 01:15 PM | #284 |
Rep 777
done it twice, re-used the plug each time.
328i Sports Pkg, Michelin PSS on Staggered 18" OZ Ultraleggeras
. BMS Powerbox. Cyba scoops + Rev motoring intake hose + charcoal delete. Wavetrac LSD . M3: subframe bushings + sways + control arms (fr & rr). Meyle rear toe arms. M3 diff fr bushings . BMW Perf: v2 springs + v1 dampers. Valeo SMFW+clutch. 034 MotorSport engine mounts . Short Shifter + Turner PU bearing + ZHP M weighted shift knob. CDV delete |
04-12-2016, 07:12 PM | #285 | |
European Editor
10635
Rep 22,992
Screw Plug With Gasket Ring M18X1,5 bmw p/n 23117531356
04-17-2016, 10:30 PM | #286 | |
Rep 1,001
But I was surprised that there was no gasket or metal washer around the fill or drain plugs on my mt. I'm also really surprised at how clean both the diff and MT fluids were after nearly six years (but only 15k miles). I used Fuchs Sintopoid 75w-90 in the diff and Pentosin FFL-3 which crosses per ZF to the right MTF for my gearbox. It's mainly a Porsche DCT fluid, but is an MTF per ZF. Shifts great. Despite the cleanliness of the fluids, I wouldn't mind getting a magnetic drain plug for the MT. Anyone know the plug spec?? |
